Question about Maytag 24 in. MD5600 Jetclean II Built-in Dishwasher
Dishwasher keeps throwing circuit breaker halfway thru cylce
I have a Maytag Jetclean estimated to be approx. 11-14 years old. Just recently it stopped working. I thought it had kicked the bucket, but was told that most dishwashers run on their own circuit so I went downstairs to find that it was the meer flick of a switch. I thought the problem was solved, but now it wants to throw the circuit switch off every time I use it. Halfway through the cycle it will stop, I go downstairs, flip the switch and it follows all the way through to the end. My thoughts are that it's salvagable since once the breaker is switched it still works. Any thoughts as to what may be the cause of the problem? Our house is sold and due to close in less than a month. The issue has to be addressed, but I don't want to pay for a service call only to find that it's an issue with the breaker or the dishwasher needs to be replaced. Please help! Thank you :)
If you have no leaks, then i suspect your element. To crosscheck, you can disconnect
'both" power wires connecting to the element then run the cycle ill the timer remains stationery. advance it by hand then let the cycle finished. if there have been no trip outs, your element is the problem.
Posted on Aug 27, 2008
  • 183 Answers
Most likely cause is a minor leak shorting acroos the wires, check in base for water stains. Regards Advisor
Posted on Aug 31, 2007
Dishwasher Stuck Mid Cycle
Jiggle the water level float sensor .It is stuck .
May 14, 2012 | Maytag Dishwashers
I have a 13 year old Maytag that works great. But recently the flipper door that dispences the dry detergent doesn't open during the wash cycle. I've tried cleaning it thoroughly, but that hasn't made a...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 17, 2010 | Maytag 24 in. MDB6600A Jetclean II...
Dishwasher died during wash cycle; what can i do?
Switch off the system. Check your program settings and re run. Check circuit breaker or fuse.
Even then it behaves erratic, take MAYTAG service help.
Apr 12, 2010 | Maytag MDB9600A Jetclean II Built-in...
Dishwasher lights flashing and will not start
silly question, did you try resetting the circuit breaker for the dishwasher in your electrical panel ?
Same thing happened to me and that seemed to fix it. Leave to breaker off for about 1 minute so the dishwasher resets.
Nov 17, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
White build-up
this is scale build up you should run a descaler through your unit if you cannot find any viniger works just let it sit in overnight
Dec 10, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Electronics problem with Maytag Dishwasher
the outlet pump may have become clogged, try removing and cleaning it.
Mar 26, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Maytag MDB6600AWW
Have you tried pushing heated wash, heated dry, heated wash then heated dry? Sometimes this will reset it.
Oct 27, 2007 | Maytag 24 in. MDB6600A Jetclean II...
Dishwashers Logo
381 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
