Question about Friedrich Heating & Cooling
Ac unit keeps freezing up - Friedrich Heating & Cooling
    Genius:
  • Friedrich Master
  • 1,363 Answers
Low on freon ,dirty coil or fan speed not right
Posted on Sep 14, 2015
We have a Goodman AC Unit and the pipe continues to freeze.
either the inside coil is dirty or system is overcharged.
May 14, 2014 | Goodman CLQ36AR49 Air Conditioner
Ac unit in the house keeps freezing up, not a window unit, central unit. The entire part inside keep freezing up, making knocking noise, and not blowing cool air. The out side part is fine, no problems...
There is a coil out side in the unit , it needs cleaning, there is an acid that is used to clean it. Its an easy job, pull the top open and use a stick or something to keep it up so you can spray the coil, with the unit off let soak 10 mins then spray wash with water hose. done
Sep 29, 2013 | Heating & Cooling
My AC keeps freezing up
Hello, the unit will freeze up either due to a airflow problem, suchs as dirty filter, dirty evaporator coil. Or a low refrigerant charge
Jul 06, 2012 | Goodman GPH1324H21A WallWindow Air...
If i set the temp to low on my window air conditioner can it cause the unit to freeze up
Under some conditions, it could freeze up. High humidity levels can cause the coils to freeze. Not cleaning the air intake filter regularly, can also cause the coils to freeze. However, most window units can not be set below 65 degrees. But, in high humidity, it could freeze at that temp.
If you want to avoid the possibility of the coils freezing, operate a ceiling fan or other small fan as fast as comfortable. This keeps the cool air moving a generates a wind chill that fools your body into thinking it's cooler than it really is. Doing this will keep you from having to turn the AC way down and thus, save on energy cost.
I hope this has helped you and thanks for choosing FixYa.
Sep 08, 2011 | Heating & Cooling
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
Model Number: UACC-036JAS The unit works fine. The problem is it doesn't shut down after the specified temperature has been reached. The furnace blower shuts down, but the ac unit keeps on running....
Hello, usually a stuck contactor coil will cause this on the outside unit. When the outdoor unit runs continously and the indoor blower does not run no heat is being absoebed by the evaporator coil and thus the line freezes. Replaceing the contactor will fix the problem.
Aug 30, 2011 | Ruud Heating & Cooling
My window ac unit keeps cycling off, before it gets to the assigned temperature. Help
What may be at issue is evaporator icing. Some units cycle the compressor, others control the refrigerant to keep the evaporator temp just above freezing. If allowed to continue the evaporator would freeze over and air flow would stop....
Check and see if that is the case...
Jul 20, 2011 | Haier HWR06XC6 Wall/Window Air Conditioner
Ac unit keeps freezing up owner says only at night
A/C's freeze up due to low air flow or low refrigerant charge. Check your air filter and make sure all your registers and vents are open and not blocked. You may need a service tech.
Aug 13, 2009 | American Standard Heating & Cooling
Freezing up, home ac unit no air flow after running a while
A low freon level in the unit can cause them to freeze up. Are the fins behind the filter clean?
Jun 19, 2009 | Whirlwind FH-778 Air Conditioner
My AC unit keeps freezing up on the copper lines going into the house from the outside unit. It also freezes up on the inside lines and the air is not cooling my home down.
Operate your air conditioner with the fan in the on position. But first turn the fan on, turn the temp up or shut the cooling off. Your coil is more than likely frozen over. At night when outside temperature drops the refrigerant pressure and temperature in the system also drops. This action can cause icing of the cooling coil, with the fan in automatic everything shuts down at the end of a cooling cycle. Thus no air movement to melt ice on previous cooling cycle.
May 09, 2008 | Heating & Cooling
Heating & Cooling Logo
99 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
Michael Vincent Cruz
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
