Hkc monitors how to use monitor buttons/colour/ britness /contrast
SOURCE: Samsung 220wm monitor brightness and contrast adjustment
umm... you are NOT supposed to use mouse !!
These are on-screen displays and you can use the other buttons (up down and select) to navigate through and then to change the values !
Posted on Feb 23, 2008
SOURCE: Unable to adjust contrast
http://support.dell.com/support/edocs/monitors/r83546/EN/setup.htm#Using the OSD
"NOTE: When using DVI source, the contrast adjustment is not available"
Posted on Oct 07, 2008
Benimur
  • 6966 Answers
SOURCE: monitor display
Appreciate the direct "Ask Me"
Unfortunately, an HCL HCM782M monitor is an unknown model. However, on similar instances and occurrence of this problem, it would seem that the controls are damp. Specifically, it would be the internal contacts of the buttons. Pls check if you can dis-assemble, remove the board/control/buttons and perform cleaning. Pls pay particular attention to the rubber pads or the small buttons themselves. if I may ask, any recent continuous rain? If yes, this may have contributed or caused your problem.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 16, 2008
SOURCE: i have the SAMTRON 56 V 14" COLOUR MONITOR .
change the eprom (A41dDC) after connect pc then switch on monitor
sushil91077rajbanshi@rediffmail.com
Posted on Nov 22, 2008
SOURCE: Dell 15 inch monitor, brightness/contrast window
Press and hold the + button, You will get a message that the monitor is going into auto adjust. After that problem solved.
Posted on Jan 19, 2009
Britness and contrast automatically going up and downs , and menu button not workling
Is it a HCL Monitor? ...................................
Go near reparer........................
No other solution.
Feb 26, 2011 | Compaq Computers & Internet
Adjust monitor
hi, most monitors have between 4 buttons or 8 to udjust picture. the 4 button MENU, PLUS, MINUS, OFF. when the menu button is pushed the screen will show a list of COLOUR, BRIGHTNESS, CONTRAST, etc,etc the plus is pressed to change the COLOUR, BRIGHTNESS, etc,etc. if you need to change the SCREEN setting BECAUSE THE ICONS ARE TOO BIG click on START go up list to CONTROL PANEL go to DISPLAY click on this and go to SETTINGS click on this and on the left. change to 1024 by 768 SCREEN SIZE (COLOUR 256). press APPLY wait press OK. gerry
Sep 10, 2010 | Envision EN 9110 19" Flat Panel LCD...
Osd problem
Try turning the power off, press down the contrast and britness setting bottons and turn the monitor back on and release the buttons.
Next if that dosent work try holding the menu button down until you get osd unlocked come up.
Hope this helps.
Feb 04, 2010 | HP w1907 LCD Monitor
Contrast on my acer monitor is bad how do you adjust it
You can use the monitor's own settings, but that doesn't work very well. I just bought an Acer V233H monitor myself, and I am very disappointed about the quality of contrast and color.
However, I have NVIDIA video card, which comes with software that you can use to adjust gamma, colors, contrast etc. That worked better for me. Still not perfect, but better than the monitor's own settings.
Oct 15, 2009 | Acer 19" LCD Monitor
Blacks have changed to blue on my PC Monitor
Can you check your monitor's device settings (on physical buttons on the monitor) and check for changes to the Hue or contrast setting(s)?
It sounds as if the hue or contrast has been adjusted slightly, just enough to be visible.
May 24, 2009 | Acer AL2416W Monitor
Need help to adjust the colour, contrast and brightness on my CMV
install the monitor driver, you can down load the driver to your monitor manufacturer..
update the video card driver and install the video card application software...the video card application software have setting and configuration options
Mar 16, 2009 | E-Machines eMachines Monitor E15T4
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
Mar 12, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Bright screen with very low contrast
I fixed it myself, it seems that the monitor have some problems remembering it's settings and sometimes it automatically set its settings to crazy values that are out of the range that we are allowed to input. For my case, the setting that was crazy was the gamma setting since it was set so high. I wasn't able to bring it back to a normal setting so I found a way to do it by resetting the monitor. So to reset these display settings such as colour, contrast, brightness and gama, you need to turn on the monitor and unplug the monitor without turning it off and plug it back in again. It will automatically power on and the correct default settings will be present.
This forum isn't very helpful is it?
Dec 09, 2007 | LG Flatron L1811S 18.1" LCD Monitor
Not enough contrast \ user mode?
You can reset it back to factory settings with the auto reset button selection or in that menu switch from advanced.
randy329sgi
Oct 15, 2007 | Compaq CV 7500 17" CRT Monitor
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
