Panasonic heatpump cs-E7HKR fault codes - Heating & Cooling
4 Suggested Answers
  • 857 Answers
SOURCE: E2 fault code on AUX
E2 - error simply thermistor short circuit.
The e2 code on a carrier comfort zone thermostat is indicitive of the external safety sensors which are located on your units ductwork in the attic. the e2 code are the hpt/ and lat sensor codes. the hpt is the heat pump temperature sensor and the lat is the leaving air temperature sensor. you can pull off the cover of the panel and behind it will actually give you all the fault codes associated with you carrier tsat.each sensor has a certain ohm rating and if its out of the range it will fail. now as to the reasons for failure, the indoor coil could be dirty, filters dirty, refrigerant charge incorrect.
Posted on Aug 23, 2010
hvac1960
  • 2133 Answers
SOURCE: FAULT CODE H19? WHST IS
H-19 Error code means indoor fan mechanism locked. replace fan.
Posted on Dec 12, 2010
hvac1960
  • 2133 Answers
SOURCE: i have a panasonic cs e12 ckp. timer light flashes
Press on/off button continuously for 5 seconds.Helpful?
Posted on Jan 16, 2011
Panasonic cs e9nkr aircon. Shuts down timer continuously blinks. Checked for fault codes h00
I haven't got the service manual for this but the error codes should be on a sticker behind the front cover. Take that of and it will guide you to the fault.
Feb 19, 2015 | Panasonic Heating & Cooling
Panasonic air conditioner CS-E28GKR error code h15
(?15) - violation of the operation mode of the temperature detector of the compressor unit Panasonic
Oct 06, 2012 | Panasonic CS-A12C Air Conditioner
Panasonic cs-21z80sq tv with a blinking red light
The fault is with its power supply regualtor section.
Mar 24, 2012 | Panasonic Televison & Video
FAULT CODE H19? WHST IS IT? panasonic air conditioner cs/cu-e18jkr.
Dec 12, 2010 | Heating & Cooling
Panasonic inverter model no CS-E21HKR fan appears to be working on high we cant get it to slow down
In remote/thermostat there is option " FAN " press for low/med/high. Plz refer if any fault code is there.
Dec 09, 2010 | Heating & Cooling
Panasonic air conditioner CS-E24GKR...The unit stops and the timer indicator blinks. Also displays error code H 11...Help...Please...its hot in here
H-11Indoor / outdoor abnormal communication. Check • Internal / external cable connections
• Indoor / Outdoor PCB
Jan 04, 2010 | Panasonic CS-A12C Air Conditioner
Panasonic Inverter CS-E12EKU timer indicator blink. The unit not work at all, I follow the manual instructions using the remote control but the instructions are not clear. Using other similar Panasonic...
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
Aug 21, 2009 | Panasonic Heating & Cooling
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
