Question about Philips 190VW
Attention analog vga
The above keeps appearing on my screen even when computer is turned off. How can I get rid of it?
Empowering Technology screen keeps popping up...can't get rid of it
Go to start,type in Msconfig and press Enter.You will see a box with a section labelled Startup.Click on that and look for Empowering Technologies in the list.Any with that description,remove the checkmark and the go to lower right corner of the box and click apply then ok,then restart your computer.That should fix your problem..good luck :)
Sep 01, 2014 | Acer T232HL 23" LED LCD Touchscreen...
Hi! I want to remove the OSD attention from my monitor. How do I manage this? It's necessary to me remove this attention pop out.
OSD popup no signal If you are getting a message that says something like"Check cables" "no signal detected" or something like that,it is likely that your monitor is operating correctly. I would suggestchecking your cables, make sure that the computer is turned on, and if thatdoesn't help, check if your monitor has VGA, DVI, or HDMI inputs. I amthinking that your monitor may be trying to display from the wrong source. This is what a VGA (analog) cable looks like. VGA cables aretypically blue.tgvern_4.jpg
Another common connection that is used is a digital HDMI (left) or DVI(right) connection. DVI cables often have white endconnectors. How your PC connects to your monitor will determine thesource mode you want to use on your monitor. (Obviously this is the cableview but the connection on the monitor itself will look similar.) tgvern_5.jpg
If none of these tips helps, I would suggest hooking the same monitor up to adifferent PC or laptop, and trying once again to get a the display working. Again, make sure that the connection matches the source setting on yourmonitor. If it works on another PC, then your computer may have a videoproblem.
Otherwise, if it still does not work your monitor have a problem displaying viathat connection. If possible I would suggest switching to a differenttype of cable and re-try the above steps.
Mar 20, 2011 | AOC FOVI F19S Monitor
My monitor is an Acer 20". model # X203H I am using a MSI MEGA computer which has a VGA connection. My Acer monitor has two connections aVGA and DVI , I am using the VGA connection from the ACER Monitor...
There is both an analog and digital setting on your monitor settings. Bring up the monitor settings and toggle between the digital and analog settings until you get a signal.
Sep 13, 2010 | Acer Computers & Internet
I need help from anyone when i turn on my computer and log on a box in the middle of my screen and says no signal and about 3-5min later it gose away and the screen turns off make a little beb and turns...
Check your monitor's cables. There might be a loose VGA cable (or whatever interface you use). If that's not the case then your PC's VGA adapter (or graphics card) might be faulty. Get it repaired or replaced. If it's the on-board VGA solution, then you could just purchase a cheap graphics card.
May 19, 2010 | Acer X193W LCD Monitor
Analog out of range display on the screen
try the lcd monitor on another PC, if the same message pops out, your monitor needs reprogramming of its A/D board, bring it to a LG service center..
if it works fine on another PC, try to boot your PC on VGA mode..
May 10, 2010 | LG 22" FLATRON LCD Monitor
Vga
Video Graphics Array (VGA) refers specifically to the display hardware first introduced with the IBM PS/2 line of computers in 1987,[1] but through its widespread adoption has also come to mean either an analog computer display standard, the 15-pin D-subminiature VGA connector or the 640×480 resolution itself. While this resolution was superseded in the personal computer market in the 1990's, it is becoming a popular resolution on mobile devices.[2]
VGA was the last graphical standard introduced by IBM that the majority of PC clone manufacturers conformed to, making it today (as of 2010[update]) the lowest common denominator that all PC graphics hardware supports, before a device-specific driver is loaded into the computer.[citation needed] For example, the MS-Windows splash screen appears while the machine is still operating in VGA mode, which is the reason that this screen always appears in reduced resolution and color depth.
VGA was officially superseded by IBM's XGA standard, but in reality it was superseded by numerous slightly different extensions to VGA made by clone manufacturers that came to be known collectively as "Super VGA".
Apr 14, 2010 | Foxconn P9657AA-8KS2H Motherboard
Analog power saving mode
If its going to analog power saving mode, that is what its supposed to do when it does not get a recognizable connection from a computer vga port. I would suggest coming back on with some more information about your computer and suggest testing another screen on your pc.
Oct 31, 2009 | LG 22" FLATRON LCD Monitor
''not optimum mode'' icon continues to show
this is not the problem with your monitor. Pl boot your computer with enable vga mode. in vga mode set your resolution into 1680 x 1050 with which color mode you need set ok
it will be ok. After restart, your computer will ok. even the problem retains, pl reinstall the video driver and try again. give me ur feedback
Aug 25, 2009 | Samsung SyncMaster T200 LCD Monitor
Analog
Seeing the word "analog" on your screen means the monitor has recognized video input on the vga "analog" input connection.
Most computers output "analog" vga (15 pin) which must be converted to digital for a flat panel monitor to display the image.
Many LCDs now have both analog and digital inputs.
Mike
May 01, 2008 | ViewSonic VP191b 19" LCD Monitor
FLOATING BLOCK
hi, it means, u need to change the input mode i.e pal/ntsc/vga..etc or whatever options avilable in the LCD menu..let me know
Dec 28, 2007 | Rosewill 19" 12MS DVI R911E LCD Monitor
Computers & Internet Logo
171 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
