Printer will not print referring me to chapter 10 of the user's manual of which i do not have? trouble shooting and routine maintenance
What error does the display show up exactly?
Hi there. . . okay . . . Follow this step 1.) Unplug your printer. 2.) Plug your printer again while holding the menu button 15 sec. 3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK 4.) then numbers appear looks like this ###:### ###:###. 5.) now push the MONO button until the purge:#### appears on the LCD 6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok 7.) - switch off the printer ,switch it on - ready to print - CHEERS! email me if I helped you. . [email protected]
dumbie123
the same problem. we can't print referring to see the trouble shooting in user guide.
my printer says "see troubleshooting and routine maintenance Chapter 10 User's guide: Unable 51"
I own a MFC 420CN Brother printer ever since we bought this printer and installed the ink cartridges the yellow cartridges always shows that it is low or almost empty when in fact it is a new ink cartridge, need to know how to solve this problem. Now the printer is saying"Unable to print - See Troubleshooting and routine maintenance chapter in User's guide, I do not have a manuel can you help with this also?
it doesn't clean
printer will not print referring me to chapter 10 of the user's manual of which i do not have? trouble shooting and routine maintenance
Brother MFC 3240 printing issue...i get the following message....unable to print see trouble shooting and maintenance in user guide
showing on my printer
Printer Unable 36
Then says trouble shooting and maintenance
need a manual so i ca trouble shoot a problem im having.
trouble shooting and maintenance chapter
