Back to:
Tags:
Sewing Machines
Generic problem for all Sewing Machines
Janome straight stitch loose (by 5 users)
posted by angelee on Aug 31, 2007
at first my top thread was bunching under the bobbin thread so I tightened the tension. Now my stithces are loose between the stitches and it looks terrible. I am using a straight stitch. I have rethreaded the machine, cleaned out the bobbin case, put in a new needle, changed the bobbin thread, and have oiled the machine.
Does anyone have any suggestions for me?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by Jax67, posted on Oct 05, 2008
In my case, even if I increase the pressure on the lower thread, it doesn't seem to work. There's no pressure at all and it doesn't seem to matter which way I turn the screw....if I pull on the thread there is no tension whatsoever.
Comment by Guest, posted on Jul 05, 2008
bottom thread is loose when sewing a straight stitch
Comment by Guest, posted on Jun 07, 2008
why are my stiches loose when sewing by machine
Comment by DOPPY, posted on Feb 12, 2008
MY TOP THREAD LOOKS FAIRLY GOOD, BUTTHE THREAD ON THE BOTTOMIS LOOSE AND NOT STRAIGHT1
Best Solution
posted on Sep 20, 2007
Helpful (85)
allmakes
Rank:Wiz Wiz
Rating: 84%, 1404 votes
Hello angelee,
Go through te process of ellinination even though you may have done it several times, when you thread the machine up make sure the presser foot is up so the thread goes through the tensions discs completely, set the top tension between 4 and 6 that should be ablout right but you may need to adjust it slightly,make sure you have the needle in the correct way round, the bottom tension should be set so you can just pull the thread through with some resistence, if it pulls through too easily just tighten the small screw slightly on the bobbin until you get some tension, if the bobbin is too tight that you really have to pull it through, slacken the screw off slightly, try it an see.
Ken
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on janome straight stitch loose:
I don't want to Accept this solution
Can you Help with these Sewing Machines problems?
Janome Memory Craft 9500 Computerized...
My Janome memory craft 95000 recognises the pc card (...
Janome MyLock 634D Mechanical Sewing...
I have a frister rossman overlocker - my best friend! and...
Brother CS-8060 Computerized Sewing Machine
I have a brother cs-80 thread is getting tangle up where...
bottom thread bunches (loops) up into many loops where the...
Baby Lock Ellure
error message is "the safety device has been...
Loading problems.
Repair Service
Find Sewing Machine Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
