Question about Refrigerators
Maytag mtf2142mes00 Switching door side
Freezer door does'nt shut all the way
If you notice one side of your Maytag side-by-side refrigerator is significantly higher than the other, you might want to raise or lower one of the doors. The refrigerator door is configured at the factory to be slightly higher than the freezer door. The weight of items on the door shelves sometimes cause the doors to sag slightly inward. Making a small adjustment to the freezer door leveling screws will correct minor amounts of sagging.
Things You'll Need3/8-inch hex head screwdriver 1
Position the refrigerator in the place you plan to keep it, and make sure the refrigerator is level front to back and side to side with a spirit level.
  • 2 Remove the base grille, located below the doors, by pulling from the sides. The leveling screws will be visible when the grille is removed.
  • Read more: How to Adjust the Maytag Freezer Door ' eHow.com http://www.ehow.com/how_12111048_adjust-maytag-freezer-door.html#ixzz1txsYiGQa
    Read more: How to Adjust the Maytag Freezer Door ' eHow.com http://www.ehow.com/how_12111048_adjust-maytag-freezer-door.html#ixzz1txrg7UOa
    May 04, 2012 | Maytag MFI2568AE Side by Side French Door...
    SWITCHING THE DOOR HINGE
    if you open the door and look to the opposite side you will see to white pieces, take the screws out and they will come out, do the same with the hinges and once the screws are off the hinges lift the door open and out, switch the hinges and the white pieces. Door is now reversed. Good Luck Tim
    Jan 16, 2011 | Maytag Neptune MDG9700A Gas Dryer
    Can you buy replacement doors for side by side Maytag refrigerators. The left side with the water/ice dispenser?
    You can buy spare parts for refrigerators. Download a manual from the Maytag web site and look up the part number. Then, search for appliance parts dealers. They can order the door you need.
    It would be cheaper to order just the piece you need for the door you have. A complete door will probably cost as much as a new refrigerator.
    Oct 12, 2009 | Maytag Refrigerators
    I have the maytag side-by-side model MZD2725GRW.The actuator pad sticks and water and ice will not stop unless the door is opened.Where can i get the part to fix this?
    Call Maytag Direct for parts. Give them the model number. Alternatively, look up a local appliance supply store and visit them with your information. Many times they have suppliers if Maytag no longer makes the parts.
    Aug 20, 2009 | Maytag MFI2568AE Side by Side French Door...
    Maytag epicz washer
    After switching on the machine try pressing 'end of cycle'. Then wait for a couple of minutes to try the door.
    www.neptunewaxmotor.com
    Feb 28, 2009 | Maytag Washing Machines
    Maytag MAH21pddww door locked
    hi thanks for the question to unlock the dor manually open the soap door look to the right top inside its a small piece of string pull on it. that should unlock the door thanks the appliance doc
    Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Maytag frig side by side door pops open when I shut the other side
    the ref. is not level or too much wieght in the freshfood door
    Jun 03, 2008 | Refrigerators
    Refrigerators Logo
    21 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
