Question about Fisher and Paykel GWL11 Top Load Washer
My washer is leaking from the red fan under the washer,what should I do?
  • Fisher and P... Expert
  • 555 Answers
The red fan is the pump motor,
You will need a new pump as the pump is leaking.
Posted on Dec 15, 2013
How do i fix a leaking outside faucet (dont know how its called sorry)
Shut of the water supply to that faucett. Turn on the water at the outside faucet to release pressure. Now loosen the nut under the valve handle with a wrench. Remove the whole valve & stem. At the bottom you you should see a black or red rubber washer. It's held in place with one screw. Remove this washer. Over time this washer wears out. It is what stops the flow of water to the spiggot. You can either replace this washer with a new one from your supply store or you can buy some time by simply turning the washer to the other side. You should see signs of wear on the original side.
Jun 26, 2014 | Plumbing
Dishwasher is leaking, not sure how to disconnect drain hose
Undo the clamp where it hooks to the washer at the red elbow or normally undo the clamp under the sink where it hooks to the drain.You shoughd have two screws in the top front of washer. Take those out and washer should slide out.
Apr 08, 2013 | Dishwashers
Red fluid leak in maytag washer la712
Sounds like gear case oil. Dark Red? Did you tip the washer over?
Sep 03, 2012 | Maytag Washing Machines
I have a fisher and paykel washing machine.Its started leaking under the machine when its do the rinse.
The leak could be from:
  • the pump
  • one of the hoses that attaches to the pump system
It is likely to be the pump. However, to verify where the leak is coming from do the following:
  1. Make sure the washer is empty of excess water. (Run the Spin cycle, if not sure.)
  2. Unplug the washer.
  3. Turn off the hot and cold water supply taps.
  4. Disconnect the hot and cold water supply lines.
  5. Pull the washer away from the wall a couple feet.
  6. Have a helper tip the washer back toward the wall and hold it up securely for you!
  7. Get down on the floor with a flashlight and look up underneath the washer for the pump. It will have a small fan blade as well as wiring and water tubing going to it.
  8. If you see signs of rust or water drops on the pump, the pump impeller shaft seal is probably leaking. Order a new pump and install it. It takes no tools and about 20 minutes as follows...
  1. Get a roll of paper towels.
  2. Make sure the washer is empty as above.
  3. Unplug the washer.
  4. Turn off hot and cold taps.
  5. Disconnect hot and cold supply lines.
  6. Pull washer away from the wall a foot or two.
  7. Tip the washer back toward the wall.
  8. Have a strong, reliable helper hold the washer in that position -- firmly against the wall.
  9. Get down on the floor. Lie on your back and put your head and arm under the washer (that's why you need a good helper!).
  10. Unplug the electrical wiring to the pump. (The GWL11 has 2 wiring connectors.)
  11. Slide a shallow plastic dishpan under the pump to catch any water.
  12. Find and bend back slightly (don't break it!) the plastic retaining latch that holds the pump in place.
  13. Rotate the pump counter-clockwise about 60 degrees, until it comes free.
  14. Note the angle/position of the pump as you pull it free. This is the same angle/position you'll use when you put in the new one.
  15. Have your helper clean up any excess water that ran onto the floor.
  16. Install the new pump.
  17. Have your helper lower the washer to the floor.
  18. Reconnect the washer to the hot and cold water supplies.
  19. Open the hot and cold taps.
  20. Plug in the washer.
  21. Test the washer with no clothes in it.
BTW - Cleaning all dust out from under the washer a couple times a year should help prevent pump squealing and leaking in the future.
May 30, 2011 | Fisher Paykel EcoSmart GWL15
I unclogged the GD by removing the pipes underneath and replaced them tightly. GD seems to be working fine now, but water is slowly leaking from underneath the GD! It appears to be leaking from the...
The leak comes from above where water comes out.
Turn off power before touching wet electrical appliance.
Put stopper in disposal.
Fill sink with water.
Check if water is getting through the putty seal at sink connection.
Next, check if water leaks only when dishwasher runs. Dishwasher drains into garbage disposal.
Last, check tailpiece where it attaches to side of garbage disposal. The tailpiece is usually sealed with a rubber washer. When washer is old, it gets deformed, and then it doesn't seal perfectly when put back.
I use rectorseal on all tubular pipe joints under the sink.
Works on both plastic and rubber washers.
It is gooey and sticky.
Brush it all over the washer, use plenty, then assemble pipes.
The rectorseal assures that joint will not leak.
Oct 25, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Machine stops when gets to the spin cycle- last time was a hair clip stuck in pump. How do I get into the pump to get it out myself? Is a fisher and paykel smart drive about 9 yrs old.
Hi just read your posting.Is the machine draining any of the water?If it is not draining then bail some of the water out with a small bucket or pot, just enough so you can look under the machine without it leaking everywhere.Now when you are looking under the machine look to the front right and you will see a red or black fan.This is your pump.Turn the fan clockwise and anticlockwise a few times to loosen it if it is jammed.The fan should turn freely.If the pump turns freely then put the machine back on its feet and select a spin cycle and push start.The machine should now drain the water and then it will spin.Please reply on how you got on or if the machine still does not drain.Looking forward to your reply.
Jul 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
Washer is won't spin
Hi just read your posting.Now from the information in your posting the machine is not draining.Is this correct?Now what I need you to do is to 1st remove all the clothes from the machine and bail out the water by hand with a small pot or bucket.Only bail enough water so it does not leak out when you lean it back against the wall.Now I need you to look under the machine ,Hence the reason for bailing some of the water out, and tell if your pump is the type with a red or black fan attached to it.The pump is located under the machine to the front right.If you have this type of pump turn the fan with your hand clockwise a few times then anticlockwise a few times.This is to loosen it up if the pump is blocked.If the pump frees up and you can turn the fan easily then put the machine back upright and select a spin cycle and push the start button.Please reply and and tell me how you got on or if your pump is the one without the fan,also reply back if it does not drain and you require more help.
Jun 26, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel- GW11US model will not drain the water out at the rince cycle
Hi just read your posting.Now what I need you to do is to look under the machine to see what style of pump you have.They used 2 types of pump for your model.Before you look underneath the machine bail out some of the water by hand so when you tip the machine backwards and lean it against the wall the water wont leak out.Now when you look under the machine look to the front right of it and there should be a fan which is red or black in color.This is your pump.While you are looking under the machine and you can see this style of pump turn the fan a few times just in case it is jammed.If it turns freely put the machine back on its feet and select spin and see if it drains.Now if you have the pump with no fan or it does not start draining after you turn the fan please reply back and I can help you further.
Jun 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
Flashing f 13 and leaking from bottom
Hello,this is an error with most of the Branded Washers like Hotpoint etc,
F13 indicates High Dryer Temperature.
Check the dryer motor runs OK and that the fan isn't hanging off. (You'll hear it if it is).
Check the connections to the dryer NTC (temperature sensor on top of dryer)
Check the condenser isn't blocked (under the fan motor, plastic unit going down the rear of the tub).
If all checks out OK, try changing the dryer NTC.
Thanks
Jun 10, 2010 | Hotpoint Aquarius WD640 Front Load...
Temperature light is flashing red, coolant is
fan relay is under the frame on the left by the fans. but most likely the fans themselves have gone bad check the fuse panel on top of the battery see if it is burned or blown fuse this is caused by the fans going from stop to high speed to many times. you will flat 40 or 50 amp flat blade fuse and both fans sorry for bad news
Sep 01, 2009 | 2001 Volkswagen Beetle
Fisher and Paykel GWL11 Top Load Washer Logo
29 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
