Question about Ricoh Multifunctional SP 3200SF Network-Ready Black & White Laser Printer
Aficio sp 3200 sf
Gives a msg. DOOR OPEN. Won't perform any functions.
4 Suggested Answers
  • 11 Answers
SOURCE: color bad on ricoh aficio sp c210 sf
Hi There,
print out a page from windows paint program of cyan, magenta, and yellow. see which colors are incorrect. that will help you get closer to the problem area.
the drum also may not be screwed in all the way. remove it, and try putting it back in again.
Posted on Dec 20, 2008
  • 903 Answers
SOURCE: ricoh aficio sp 3200sf fuser door open error
There is a black sensor that detects when the fuser door is closed, and an actuator that the sensor either sees or doesn't see. If this sensor is dirty, it might not be seeing the actuator. It could also be broken or knocked out of place.
Locate the actuator on the side door (a small metal or plastic tab that sticks out from the door) and find the corresponding sensor. Make sure the sensor is in place and not broken or moved, and make sure it's connector is well-seated. If you have a can of compressed air, blow it into the sensor to clear away any dust or dirt.
Posted on Jun 19, 2010
  • 121 Answers
SOURCE: I have Printer and Scanner
Hi Mach,
Click on the download link below to goto the driver and software download page of Ricoh.
Download Link
E.g : If I want the printer/scan/fax driver for windows 7, I will click on the download icon under Windows 7 as shown in the image.
shreysri_7.png Regards,
Shrey
Posted on Jun 02, 2011
How to clear toner alert
open the front door and close again, wait for toner to load.
if this problem persist,open the front door and remove toner unit,use a flat screw driver to press on the door sensor and check if the toner motor is working properly.
if the motor is in good condtion,service the toner unit and make sure that the unit is toner free and insert new toner.
if this condition persist, enter the sp mode and clear all memory by sp 5801 for mp5ooo, aficio 1035-4545,645,2035,2045,235,735 or sp801 for 1022,1027,1505 and restart the machine.
for aficio 1035-4545,645,2035,2045,235,73 enter sp21093 and 21094 mode before making a copyor else the error sc329 will appear.
good luck
Apr 04, 2014 | Ricoh Aficio MP3350
Risoh aficio sp 3510 sf
my printer richo sf 3510 sir. my problem replace required soon print cartridge show on the display
Feb 19, 2013 | Ricoh Office Equipment & Supplies
I need a replacement part for Aficio SP C 222 SF - It is the black plastic piece that is approx 12 inches long that has "teeth" hanging down to guide paper through the machine. It has...
I'n not quite sure what part you mean, as there is no picture included. If it is the one, connected to the "door" you open in front of the machine, the part number is G166 3923 Exit Guide Plate - Middle.
ricoh sp c222 gif-2rhlv5r3sdqqpeuzs0ozcjtp-5-2.gif The part I'm thinking of is marked as number 8.
Jul 13, 2017 | Ricoh Aficio SP C222SF All-In-One Laser...
Ricoh aficio sp-1100 sf toner chip reset problem
WE HAVE RICOH PRINTER SP 1100SF & REPLACED CARTRIDGE WITH NEW RECYCLED BLACK TONNER CARTRIDGE FROM POWER POINT, BUT UNABLE TO PRINT AS CHIP GIVEN IS NOT ACCEPTED BY PRINTER. TRIED 3 DIFFERENT CHIPS STILL PROBLEM PERSISTS. WHAT MAY BE THE RESEASON AND SOLUTION
Nov 30, 2010 | Ricoh Aficio SP-C210SF Printer
Gives code sc541 on Ricoh 1035
Clean the fuser thermistors.For reset enter in the service mode : press total clear (yellow)key-107-clear(red)key,touch SP mode,open the front door and turn OFF the power switch.Unplugged the machine,wait 10 sec.,plugged the cords,close the front door amd turn ON the power switch.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
Ricoh Aficio SP C210 error message
Try loading letter size paper in tray1 .. Open the front door and the assembly attached to the front door is the transfer roller ASM. mybe you knocked it out of position ..There are green plastic clips that allow someone to the transfer roller unit so its easy to mess up good luck
Apr 20, 2009 | Ricoh Aficio SP C210 Laser Printer
Ricoh aficio sp c210 sf is printing with a black line on the right side of each page when used as a printer or copier.
you are having a drum or fuser issue, to find problem you will need to attempt to make copy and as paper passes the drum you need to open door and remove paper,if line can be rubbed away then it is drum if it cant then the fuser is problem
Apr 17, 2009 | Office Equipment & Supplies
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
Ricoh Multifunctional SP 3200SF Network-Ready Black & White Laser Printer Logo
61 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
