Question about Pool & Spa
DREAM MAKER SPA WATERFALL VALVE
FOR SOME REASON THE CONTROL VALVE (NOT THE JET AIR CONTROL BUT THE WATERFALL FLOW CONTROL)POPPED OUT AND I CANNOT FIGURE OUT HOW TO MAKE IT STAY IN. NO MATTER WHAT I HAVE TRIED, WHEN THE SPA IS TURNED ON THE VALVE FLIES OFF AND WATER GUSHES OUT THE PORT............
The threaded cap the holds the waterfall valve in place is most likely cracked so you will just need a new valve. Send me a picture of it and I can see if I can locate one for you.
Posted on Jun 08, 2014
SOURCE: how do you replace jets on dream maker spa X-500
There is a tool that comes with the spa, instructions are in the owners manual. If you don't have the manual you can download it here
http://www.dreammakerspas.com/_PDFs/0607l.pdf
If you don't have the tool you can order one from Dream Maker.
Posted on Nov 04, 2009
  • 12744 Answers
SOURCE: my dream maker spa does not work. there is
open control panel will see a small glass fuse replace if blown if 220 volt check that getting power on both lines
Ian  Hot Tub
  • 77 Answers
SOURCE: Dream Maker spa - does my dream maker spa 4 person
Depending upon the age, the Dream Maker has a digital thermostat which is easy to change but to be honest I don't think that is the cause of your problem.
Check the keypad connection on the PCB (circuit board).
t could be either the keypad or PCB at fault and withou trying one or the other you'll not be able to determine the problem. My advise would be for you to contact your local parts supplier and ask them whether or not they can supply you a keypad to try with the option to send it back for a refund if it doesn't cure the problem.
A keypad can be trial fitted to the PCB, just unplug the old one, plug the new one in and turn on the power. There's no need to install the keypad to the spa, therefore you wont damage it in anyway.
If the keypad doesn't cure the problem, change the PCB.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 01, 2010
Ian  Hot Tub
  • 77 Answers
SOURCE: Easy spa round - dream maker - overheat sensor is
Assuming that you've got adequate water flow, clean/new filter and the pump works as it should; Try a new sensor. They can and do sometimes fail and the sensor is much cheaper than the PCB. ;)
Cheers,
Ian, from: http://hottub.synthasite.com
Posted on Jun 18, 2010
SOURCE: I have a Dream Maker x-spa Dition 4 person spa. i
hi i am having the same problem have you managed to fix it and how any help would be much appreciated thanks joe joeathome2009@hotmail.com
Posted on Aug 06, 2010
Replace waterfall in hot spa
possible bad relay for waterfall or pump to waterfall
Feb 05, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
My dream maker big eze hot tub the jet light on the upper control panel just keeps blinking what does that mean
Are the jets coming on when you press the button?
Try unplug the control from the board and plug it back in.
Dec 01, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Will a flow switch stop the tub of any operation
Is the board getting power, is the control lighting up?
Do you see any error codes on the top side control?
Improper flow will give you an error code, caused by flow issues or a faulty flow switch. Make sure all gate valves are open and the water can flow freely.
If not then check your Hi Limit sensor. This is the overheat safety sensor if it fails the tub will not function at all.
Sep 23, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Air trap,,,,,,how do u bleed it,,,,,,location of bleeding screw
With the spa full you will just open the drain valve for a few seconds and that should purge all the air from the system.
Aug 13, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
We are getting the error message of NON FUNCTIONAL HIGH TEMP SENSOR. Does anyone know how to fix this on the Dream Maker Spa B6L series?
Not much to go on but try opening the drain valve for a few seconds. If you have an air lock this give you a high temp code. When you open the drain it will break the air lock and start it pumping again.
Nov 27, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Have a dreamaker X-500 Only get air on one side out of my jets. Steve
Either an air line has become disconnected, or the air valve on the spa is clogged/broke.
If this is a blower model and not a venturi tee air injection system, the lines on the one side probably blew off.
Nov 14, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
No jet flow hot springs highlife 1990
you might have an air lock, when you first start filling the spa, start the water running in the skimmer first. that should force air out of the pump and should pick up prime right away. if not, you may have a valve problem.
Mar 30, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool & Spa Logo
232 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
