Question about Scotts Company Scotts& Accugreeen 2000 Drop Spreader 3 Pack
Handle assembly with micrometer housing broken
How do I remove the LCD Housing from the Handle Assembly
The lcd and housing should have been removed from the previous handle...if you have thrown them away then you will have to order the new parts.
May 16, 2017 | Fisher & Paykel DD24DCTB6 Double Tall...
How do i find the millionth of a inch on specs in the govenor assembly on my 1972 yamaha 125
I think you have misread the spec. A millionth of an inch is not something that you can measure using normal micrometers, vernier's, feeler gauges etc. If you take an inch as 1 then a millionth is 0.000001 inches. If you have seen the word mil in the spec this actually equals 1 thousandth of an inch or 0.001 inches which is more likely. Example 5 mil = 0.005 inches, micrometers, verniers and feeler gauges can all be used to measure this dimension.
Dec 26, 2014 | Yamaha Motorcycles
Broken pull cord
How to replace a broken pull cord on a leaf blower.
1) Remove Hex bolts holding plastic leaf blower housing in place with your hex wrench. you may want to cut the cord with scissors and loosen the bolt or screw securing the rope assemble with hex wrench or screwdriver.
2) Remove spring assembly Carefully. (DO NOT REMOVE THE SPRING ONLY REMOVE THE ASSEMBLY)
3) Remove old cord. Notice the direction the pull cord is wound. This is important in the following step
4) Wind new pull cord in the same direction you removed it, as in step 3, Make sure cord secures in the slot provided on pull and assembly.
5) Replace the pull cord pulley and place over spring.(This is the white plastic spool.)
6) Rotate the pull cord assembly 2 or 3 times in the same direction the cord pulls. (wearing safety goggles and work gloves) Reinsert the center screw by securing in in place with your screwdriver.
7) Insert the leaf blower cord into the end of the handle opening. Secure the handle by tying a knot at the bottom of the new cord.
8) Place the pull cord assembly back onto your blower in its designated area then secure by refastening the 4 hex nuts.
9) Replace the housing cover of blower and refasten the hex nuts.(the housing you removed in step 1.)
I hope this was some help to you. Good luck.
Jul 01, 2012 | Homelite Consumer Products Backpack...
Broken plastic opener handle just above micrometer dial
I'm sorry to hear about the problem you are having with your AccuGreen spreader. Sometimes we have replacement parts for our spreaders. Please give Scotts a call at 1-800-543-8873 at your earliest convenience to check part availability. Hilary @Scotts
Jul 07, 2011 | Scotts 73730 AccuGreen 3000 Deluxe Drop...
How do i calibrate my speedygreen 2000 broadcast spreader
You may check the calibration by using the following directions. First, adjust your micrometer setting to 2. Squeeze the trigger against the handle. The calibration line is a small, raised line embossed on the top of the spreader's shut-off plate. With the micrometer set at 2 and the trigger squeezed against the handle, the calibration line should be aligned with the back edge of the hopper opening.
To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel. Adjust the screw until the calibration line and back edge of the hopper meet. If you have any difficulty checking the calibration, contact us and we will be happy to help walk you through the adjustment.
When you are not pulling on the trigger handle, the cable should be loose. When you pull on the handle, the cable becomes taut and the shutoff plate slides open.
If you need further assistance feel free to contact us @ 1-800-543-8873
Jan 24, 2011 | Scotts Company Scotts& Accugreeen 2000...
How do i calibrate the scotts speedygreen 2000
Your SpeedyGreen 2000 Rotary Spreader spreader was calibrated at the factory. However, a spreader's calibration may change or slip during periods of frequent or heavy use.
If you have any additional questions feel free to contact Scotts directly @ 1-800-543-8873
Jan 24, 2011 | Scotts Company Garden
How do i calibrate the accu green 3000
According to Scott's:
To adjust calibration, do the following: Adjust the micrometer setting to 6. Flip spreader over. Use your foot to squeeze the trigger against the handle. The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper. To adust alighment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insert.
Sep 18, 2010 | Scotts Company Scotts& Accugreeen 3000...
The 4 wheel drive shifter is broken. How does the linkage to the transfer case come apart?
Shift Lever NOTE: Remove the shift ball only if the shift ball, boot or lever (7E067) is being replaced.
Removal
  1. Raise vehicle on hoist and position suitable safety stands under vehicle.
  1. Prior to removing the control lever assembly (7E069), be sure the shifter is in the 2H position.
  1. Loosen (do not remove) the nut retaining the shift handle (7E067) to the control lever assembly (7E069). Remove the shift handle (7E067) from the control lever assembly (7E069).
  1. Remove the vent hose (7D494) from the notch in the detent plate.
  1. Remove the control rod (7A315) from the control lever assembly (7E069). ani_caut.gif CAUTION: When removing the control rod (7A315) off the control lever assembly (7E069), do so very gently so as not to damage the control lever assembly.
  1. Loosen (do not remove) the large pivot bolt holding the control lever assembly (7E069) to the detent plate.
  1. Swing the control lever assembly (7E069) out of the way and remove the two bolts (39129-S2) retaining the detent plate to the transmission extension housing. Remove the entire control lever assembly from the vehicle.
Installation
  1. Prior to installing the control lever assembly, be sure the transfer case link (7B106) is in the 2H position (pointing upward).
  1. Install the two bolts (39129-S2) to retain the control lever assembly (7E069) to the transmission extension housing and tighten to 92-125 Nm (68-92 ft-lb). Refer to the following illustration for bolt hole application.
  1. Attach the control rod (7A315) to the control lever assembly (7E069).
  1. Tighten the large pivot bolt to 92-125 Nm (68-92 ft-lb).
  1. Attach the vent hose (7D494) into the notch in the detent plate so the white mark is flush to the outside surface of the plate.
  1. Install the shift handle (7E067) into the control lever assembly (7E069). Tighten the retaining nut to 27-38 Nm (20-28 ft-lb).
  1. Check transfer case for proper shifting and operation.
Feb 27, 2010 | 1992 Ford F250
My cable to open my hood is broken now my hood will not open its a 1994 honda civic.
you might have enough cable to catch a hold of with pliers if you remove the cable handle assemble from dash,if not cut away at cable housing until you do
Nov 19, 2009 | 1994 Honda Civic
I have a Republic EZ drop fertilizer spreader. The gray plastic device (2 pieces, one screwed inside the other) up by the push handle that rotates to widen or narrow the slot at the bottom of the...
I have a Republic EZ drop fertilizer spreader. The gray plastic device (2 pieces, one screwed inside the other) up by the push handle that rotates to widen or narrow the slot at the bottom of the fertilizer storage bin when the handle is squeezed is broken. The cable connecting the device to the movable part of the slot is OK. The gray plastic has numbers on it that show through a small square opening in the gray plastic closest to the push handle. Where can I get a replacement part?
May 11, 2009 | Garden
Scotts Company Scotts& Accugreeen 2000 Drop Spreader  3 Pack Logo
60 people viewed this question
Top Scotts Company Garden Experts
john h
Nick Olsen
lnbn1975
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
