Question about Food Mixers
HUSKY CEMENT MIXER GHM105890 WIRING SCMATIC - Food Mixers
I have bottom part of older portable cement mixer trying to find name/model number so we can get the top part. How can I submit photos to see if anyone recognizes it? Pot to be removed.
Google images has a way to search for similar images on the internet. If you put your picture on the internet, for example, on your own Facebook or other page, there is a way to search.
However, you have placed your question in the Food Mixers category. Is it a portable cement mixer or something else, perhaps spelled differently?
Feb 24, 2018 | Food Mixers
Cement Mixer won't run or start
Is there power in the wall socket. Check with a lamp?
Does the motor get warm when plugged in for a while?
Does the motor have a starting capacitor? Look for a metal tube on the side an inch or so in diameter. Those are AC electrolytic capacitors that are a common failure item.
Apr 18, 2016 | Food Mixers
Left my honda petrol cement mixer upside down and now it won't start. How to I get it to work again?
There is probably oil in the cylinder. Remove spark plug drain oil and fuel and get carb cleaner spray in to cylinder wait five mins and empty out. Refill crank case with oil and clean spark plug. Fill gas tank note it might smoke for about 10 to 15 mins as it burns off remaining oil.
Nov 02, 2014 | Food Mixers
MY MINI MIX CEMENT MIXER IS BROKE DRUM WILL NOT TURN WHEN LOADED
This is the food mixer forum, not much cement gets mixed in the kitchen around here, too much danger of a flying rolling pin.
Sep 06, 2014 | Food Mixers
My kitchenaid mixer run on high at all times
If your mixer only runs on high speed there are 3 things that can cause that. The first thing to check will be the speed control plate, Remove the trim and end cover on the mixer, the first thing you should see is the speed control plate, this has 3 screws on it, try adjusting the top two screws 1/4 turn, this should slow the mixer down, do not over tighten. Also check to see if the control plate spring is unhooked. If the spring is unhooked, attach to bottom of the control plate, and squeeze the spring end.
If this does not fix your mixer, check the wiring of the mixer, you can locate a wiring diagram on the last page of the service manual.
If the speed control plate is adjusted correctly and all the wiring is correct it will be your speed control phase board. You can test the speed control phase board to see if it is shorted. With the line cord disconnected, pull the t-b ar contacts to open, and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run. If it operates at full speed, teh phase control board is defective and needs to be replaced.
Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
This will aid you in taking the mixer apart, troubleshooting and putting it back together, remember the wiring diagram is the very last page.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Jan 07, 2013 | KitchenAid K5SS Mixer Speed Control Plate...
Is my mixer internally short circuited? How to remedy?
It sounds like your mixer has a bad ground connection. Sorry electrical is not my forte, but something in the mixer wiring is the problem, not the wall outlet..
Dec 12, 2012 | KitchenAid KSM90 Ultra Power Series Stand...
Wiring diagram for a Hobart D340 40qt mixer
i read in the manual that the wiring diagram is located on the inside of the top cover. check it out..
good luck
Oct 08, 2009 | Hobart D340-6009 Mixer
A - 200 3 speed mixer needs a wiring diaram
how do you know diagram is wrong , you could have wired it wrong the timer kit i belive comes with 3 or 4 different diagrams for that mixer you need to pick the right one
Aug 27, 2009 | Hobart A200 Stand Mixer
West bend stand mixer # 41039 dial won't turn
If the mixer does not work on all speeds, then check motor wiring and control board.
If the mixer is less than one year old call manufacturer at the number listed on the owners manual.
To get parts for your mixer you can contact West Bend Appliance Parts - Bettervac 1-800-675-9491
Dec 08, 2008 | West Bend 41125 Hand/Stand Mixer
NEED A WIRING DIAGRAM FOR A A200 HOBART MIXER
I had a look on google and came up with a service manual. not sure if this has the wiring diagram but the only other thing i can suggest is to contact te manufacturer direct. Go to http://cgi.ebay.com/HOBART-A200-20-QUART-MIXER-SERVICE-PARTS-MANUAL_W0QQitemZ160203114233QQcmdZViewItem
hope this helps.
Feb 02, 2008 | Hobart A200 Stand Mixer
Food Mixers Logo
106 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
