Question about Music
Yamaha electone hs7t
My yamaha electone organ hs-7t have a only buzzing sound, how can it be fixed ?
pianokey54
SOURCE: I have a yamaha electone hs4, The foot pedals do not work.
JM: Your problem is this: There are rubber washerson the bolt that holds the pedal on. They are shot. Most likely Yamaha doesnot have the parts.Go to the plumbing dept of a hardware store and get some faucet washers and replace them. YYou can tell if the washers are shot by tiping over the organ and looking at the pivot bolt. Most likely that is yoiur problem. I am an organ tech. and have replaced many of these. DM
Posted on Mar 16, 2009
  • 5603 Answers
SOURCE: yamaha electone organ no sound-
Check if you may have knocked off the speaker leads OR ones to an expression pedal.
Posted on Sep 22, 2009
  • 5603 Answers
SOURCE: no sound from Yamaha Electone HS-6
First check if you get sound from the headphone jack.
Do you hear anything as the power comes on from the speakers..? A slight bump?
A lot of these dead audio things can be traced to a failure at the expression pedal. often these use a light dependent resistor and the illuminating lamp burns out. This is all down by the pedal.
Many of the Yamaha organs, including the FX20 I have, have circuitry that checks that the power amp has DC balance before a relay closes to connect the speaker. A failure in the amp can cause dead sound as well.
Posted on Jan 12, 2010
  • 5603 Answers
SOURCE: Model C-60 Yamaha organ. Loud hissing sound
This is likely in the power amp or the drivers for it.
The key to troubleshooting is a schematic. Try to procure one.
You MIGHT try using circuit cooler in the area of the power amps to isolate a bad component or cracked circuit board.
Posted on Mar 10, 2010
  • 5603 Answers
SOURCE: I need the service manual or schematic for a
Go to the electone forum at electone.com and ask there.
Also the organ forum
http://organforum.com/forums/forumdisplay.php
When there, go into the home organ section.
Posted on Sep 20, 2010
Hi,is it possible to upgrade the rhythm's and backing on an Electone HS organs/or similar. Thank you Chris
Chris, most likely yes, depending on the actual model. Best to contact Yamaha directly. Here's the link-
Contact Us Support Yamaha United States
Mar 07, 2017 | The Music
I have a Yamaha Electone HS-6 which for some reason won't power on anymore.. is there somewhere I can look at to get it fixed? where should I be looking at fixing this? Fuse? power box maybe?
Yamaha has a service locator at http://usa.yamaha.com/dealers/service_locator/ I ran it and it came up with the exact place local to me I would have taken it to. I know their reputation and have had service done by them before with excellent results. Your organ's a pretty complex unit, so if I were you, I'd take it to a Yamaha recommended facility, after checking with Yelp.
Jan 12, 2015 | Yamaha Music
Organ repair
Yamaha electone organ have no sound el 25 need help thnks...
Sep 03, 2013 | Yamaha Music
Yamaha Electone HS-4 doesn't remember settings
checked the internet and it states in the manual that if you do not use the organ for long time the user memory will be lost but the factory memeory will not be affected. check the below link:-
http://archive.org/stream/YamahaElectoneHsUsersGuide/YamahaHsUsersGuide_djvu.txt
Aug 30, 2012 | Music
I need the service manual or schematic for a Yamaha D-60 Electone Organ. Any help?
Sep 19, 2010 | Yamaha Music
No sound from Yamaha Electone HS-6
Jan 12, 2010 | Yamaha Music
Yamaha electone organ no sound-
Sep 16, 2009 | Boss Micro BR Digital Recorder
Hi, Yamaha Electone HS-4 NO SOUND
j have had the some problem on hs 7 . The relè not work probably you have a cold o breaked joint on power amplify integrate or it is broken.
Jul 18, 2009 | Yamaha Full-Size Keyboard
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
