Question about Egis Technology EgisTec Shredder
Egistec shredder activation code - Egis Technology EgisTec Shredder
Shredder will not work in automatic mode
There might be a tiny scrap of paper blocking the sensor, which will keep the motor running.
Dec 06, 2016 | Shredder Office Equipment & Supplies
Unit will not stop
Dear Hal,
Here is some generic information about shredders that may help you.
Most of the shredders have a micro switch that "senses" if the paper has been introduced to the shredding slot. These micro switches are activated by a little arm/leveler that touches the paper and activates de contact inside the shredder housing. Also, note that some shredders may have an optical sensor that may be "clogged" with paper dust.
If you shredder does not stop, the sensor may be stuck in a on position, or, in case it has optical sensor may be detecting dust or a little piece of paper may be blocking the optical sensor and keeping the motor running.
I hope this gives you some light in further investigating your problem.
RC
Apr 14, 2014 | Office Equipment & Supplies
Omnitech shredder ot-nxc18pa won't power up
Dear Bruce,
Most of the shredders have a micro switch that senses if the paper has been introduced to the shredding slot.
While disconnected from the power, try to check if the switch is working properly. Check if you can hear a "click noise" while moving it back and forth by using a paper clip. When this sensor arm is broken, the device will not operate since it does not detect the presence of a paper sheet to be shredded.
Make sure your power is on (not only connected to the wall - but check if there is any indicator in the shredder). If the arm is not broken and you still hear the click noise indicating the micro switch is being activated, then your problem could still be the power since there is not LED indicator in the panel of this device.
If this does not solve your investigation process, please make sure your power cord is fine. Otherwise, it would be an internal electric problem in the device.
One additional possibility (since I have no further details from you) is that the device is on, you can hear the motor running but the gears that move the shredder blades are broken (that has happened to my device).
RC
Mar 22, 2014 | Omnitech 10-Sheet Micro-Cut Shredder
Royal mc100mx
Dear Michael,
RC
Mar 21, 2014 | Royal 29140X PX100MX Cross-Cut Shredder
Shredder stops - red light off
Some shredders are great for thicker paper. If you put a thicker piece of card through, it should activate the switch located in the middle of the shred blades. The paper might be too light to push it forward. Also, if you click the feed catch beyond it's operating position, this can also stop the shredder with no lights.
Jan 25, 2014 | Intimus 280 Shredder
Everytime i open my computer a box appear and said Egis update
Egis Technology Inc., a leading sensor provider of fingerprint biometrics and data encryption, specializes in integrated turnkey solutions with an emphasis on sensor performance and software usability.
Check your computer for one of the following programs. If you have one installed goto the egistec.com website to dowload the latest update.
EgisTec Protection Suite
EgisTec Shredder
MyWinLocker
Port Locker
SecureShare
Trust Delete
Or you may have a biometric sensor on your keyboard or usb drive. Which you would also want to goto the egistec website for the latest update. If you do not use the sensor you should be able to diable it.
Mar 11, 2011 | Computers & Internet
Egisupdate.exe, my daughter used my puter and now I have this. Certain things are not responding at all. New computer
Malware can be named anything but here Acer is the clue, it may have an encryption program known as MyWinLocker by EgisTec Software installed and EgisUpdate.exe would be the updater.
Do you have MyWinLocker on your laptop?
If yes then below is the vendor site to tell you that its not a Malware..
http://www.egistec.com/products/mywinlocker-3-plus.aspx
If its locking up your PC then you may want to end the task and some times a reboot should also help.
Let me know if you need more help.
Feb 02, 2011 | Acer Aspire 5735 Notebook
It will not grab the paper; need to press forwared
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Quartet gbc Shredmaster 6550X...
Light is on. Reverse works, paper fed won't trigger the shredder
If you are pushing a button to make the shredder run something doesn't sound right.
See if this makes sense, Generally shredders will use a photo switch or a micro switch to detect the paper. If you are pushing a button it sounds like you have a micro switch. The switch should have an arm that would extend into the throat of the shredder and the paper would hit the arm activating the switch. From your description it sounds like the arm is missing or bent out of the way of the paper. If you can see the paper actually hitting an arm that would activate the button then the arm may just need to be bent a little so it moves farther to operate the button
Hope this makes sense and helps
Mar 14, 2009 | Office Equipment & Supplies
Computers & Internet Logo
199 people viewed this question
Top Egis Technology Computers & Internet Experts
Raj Patel
ray gallant
Bill Boyd
Are you an Egis Technology Computer and Internet Expert? Answer questions, earn points and help others
