Question about Vacuums
Bissell 1671 y big green clean machine
How do I get an instructional manual?
reddevil6
  • 1673 Answers
SOURCE: Big Green Machine
Go to Bissell.com and see if a user manual is available for download. You will need your model number tho.
Posted on Feb 14, 2008
SOURCE: Bissell Big Green Machine Model 1672 will not pump cleaning liquid
have a Bissell Big Green 1672, the older canister model. Went crazy trying to figure out how to get to the pump. Finally figured it out. The top green "shell" covers the motor & pump and is separate from the "grey" plastic housing. Using a screw driver, insert it between the small gap between the top "shell" and the housing. If you look at it with it laying down on the top, you will see the small 1/4" gap. Gently pry in between the two and work your way around. It will start to lift up and then you can easily work your way around and it will pop off exposing the motor and pump. Note that the wires to the on/off & pump switches will sill be attached to the top shell. If you take them off note where they came from and make sure they are all on when you put the top back on. I have had my Green Machine for years, what a work horse! To bad they don't make them anymore, the new ones that replaced them just don't have the same durability and power as the older Green Machines.
Posted on Mar 11, 2009
SOURCE: I need instructions for the Bissell Big Green powerbrush
I recently did a Google search an owners manual for my inlaw's Bissell. I just googled your 168-3 and found a manual, hope it is the right one,
Posted on Apr 09, 2009
SOURCE: Big Green
We found that ours had a simpler problem. Upon opening the motor compartment, we saw that the pump had "nudged" up from it's mounting slots. It is held down by a clip on each end and one had pushed up, allowing the pump to ride up and thereby disconnecting the short hose which kept the "suction train" intact. Once we re-seated the pump correctly and pushed the clip back down, the hose reached nicely and our suction was re-established.
Getting into the motor and pump area was the hardest part. Inside the power hose "cubbie" is a small hex head screw. Find your shortest stubbiest 1/4 inch open ended wrench to loosen this screw (lefty-loosey). Once the screw is out, gently pry along the edge with fingers and thumbs. The top (ours is green) part should separate itself from the bottom (ours is beige) part. The pump in our unit is red and has a 4-5 inch hose leading from the end of the pump to the outlet (on the outside of the green or top part). Re-assemble and go for it!
Posted on Jan 19, 2010
BissellCSR
  • 276 Answers
SOURCE: looking for cleaning instructions for bissell
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Posted on Oct 13, 2010
How can I download Bissell Little Green Clean Machine manual?
direct
https://canada.bissell.com/support
or the first link has it, also videos
  • BISSELL LITTLE GREEN 1400 SERIES USER MANUAL Pdf ...
    www.manualslib.com > ... > Vacuum Cleaner > Little Green 1400 SERIES
    Bissell LITTLE GREEN 1400 SERIES User Manual. ... Vacuum Cleaner Bissell Little Green 1400 SERIES User ... Rcvd a used bissell little green machine w stagnant ...
  • Bissell Little Green Machine ' Walmart.ca
    www.walmart.ca > Walmart.ca > Appliances > Vacuums > Steamers
    • 4.1/5
    • 185 REVIEWS
    • $99.96
    Bissell Little Green Machine for sale at Walmart Canada. ... Powerful suction lifts stains and spots with water or any of the Bissell cleaning solutions.
  • Little Green® Portable Carpet Cleaner ' BISSELL®
    www.bissell.com > ... > Browse By Type > Carpet Cleaners > Portable
    The Little Green® portable carpet cleaner is produced with a minimum of 50 ... Coupon code for purchases on bissell.com: ... (including all accessories and manuals) ...
  • BISSELL LITTLE GREEN CLEAN MACHINE PDF - fenbook.me
    fenbook.me/get-it-free/b/bissell-little-green-clean-machine-manual.pdf · PDF file
    Get Free Read Online Ebook PDF Bissell Little Green Clean Machine at our Ebook Library. Get Bissell Little Green Clean Machine PDF file for free from our online library
  • Bissell Little Green Owners Manual ; Bissell Little Green ...
    www.youtube.com/watch?v=PpQji8obNz4
    • BY BOTHSHOOP
    • 4 MIN
    • 11K VIEWS
    2012-11-07 · Video embedded · Bissell Little Green Owners Manual ; ... Bissell Little Green Owners Manual ; Bissell Little Green Machine ... How to fix a Bissell Carpet
  • Bissell LITTLE GREEN 1400 SERIES User Manual
    May 24, 2016 | Bissell Vacuums
    Bissell big green clean machine extention hose not spraying
    Hey, sorry you're having difficulty with the spray on the hose.
    Here's a quick link to troubleshooting steps to assist you:
    http://www.bissell.com/FAQDetail.aspx?id=23646&cid=ccsocial
    Feb 28, 2013 | Bissell Big Green Deep Cleaning Machine...
    Apr 09, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
    Big Green Machine
    Jan 09, 2008 | Vacuums
    Vacuums Logo
    56 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
