Question about Electrical Supplies
Wenling jennfeng engines carburetor - Electrical Supplies
2 Suggested Answers
claudeinmo
  • 9098 Answers
SOURCE: I need a parts book for a wenling jennfeng 3800 generator
I have a cheap wenling Jennfeng 3800 generator someone ...
www.fixya.com/.../t25882221-cheap_wenling_jennfeng_3800_generato...
Sep 26, 2015 - I have a cheap wenling Jennfeng 3800 generator someone removed wiring from bridge rectifier i ... If you are replacing parts on the board please send photo. ... Snap-On book says the part number is BC4200-2000R but it.
wenling jennfeng industry 79 5cc generator parts Questions ...
www.fixya.com > Forum > Tags
Find solutions to your wenling jennfeng industry 79 5cc generator parts ... My 6.5 Hp Honda Clone 3800W Wenling Jengfeng 5WJFS.1961GA runs fine off ... Bank Swift Codes I need the swift code for Bank of China Wenling Sub Branch Hi there, don't know if you speak Chinese, but here is a list of swift codes for branches of ...
jennfeng generator parts Unsolved Problems - Fixya
Posted on Dec 08, 2015
I have a 5000w generator #5wjfs.3892ga.em. It is a wenling jennfeng I need a carburetor
All contacts for this Chinese company seem to have closed down. I can only find spares here, including carburettor (with two t's :) It does however say the part is not available.
Troy Bilt nbsp753 05005 JENN FING 29CC ENGINE nbsp29cc Jenn Feng Engine
Dec 10, 2016 | Electrical Supplies
3000 wat gen 6wjfs muffler,
Wenling Jennfeng makes that unit. It Chinese. Honda parts should fit that engine. You may want to take the old one off, do a thread count and pipe size and see what it takes. It is going to be metric.
Jun 27, 2016 | Cars & Trucks
Dec 08, 2015 | Electrical Supplies
Wenling jennfeng generator governor not working, linkage ok, speed ran away while in use
that doesn't make sense , surely it has a governor how else can the carby rpm be governed , sounds to me like the internal governor thrust counter weight has come out of it's locking plates. if governor arm has been adjust wrong way or moved from it's original position this will happen .
Mar 28, 2014 | Electrical Supplies
Bank Swift Codes
Hi there, don't know if you speak Chinese, but here is a list of swift codes for branches of the Bank of China. I didn't see one for Wenling, but this is all of the branches: http://wiki.answers.com/Q/Is_Bank_of_China_a_member_of_SW
Hope this helps, here is the Bank of China website also: http://www.boc.cn/en/common/third.jsp?category=ROOT>en>Information+Center>BOC+Network>Domestic+Branches
Feb 11, 2010 | Computers & Internet
Clone honda 6.5HP engine
hi
valve clearance(cold0
intake 0.005to0.007inch
exhaust0.007to0.009inch
byesavumihai71
Sep 12, 2009 | Electrical Supplies
I have a John Deere Riding lawn mower which starts
Hello roobar2009:
>>From your Description it Sounds like a Carburetor Problem, a Bad Fuel Filter or Bad Gas.
>>If you have Changed the Filter and the Gas and the Problem is Still happening, then
>>The Following is a Simple Way to make Sure the Engine is Getting Gas from the Carburetor to Run.
>>If the Engine Starts and Quits, then Check the Carburetor Solenoid.
>>If the Carburetor Solenoid is Good or has been Removed and the Engine will Start and Quit when the Gas is Poured into the Carburetor Throat, then Soak and Clean the Carburetor.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 17, 2009 | Garden
McCulloch 11HP FG6000MK surging
it sounds like the govener screw needs to be adjusted by turning it clockwise and then you may have to tweek the throttle screw. hopefully that will take care of it.
Sep 19, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Electrical Supplies Logo
54 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
