Question about Motorola Mobility RAZR V3
Can't press any thing but end
The only buttons that work are the one on the right side of the screen and the end button.
  • 4 Answers
Hello" My name is Cristy and I rebuild motorola v3 cell-phones for a living. You need a new keyboard assembly for your cell phone
Posted on Aug 31, 2007
'tab' button doesn't work on Motorola MC3190
You get 3 different keypad models of the Motorola MC3190:
- 28 Key Numeric
- 38 Key Shifted Alpha
- 48 Key Alpha Numeric
So depending on the type of keyboard your model has, using TAB are different across these 3 keypads.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
When the FUNC button is pressed the icon "F" appears on the taskbar on WinCE devices or the icon "Blue Circle" appears at the bottom of the screen on Windows Mobile 6.1 devices.
In order to use the TAB function, do the following:
28 Key Numeric - Press the blue FUNC button (Bottom right next to Power button), and press the RIGHT ARROW button.
38 Key Shifted Alpha - Press the blue FUNC button (Right side below RIGHT ARROW button), and press the RIGHT ARROW button.
48 Key Alpha Numeric - Press the blue FUNC button (Right side below ENTER button) and press the number 9 button.
Apr 18, 2014 | Zebra Symbol MC3190G Handheld Mobile...
Tip
Broken Screen Delete Messages Nokia 3109 3109c 2323 2323c
This works for the Nokia 3109/c and also the 2323/c which have a Nokia menu like in the picture. If you have the same menu then it should work. The handsets have a central navigation button which allows you to move up, down, left and right through the menus.
Delete Inbox Messages Blind Nokia Broken Screen
Press Central Navigation Button to get Menu
Press left once
Press up once - Message Menu
Press Central Nav Button
Press up twice - Delete Messages
Press down once - By Folder
Press Central Nav Button - Inbox
Press Central Nav Button - Confirm Delete
Press Button above call end several times to exit from the menu
Note on the 2323 (not sure about the other models) you have an option to keep unread messages. If you still want everything deleted then swap confirm delete step above for
Press Left hand button set above green call button - confirm delete all messages
Delete Sent Messages Blind Nokia Broken Screen
Press left once
press down three times - Sent Items
Press Central Nav Button - Confirm delete
on Aug 06, 2010 | Cell Phones
HTC Wildfire touch screen frozen
You can try 2 things:
    1)Soft reset - clears memory and restarts program
    2)Hard reset - deletes all saved data and settings
    Soft reset
      -Locate reset button to right of USB port on bottom of phone
      -Press reset button with stylus
      -Wait
      Hard reset
        -Press and hold both talk and end buttons
        -Press reset button with stylus while holding talk and end buttons.
        -Release talk and end buttons and press enter
How to Troubleshoot Frozen HTC Touch
Aug 29, 2017 | iPhone Apps
Turn ringer on
To set the Vtech T2326 ringer:
there are only four ringer tone/volume choices plus "off" available
1. Press the PROG end of the "SELECT/PROG" rocker switch.
The display will light and show "DIRECTORY"
2. Press the right side top button "VOL +/DIR"
The display will change to "SPEED DIAL"
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: [number] ( 1 - 4 or OFF )"
4. Press the SELECT end of the "SELECT/PROG" rocker switch.
The "RINGER: [number] ( 1 - 4 or OFF )" will blink and the ringer will sound.
5. Press the right side top button "VOL +/DIR" The display will change from "RINGER: 1" to "RINGER: 2" and the sound will change accordingly.
6. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 2" to "RINGER: 3" and the sound will change accordingly.
7. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 3" to "RINGER: 4" and the sound will change accordingly.
8. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 4" to "RINGER: OFF" and the sound will cease accordingly.
9. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: OFF" to "RINGER: 1" and the sound will change accordingly.
10. ...and so on, cycling through the four choices & OFF: when you decide to select one, press the "SELECT" end of the central "SELECT/PROG" rocker switch.
11. The display light will go out, the phone will chirp in acceptance, and it will be ready to use the chosen ringer. --
Sep 07, 2013 | Vtech T2326 Cordless Phone
Instructions for oxo model 1061978
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Feb 17, 2013 | Oxo Hardware & Accessories
Administrator log in
1-Press "Utility/Counter button from control panel.
2-Press "Administrator settings" from Touch screen LCD menu,
3-Enter "Admin Password" which is 12345678.
4-After entering the above password, press "ENTER" or "END" button, (appeared on top right side of menu).
5-After pressing the end or enter button you will be in administrator mode.
Now, if you are asking about the Administrator password, then the password is "12345678" This is the default administrator password of Konica Minolta bizhub MFPs and Photocopiers.
For any other queries, feel free to ask any time.
Jan 31, 2013 | Konica Minolta Bizhub C300 All-In-One...
Every program scheduled to record starts and ends five minutes early? So the end of the preceding program is recorded and the end of the selected program is cut off.
BigBillO,
One of the options for the DVR recordings is starting and ending before the program starts and ends. You can change this setting to your preference. To change , press the DVR button 2 times on your DISH remote. This will bring up the "My Recordings" screen on your TV. Go to "Schedule" button on the right side of the screen. Press select. You should be on the "Daily Schedule" screen. Go to "Timers" button on the right of the screen. Press select. You are now on the "Timers List" screen. Select one of the programs scheduled to be recorded and press "Select". You are now on the "Timer Schedule" screen. Go to "Options" button and press select. You are now on the "Timer Options" screen. This is the screen you can set your preference for the "start early" and "stop late" settings. Be sure to select the "Set as System Default" if you want to apply this setting to all your recordings. I hope this helps.
Ray Calo
DISH Network
Mar 20, 2010 | DISH Network ViP622 DVR DTV Receiver /...
The right button of the mouse is very hard to press.Any ideas how to fix this problem
Hi there, You feel hard because its broken from the inside. i guess if you press the right button from the end side( back side end of pressing location ) then some time it will work. Ok just turn back and open the small screw by screw driver. Then remove the casing. you should find 2 button look like small tap with black head or you can say its a radio button. press both button, if its working perfect and sound like a " tik tak" then you confirm that the button is ok. After that check the mouse casing press button. There you found a small plastic "dot" which is attached back side, with left & right side pressing button. If right side is missing then the "dot" button is broken, that's why you can't press the key. And some time its dislocate So if you do not find that "dot" plastic then i suggest you buy a new mouse or if its dislocate then try to fix it.
Thanks & waiting for your feedback.
Feb 15, 2010 | Logitech MX620 Mouse
Control panel locked, won't unlock.
Press & hold the 'end of cycle' button on the right side of panel for 3 seconds. Child lock button, you do the same thing again & it locks. You don't want kids bathing in the machine, no. Pl rate me nice.
Apr 20, 2009 | Whirlpool GHW9100L Front Load Washer
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Dec 24, 2006 | HP Compaq FS 7550 17" CRT Monitor
Motorola Mobility RAZR V3 Logo
49 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
