Canon mf8300 Why won't my scanner scan?
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: lexmark x4530 multifunction printer/copier/scanner. The
    There could be something blocking the scan communication - possibly a firewall. If you have a firewall enabled on your computer, make sure to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
    Posted on Jul 01, 2011
    • 12 Answers
    SOURCE: scanner won't scan. the light
    depending on the scanner the belt may not be broken, however the gear that it rides on may not be moving, or the belt is slipping. Some scanners the glass can be removed for you to visially see the gear and evaluate from there
    Posted on Jul 15, 2011
    • 867 Answers
    SOURCE: won't scan
    Yes canon are a pain, they make them so that you have to purchase ink cartridges in order to use any functions of the multifunction.
    Posted on Mar 06, 2012
    Geekman
    • 32281 Answers
    SOURCE: Canon MX860 won't scan to a pdf
    Scan and create PDF documentYou need to install a PDF printer driver on your computerfirst. There are quite a few freeware PDF writer programs on the Internet youcan download one such as CutePDF.
    From your computer SCAN your document then click on File - Print and select thePDF writer as the printer device. Then name and save the PDF file. To download Cutepdf PDF printer driver (freeware) click onthis link :-http://www.cutepdf.com/
    Posted on May 19, 2012
    Cogz
    • 1326 Answers
    SOURCE: Kyocera CS-C2525 won't scan
    Do you have the option installed on you copier??? Also, there is another ether connector for scanning. If it is installed it is right above the print PCB.
    Posted on Jun 03, 2012
    Cannon error codes
    Printer is in use or an error has occurred. check status. Scanner driver will be closed.
    code 2,140,2
    if scanner is not in use there is a problem using it with the USB unplugged.
    May 15, 2013 | Canon PIXMA MX892 multifunction printer
    CANON PIXMA SCAN CODE 2,151,44
    I have a PIXMA MP340 printer/scanner--prints fine but when I try to scan, it gives me error code 2, 151,44.
    Nov 06, 2012 | Canon PIXMA Office Equipment & Supplies
    5010C scanner won't skip blank pages
    We had this problem and discovered it was caused by a small piece on the glass. Once the glass was cleaned, the blank pages were skipped.
    Sep 11, 2012 | Canon DR-5010C Scanner
    My Canon P-150 keeps giving me a "double feed" error and won't scan.
    Uninstall all drivers and scanning software. Switch off the comp and Scanner, restart the scanner first and then the computer. Then reinstall software again
    Jun 07, 2012 | Canon imageFORMULA P-150 Personal Document...
    DR-6080 not recognised after reloading Windows 7 (32-bit) on laptop. Re-installed latest driver (says Win7 supported) successfully but still won't work, Anything?
    Disconnect the scanner from the computer. Uninstall driver software, shut down and restart the Comp. Reinstall the driver. (http://software.canon-europe.com/software/0036991.asp?model= ). connect the scanner and the system will report USB device plugged in. This should work.
    S. Mohan. Chennai, India
    Dec 02, 2011 | Canon DR-6080 Path-Through Scanner
    Canon mx310 won't scan message reads "the
    Please go to Control panel and choose add or remove programme.. kindly uninstall the program i.e. Your printer driver after all re-install the driver... thanks
    Aug 22, 2011 | Canon PIXMA MX310 All-In-One Printer
    Canon pixma mx 700 won't scan showing error code 0x00000015
    This is a windows or software error code,Uninstall the scanner/printer software and reinstall from the CD
    If you have lost it you may download new drivers from here
    http://support-au.canon.com.au/P/search?model=PIXMA%20MX700&filter=0&menu=Download
    Aug 16, 2011 | Canon PIXMA MX700 All-In-One InkJet...
    Canon mp 980 won't even copy or scan if any ink runs out. Is there any way to change that?
    Sorry, but no. As far as I know that's how all of these all-in-ones work. If the printer doesn't work because the cartridges run dry, nothing else works either. They don't allow you to use the scanner as a standalone piece.
    Jul 06, 2011 | Canon PIXMA MP980 All-In-One InkJet...
    Scanner won't work
    If you are using a wireless connection, your scanner will not work.  I was told the printer does not have the capability to scan wirelessly....prints wirelessly, wont scan
    May 11, 2009 | Canon Pixma MP500 All-In-One InkJet...
    32 people viewed this question
    k24674
    jasbo
    jasbo
