Question about Leica C1 35mm Point and Shoot Camera
Repair I dropped it and the camera not working, it turns on but that's it
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
Dropped my easyshare C1550 & now it doesn't work!
Not hard to figure out, you need a new camera because the cost to repair it will be more than you paid for the camera when you bought it !!
Oct 01, 2012 | Kodak Cameras
It drop from me and it will not turn on what must i do
The digital camera's don't do well when it has been dropped, I would suggest having it checked out to see if a repair is a option.
May 15, 2012 | HP CB350 Digital Camera
Camera dropped in water
If you had immediately fished it out, removed the batteries, and let it dry thoroughly before even attempting to turn it on again, then the camera MAY work again. If you had left the batteries in or tried to turn it on again while wet, your chances are much less.
If your camera doesn't turn on after it's dried out, then you have to either replace or repair it. Given repair costs and the expected life cycle of digital cameras, it's probably more economical to replace it with a newer model. Of course, since you neglected to specify the model of your Canon camera, I can't make that decision for you.
May 09, 2012 | Canon Cameras
I dropped my fujifilm finepix av100, the lens is now stuck and will not go back in when i turn off my camera. when i turn on my camera it says ''turn camera on and off'' but it doesnt solve the proble
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here's a 16 minute video summary of the info shown in the link. But note that the article link above goes into even greater detail than this video:
Nov 17, 2011 | FUJIFILM FinePix AV100 Digital Camera
I dropped my camera whilst the lense was out and everytime i turn it back on the lense doesn't move it just says 'turn power off and on' and i turn it off, turn it back on and it still says the...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 28, 2011 | Sony Cyber-shot DSC-N1 Digital Camera
Some stupid person has dropped and then kicked my brand new Samsung camera and now it won't turn on and the lens is stuck out :( When I try to turn it on it makes a weird beep and won't turn on and...
You should try to get that stupid person to buy you a new camera if the following doesn't help. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Jul 09, 2011 | Samsung Digimax S730 Digital Camera
My Canon Digital Ixus 100 IS camera get ''Lens error,restart camera'' everytime I try to turn it on. The lens is also stuck outwards. This is after a friend of mine dropped it. I have tried...
Here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 04, 2011 | Canon PowerShot SD780 IS / IXUS 100 IS...
I dropped my Polaroid i735 Digital Camera once and the screen has been blurry...even the pictures turn out blurry. Is there any way to fix the screen?
You dropped it only once? Hmmmm ....
I don't think the problem is with the screen.
It's more like the lens can't focus properly anymore, and there is nothing you can do to fix it.
I'd take it to my local camera repair place, and give them the classic:
"Don't ask me what happened. I lent it to my baby-brother, and he said the camera worked OK."
They just may give you a free estimate.
Jun 27, 2011 | Polaroid i735 Digital Camera
Dropped camera. Will not turn on. Sticking lens cover prior to drop. Olympus stylus 500
Most probably you already have a defective camera. The camera's internal components are sensitive to shocks especially the lens. If it's not turning, try to remove the battery first for 10 minutes. If it didn't turn on after you put it back in, more likely you need to send the unit to any camera repair center.
Oct 23, 2009 | Olympus ? Stylus 500 Digital Camera
Leica C1 35mm Point and Shoot Camera Logo
29 people viewed this question
Top Leica Cameras Experts
Steven Wander
Steven Wander
Steve
Are you a Leica Camera Expert? Answer questions, earn points and help others
