Question about Mitsubishi WS-65809 65" Rear Projection Television
Mitsubishi WS-65809 PIP/POP operation without Remote
I lost my original remote. I can still use it with my Comcast remote or using the front panel buttons, but how do I use the PIP/POP options without the remote. The manual doesnt cover that part Thanks for any help you can give
  • boatgambler1 Sep 29, 2008
    i lost my remote i do have comcast but my tv isnt on i bought a universal remote but i dont know how to use it because my front buttons on the tv dont work so i cant even turn it on what should i do
    Sergeant:
    Champion:
  • 301 Answers
You can buy an orignal remote from mitsubishi. they are roughly $68.00 unless you can find a universal remote that will output the correct IR command.
Posted on Feb 20, 2008
SOURCE:
Tip
Reset Mitsubishi HDTV VChip Password
Bypass or Reset Mitsubishi HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Bypass Mitsubishi HDTV Front Panel Lock
Mitsubishi WS-55511 Manual Download
on Apr 30, 2010 | Televison & Video
Tip
I hope that helps.
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
I lost the remote and cannot remove the PIP.
Hi, I have the same TV, remote too. From what I can see you will need the remote to turn off the PIP, but if you unplug the TV and the plug it in again it may reset it to original values. As long as it is plugged it will retain certain low power settings.
If your Comcast remote is a learning remote, you can probably program it to mimic/replace the remote you lost, but you will need the codes from the Sony remote, or borrow one so the codes can be "learned" by the Comcast or some other learning remote. The codes would likely be available online, from Sony.
Worst case - I'll buy for you a cheap learning remote and dump the codes from mine if you want.
Also, you may find a used remote on line.
Mar 09, 2010 | Sony Televison & Video
Tip
Bypass Mitsubishi HDTV VChip Password
I hope that helps.
WS-55511 55in volume turns up by itself & can't switch devices
The remote is not the problem. The switch for volume up on the control panel has become leaky. Very common problem for this generation Mitsubishi. If you don't mind not having the control panel working you can disconnect it and the set will work just fine with the remote. To disconnect the control panel pull the speaker grill, it just snaps off, and remove the front access panel. Once that is done you'll see a cable going to the switches just disconnect it.
Nov 23, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Tv code
Good Day, weilly101;
Look into your COMCAST booklet or call COMCAST, not TV problem. Good Luck, big IRISH.
Aug 30, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
161 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
