Question about Irons
Repair retractable cord won't stay extended
I pull the cord out and it keeps retracting back in. It will not stay extended. Otherwise the iron seems ok but it cannot be used in this condition. It keeps pulling the plug from the outlet when I tried to use it in an emergency ironing situation until I could get it fixed. There aren't many repair shops here that would be able to fix it and the iron is not new so it would be better if I could fix it myself. It is a Rowenta made in Germany
SOURCE: rowenta dx6700
The wire inside the cord is likely torn ant it connects and disconnects as it is moved back and forth. This happened to me too. I just need to find where to get a new cord.
Posted on Jul 31, 2008
SOURCE: Retractable cord
first, i'll apologize for not posting pictures with this, but i didn't have a camera handy when i "fixed" it. i'll do my best to explain the sitch.
i also have a sunbeam 4124 whose retractor was jammed...the cord would not release more than two feet or so, nor would it retract. i was able to disassemble it, but broke some internal retaining clips meant to hold the retractor housing to the iron. WARNING!! do not attempt this if you do not want to void your warranty. i can only assume that the manufacturer did not want you to disassemble the cord return housing and as such, hid the retaining clips where it would be impossible to disengage them. i got lucky and only broke one set of the retaining clips....if you carry on, you stand a chance of breaking both sets, which will not allow you to reattach the retractor housing to your iron securely. best thing to do is call sunbeam and have them send you a new iron, but if you're bent on fixing it yourself, here's how i did it (you'll need one medium philips head screwdriver):
1) remove the rubber feet from the bottom of the iron. this will expose two screw holes (the third foot under the retractor button has no screw; this is the side where the reaining clips are buried).
2) remove the two screws
3) WARNING! this is where you have a good chance of breaking your iron. pull the base of the iron really hard, rocking it from side to side. there are two sets of retaining clips recessed in the housing of the iron. the button will come with the base of the iron, the entire cord retraction assembly is self-contained. you can carefully use a screwdriver to pry the two halves apart. also, be careful not to pull too hard as the electrical connections between the iron and the retractor assembly has only about 2 inches of slack, though the connections are just wire-nut'd together and could be reassembled in a pinch.
4) after the retractor housing is separated from the iron, remove the housing cap by unscrewing the four screws.
5) carefully separate the two halves of the housing; the spring may be loose inside and could snap out at you.
here's where my iron was broken....the coil spring is contained by a plastic tray that had snapped, probably due to somebody pulling the cord out too hard. a section of the tray had jammed itself into the inside of the housing, immobilizing the winding mechanism. my only recourse was to completely remove the spring and permanently extend the cord all the way (not one of the features i bought the iron for anyway, so what the heck). PLEASE be careful unwinding the spring if you have to do it....wouldn't want anybody poking out an eye inadvertantly.
6) reassemble the retractor housing by screwing the cap back on with the four screws
7) if you're lucky enough to keep one set of retainer clips, snap the base of the iron back on and reattach the two screws located under the feet.
8) rubber pads back in and voila!
hope this helps!
Posted on Nov 03, 2008
  • 240 Answers
SOURCE: Rowenta Professional Iron - steam button suddenly stopped working
Have you tried descaling it? It may well be blocked up with limescale. Personally I only ever buy cheap irons and bin them when they go wrong! As you say-they are generally too expensive to repair.
Posted on Jun 11, 2009
deme-tri
  • 90 Answers
SOURCE: Retractable Iron Cord Stuck
under the knob to press to retract the cord there is a screw,
slacken it ad try to adjust it again.
Posted on Dec 01, 2009
heatman101
  • 43501 Answers
SOURCE: My Rowenta iron is leaking down by the cord. can
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
Fix Rowena iron with retractable cord
I would contact a small appliance repair business near you, they can supply the needed cord and the repair for very little money I would think
Sep 23, 2016 | Irons
How do you repair the retractable cord on a 1500w iron
So many people make a copy of that iron maybe a local repair shop for tefal, black n decker, or another can do it. Taking things apart sometimes is not worth the trouble of putting back together. sometimes it requires special tools. call around first before you try it yourself
Jan 26, 2015 | Rowenta DW2090 Effective Comfort Cord Reel...
Why does the cord to my rowenta iron not fully retract?
pull cord all the way out of the iron, make sure it's flat and not twisted when it gets reeled back in.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Aug 26, 2014 | Rowenta 1500W Steam Iron with Cord Reel...
How can I repair my the retractable cord on my iron?
Install a new one cuz that old one is compromised
May 02, 2014 | Panasonic NI-R73NR Iron
My hamilton beach iron will not steam
see the diagram and see if there are any part broken, or worn and replace. Tank or ports clogged.and repair
Sep 09, 2012 | Hamilton Beach 14210Z Nonstick Iron with...
Jul 26, 2009 | Black & Decker Irons
Black and Decker First Impressions Iron
seems like you have to take it apart
Jul 22, 2009 | Irons
Sunbeam 4214 Clothes Iron with Retractable Cord won't heat.
hope this helps!
Mar 17, 2008 | Sunbeam 4214 Iron
Retractable cord
hope this helps!
Jun 12, 2007 | Sunbeam 4214 Iron
Irons Logo
21 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
