Question about Dryers
Samsung dv 398 error code ur 08
No heat. Power is good, venting is good.
2 Suggested Answers
SOURCE: Rheems Power Vent Model 42vp50fw Manufactured
Intellivent gas valve shows AB and vacation error lights:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
The igniter and flame sensor have to be positioned correctly:
http://waterheatertimer.org/pdf/Hot-surface-igniter-troubleshoot.pdf
Check electrical outlet with circuit analyzer, and test that unit is receiving 110Volts
Intellivent gas control must be grounded.
Check that gas control is getting 24volts.
Check for air in gas line and low gas pressure.
Following links offer troubleshoot resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Sep 11, 2011
Error Codes on our Samsung RF4289HARS refrigerator: Error Code: 6E, 2E, 25E, 73, 40E
https://removeandreplace.com/2015/08/10/samsung-refrigerator-error-codes/
Oct 28, 2017 | Samsung Computers & Internet
How to fix the error 10-398....Thanks
Hello, GRAFOPRINT. Error 10-398 in older Xerox machines was a cooling fan failure. Depending on the model, it isn't very difficult to replace. If I remember correctly, depending on model, a computer case fan will bolt right in wiring and all. Hope that helps. Good luck and God bless.
Jun 01, 2015 | Office Equipment & Supplies
Error code 08
Good Morning Friend,
I understand that you are receiving a 08 error code on your Electrolux dryer, model# T4530. I have researched your appliance and noticed that it was manufactured in the UK. What is suggested for the North American appliances is to reset them, by either unplugging them or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this. If this does not work, I suggest contacting the manufacturer for further assistance. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Electrolux Dryers
Error Code E-08 on Samsung Gas Range. Oven will not heat but range top works.
Is there a gas pilot light that stays lit all the time or does it have an electric pilot light that glows red to start the oven.Either way if it's a gas pilot the thermocouple is bad, if electric the igniter is bad.
Jan 03, 2014 | Samsung Kitchen Ranges
Hei, need help when printing from Samsung Galaxy Tab 10.1/Polaris Office app to Samsung printer SL-M2070W: SPL error code 11-1113 position 0x0 system h6fwsim/xl_image line 398 version spl 5.73. Thanks in...
I am trying to print via wi-fi direct, and it gives me:
SPL ERROR -Please use the proper driver
POSITION 0x0
SYSTEM h6fwasim/x1_image
LINE 398
VERSION SPL 5.73.04 06-10-2014
ERROR CODE 11-1113
Any help?
Oct 10, 2013 | Office Equipment & Supplies
Noritz Boiler NH-1501-DV-NG Shuts off at radom times with blinking error code 123
error code 123 is a flame rod sensor problem. Chances are the flame rod is sending a weak signal to the control unit. Check for a loose flame rod electrical connector. Peek in the flame inspection windows to ensure there is a proper flame on that side of the burner. If non of the above then try removing the flame rod and cleaning with 400 grit sandpaper or replace it with part order # SKC7448 (called an Ignition plug ELV & Packing EHK SETV)
Dec 16, 2012 | Noritz NH150-DV-NG Indoor Direct Vent...
Sir 010-398 in my colour xerox machine model no 1632 plese give me solusation whats problem give me answer
010-398 Fuser Lock Failure RAP
Description
The Fuser Fan failed.
Power OFF/ON
Procedure
Turn on the power.
Visually check the rotation of the Fuser Fan
Feb 26, 2011 | Xerox DocuColor 1632 Laser Printer
Carrier model #58rav070-08 flashing error code #31
I would check the back of the unit to see if any debris has accumulated then check for the filter and make sure it is clean. Look at the front of the a/c where the filter sits and see if the coil behind the filter is dirty. If so the unit needes to be cleaned. This can be done by purchasing a can of coil cleaner at the hardware store and follow the directions to clean the coil. What the system is saying is there is a blockage somewhere causing this code. Not being serviced in 4 years would be the possible cause because of the amount of debris in the air over that 4 year period. Good luck on the repair hope this helped you.
Dave
Dec 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Struggling with Sky remote codes for new Samsung TV LE32A457
0060, 065, 584, 037, 245, 476, 398, 516, 292, 318,037
these are samsung codes for sky remote
good luck
Dec 29, 2008 | Televison & Video
Dryers Logo
Top Dryers Experts
