Question about Garden
Poulan Pro 500ex riding mower, starts but wont go forward or backwards rear wheels seem to be locked up. Anyone ever run into this ?
  • Garden Master
  • 2,478 Answers
Check your drive belt. May have come off or broke.
Posted on Mar 20, 2015
  • 1,169 Answers
Check the brake caliper; it may be struck
  • 653 Answers
SOURCE: snapper rear engine riding mower clutch
It is time to replace the driven wheel. When you flip the mower up on the back end (after closing the vent on the top of the fuel cap), the driven wheel is the disc that has rubber on the outer edge that rides on the silvery disc that comes off the end of the motor. The last time I bought one was about 7 years ago, at which time it cost me about $7.85. I would expect it to be around $11-12 these days.
Posted on Apr 07, 2009
  • 109 Answers
SOURCE: MTD PRO RIDING MOWER/LAWN TRACTOR 18 HP ENGINE HYDROSTATIC DRIVE
In the back of the mower...probably under the seat, there should be a lever to release the transmission, or it is on the back plate. As far as the noise when trying to move drive the mower, the brake in the back, next to the transmission is jammed, use a 1/2 inch wrench to loosen it maybe 1/4 turn and this should unlock the brakes
Posted on Apr 22, 2009
  • 4 Answers
SOURCE: Hard to shifet my poulan pro and wont go into reverse
Try loosening the belt tension to the transmission a little bit. Some of these are just stiff and you have to slip the clutch a little to rock them into gear.
Posted on May 25, 2009
SOURCE: Murray Riding Lawn Mower won't start or move
The Drive Belt keeps coming off as soon as I engage the mower I replaced the Drive Pulley and put on a new belt but it still comes off. Any Ideas.
Posted on Aug 15, 2009
SOURCE: Murray Riding Mower will not move forward or back
my murray Riding Mower will not move forward or backward
Posted on Sep 03, 2009
How do I unlock the rear wheels, I got a Poulan Riding Mower from a late Uncle. It won't roll forward or backwards
Kevin, if it is in neutral or if it is hydro-stat, you have pulled the pins in the back to unlock the axles. the brakes may be locked up. the last two mowers i got for some reason the brakes were locked up on them both. hope this helps.
Dec 16, 2016 | Poulan Garden
Poulan pro 500ex I need the belt and pulley diagram to make sure the belt is on correctly
Jason, Belt routing for Poulan Pro 500 on page 18,19 and 20 of attached manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
User Manuals
http://www.poulanpro.com/ddoc/ppoo/ppoo2012_aaen/ppoo2012_aaen_pb22h46yt_532448351.pdf
poulan pro 500ex belt diagram Google Search
May 22, 2016 | Poulan Garden
I have a poulan pro 500ex 22.0 up 48"cut it will not engage the blade or drive how do I fix it
if engine runs but does not provide any movement in wheels or deck , id ck the drive belts 1st , there is a separate belt for drive and deck , its possible both of these are broken or slipping badly
Jun 22, 2015 | Poulan Garden
My poulan pro 500ex runs until I try to go forward or backward then it shuts off
did you check the seat switch ???... unhook the kill wire at the engine ( for testing purposes ONLY ) and then try to move... if it works check you safety system... if not, check your safety system
Aug 30, 2014 | Garden
Mower deck on Poulan Pro 500EX does not start sometimes
check the safety switch on the seat
May 08, 2012 | Garden
Poulan Pro riding mower jerks in forward and the blades engaged
This is a lawn mower catagorized as a chainsaw. We don't answer lawn mower questions ands you don't cut down trees.
Mar 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
209 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
