Oki c9650 error 381 - Office Equipment & Supplies
5 Suggested Answers
  • 44 Answers
SOURCE: oki c5250n paper jam
Unfortunately this may require and engineers visit. If you pull down the MP assembly by using the handle in the middle at the front of the printer you can then see a small "gearbox" at the right hand side of the transfer belt. This is common to feeds from both trays and could be worn. If you remove tray 1 and temporarily tape up the sensor arms to fool the printer into thinking it has a full tray installed, you can the test, by applying a little pressure to the feed roller, to see if it positively moves forward or if you are able to stop it turning. On a brighter note, you may just need new rollers instead of cleaning them.
Posted on Apr 18, 2009
SOURCE: My oki c9650 say service
jcampos,,, pudistes solucionar este problema del error 256... tengo el mismo..
Posted on Jun 26, 2011
matt800
  • 241 Answers
SOURCE: oki c9650 paper jam
I would recommend removing all paper trays and opening any hatches that are not screwed down. With this done please check the machine thoroughly and hopefully you will spot the paper in question.
Please bear in mind that even small scraps of paper stuck in the printer can cause this error if they are covering a key sensor.
Once you are confident the offending paper has been removed just closing all doors and replacing the paper trays should make your printer check for paper again (although some models will require you to indicate the jam has been removed).
Posted on Sep 13, 2012
  • 35 Answers
SOURCE: I have an oki c9650 when I print on cardstock the blacks become bubbly and flake off, but only when printing on cardstock
Set it or computer, whatever you are using to cardstock, or it may be called thick,there are multiple selections depending on the media. Beacuase thick paper requires slower speed and hotter fuseing.
Posted on Sep 26, 2012
381 error paper jam oki b431d
381 error indicates a jam under the drum. If no jam exists try using canned air to blow out the printer. Caution, toner dust may blow up in your face.
Jul 16, 2014 | Oki Electric Industry B431d Printer
Error sensor
Toner is a Black in cartridge that needs to be replaced once it runs out.
Nov 06, 2013 | Oki Printing Solutions C9650 Led Printer
How do you fix density shutter error and sensor calibration error on OKI C9650 Printer
The shutter protects the density sensors and keeps the windows on the sensors clean, until they wear out. Replace the shutter assy (part number 42755401) and clean the sensor windows.
If this doesn't solve the problem, you may be at the beginning stages of a broken gear for the top cover mechanism that protects the LED printheads when the cover is open. As a test, you can remove the 4 black protective covers from the printheads and see if your machine will calibrate itself. If it does, I recommend leaving the protectors off and just be extra careful of the LED printheads when you change toners...
Jul 06, 2013 | Oki Printing Solutions C9650 Led Printer
Oki c9650
The top cover mechanism that protects your LED heads has broken gears that operate the protection shields. As a test, you can remove the 4 black shields from the LED printheads and see if the printer now prints correctly. If that fixes it, then I recommend leaving the machine that way as replacing the entire top cover is the solution...very expensive if it is still available to purchase.
May 01, 2013 | Oki Printing Solutions C9650 Led Printer
Fatal error 142
Color ID up/down error
is detected.
1) Is an Error message displayed?
Confirm that the Y, M, and C ID
units are in position, and reboot
Mar 04, 2013 | Oki Printing Solutions C9650 Led Printer
Oki C9650 not printing Yellow
remove the unit
open the cleaning lamp cover (front of unit)
turn O.P.C drum gear and check that toner is always applied to the developer roller
Sep 27, 2012 | Oki Printing Solutions C9650 Led Printer
Iam getting the duplex paper jam error 371 each time i try to print . how do imake the error go. i dont use the duplex at all.
See page 75 of the attached user manual on how to remove a duplex paper jam. If you can't find a paper jam in the duplexer, simply remove the duplex assembly (power off the printer, then power on) and see if that resolves your issue.
(The printer will operate just fine without the duplex assy. installed)
Okidata C9650 User Manual
Sep 12, 2012 | Oki Printing Solutions C9650 Led Printer
Oki c9650 paper jam
My oki c9650 say service call 256: Fatal error
Feb 02, 2011 | Office Equipment & Supplies
71 people viewed this question
k24674
jasbo
jasbo
