Question about GE VG4052 VCR
Sudden eject of the tape
My VCR ejects the tape as soon as I push it in. It takes a few seconds, and then ejects the cassette. I think could be the Sensors or something like that. Would you explaing about the problem and the possible solution? I´m not expert but I use to fix all my appliances.
    Brigadier General:
  • 6,966 Answers
Hi, This sounds like a mechanical problem. The tape is not fully extended over the video head or the two arms spreading the tape over the path is not fully extending. This is normally caused by a small belt slipping. The belt couples a small motor (near the right side of the head) and a pulley/gear combo that drives the spreading arm along its path taking the tape with it. It's a tight squeeze but if you can manage to extract the belt and replace it, then this should do the trick. Hope this be of some help/idea. Post back how things are or should you need additional information. good luck and kind regards.
Posted on Aug 31, 2007
Vcr ejects after 10 seconds
The tape is wound tight or is not wound evenly creating friction. There is a safety feature designed into the vcr that senses that there is too much tension. Fast forward all the way then rewind all the way. This is the way it was in the 70's 80's for cassette tapes and vhs tapes. If the tape still ejects then check the belts.
Dec 01, 2013 | Toshiba DVR620 DVD Recorder/VCR
Panasonic SQPB will not load cassette
I rather suspect some damage has occured inside the VCR. You should look for plastic parts that are broken.
Nov 20, 2012 | Panasonic Televison & Video
Tape loaded normally but now won't eject. The unit just powers off after a few seconds.
Unplug the power from the combo unit and give it 30 seconds, now plug back in, sometimes this will eject the tape, if not! take the top off the machine and check to see if the tape is spewed in the mechanical section and around the video head, if yes! get a pair of scissors and cut the tape carefully to avoid damaging the video head and remove all tape deb-ri, now power up and eject the main cassette. But! if you find the cassette has loaded in place and the tape is still in the vhs cassette, this would indicate a loading problem with the main carriage, broken belt, bad idler assembly and possibly sensor issues.
Feb 06, 2011 | Sony SLV-D350P DVD Player/VCR
Vcr will not play tapes,it ejects the tape after a few seconds
This may be caused by the mode switch.
By the way it uses a K-Deck Mechanism.
Sep 11, 2009 | Televison & Video
VCR ejecting my cassettes
Try removing the top cover & have a look to see what happens when you put the tape in & press play/rewind etc. Is the take up spool (right hand spool) turning properly or is there slack tape not being taken into the cassette? Are the heads spinning ? I think your problem is more likely to do with the tape not travelling smoothly around the tape path. Possibly the clutch gears need cleaned or the soft brakes may not be dis-engaging properly.
Jul 19, 2009 | Televison & Video
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
CASSETTE STUCK IN VCR WONT EJECT I TURN VCR ON IT STAYS
When the tape has been removed the carriage deck will still be in the wrong position. The cassette tray has to be aligned so that the timing of the tape will detect that there is a tape in the machine. At the moment your VCR thinks there is a tape still in it because the cassette tray is not in the full eject position. This can be fixed by a service technician.
Mar 26, 2009 | Emerson EWV401 S-VHS VCR
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
VCR ejects blank tape only
It sounds like the cassette is not releasing the tape so the machine can put it around the heads. This could damage the machine. Don't use it. A two dollar tape is not worth damaging your vcr. Throw it away.
Oct 09, 2008 | GE Televison & Video
Cassette stuck in VCR
You are almost on the right track. did you look where your finger was? what happened was you did not allow the blocking a photo sensor which mimicked the clear part of the tape and this caused the eject to take place. What was happening in your case was the arm would come fully out and the sensor would sense no tape so the VCR shut off in a trouble condition to prevent damage from ocurrin.
Oct 28, 2006 | GPX TVR950 VCR
GE VG4052 VCR Logo
64 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
