Question about Refrigerators
Problem lamona 150mm wine chiller
Making a loud noise and temperature keeps increasing
57 varieties
  • 1653 Answers
SOURCE: I have Vinotemp wine chiller model number
It will either be the thermal resistor or the controller of which the electronic thermostat is a part and yes it can be repaired. It is a reasonably common and cheap fault to repair. If you go to the following link you can get the service manual FOC
http://www.vinotemp.com/Resources/Documents/VT60.pdf
and you can contact a repair company via Vinotemp at the following link
http://www.vinotemp.com/Service-Support/Repair-Companies.aspx
Posted on Nov 07, 2009
  • 4793 Answers
SOURCE: The wine bottles in my wine chiller are covered
put a dehimidifier/silica gel sack in the bottom to keep the interior dry.dont forget to oven dry the silica gel every month.
Posted on Jun 03, 2010
Testimonial: "Thank you. I hadn't thought of silica to dry it out but I will try it right away. I really appreciate your suggestion@"
SOURCE: Haier Dual Zone Wine Chiller - One Fan wont run
I have the same problem. When I first discovered this, both fans had stopped working and the temp for both zones was over 80. So much for the wine that had been stored there. After leaving the unit unplugged for a few days, the fan for the lower section started working again but the upper fan is still overheating. Haier customer service says too bad, so sad (I discovered this problem in the 13th month of ownership). I'm sure it is not worthwhile to fix this so it is going out with the trash and I'll look for a different brand for the next wine cellar that I purchase. Any ideas?
Posted on Jul 13, 2010
  • 266 Answers
SOURCE: Hi, I have a WCR524SDZD wine
your unit uses a generic fan motor that a lot of refrigerators ect.. use. If you take the fan to a local shop that sells refigerators they will match up one for you. Avanti's phone number is 1 800 220 5570. good luck
Posted on Aug 11, 2010
SOURCE: My magic chef wine fridge keeps making a loud
I have a Magic Chef wine cooler making that loud popping noise - Model # MCWC45MCG Could you let me know the way to fix it if possible or where to take it considering I live near Indianapolis, Indiana?
Posted on Oct 08, 2010
I have a KitchenAid Refrigerator Model Number: KBFC42FTS. Bottom drawer freezer over cools -10 degrees.
Does that unit have a low temperature monitor built in? Maybe that is what is making the noise when your temps dip to -10 degrees. Actually, that is great because the lower the temps the longer you can keep food in the freezer so I would not be overly concerned about that aspect. BTW, have you tried to isolate the source of the humming noise?
Sep 19, 2017 | KitchenAid Refrigerators
That's interesting, -10 or colder is too cold and something is defiantly going on. This unit is controlled by a mulitple control boards, temperture sensors and other components. Question, what is freezer temp set at? Try increasing it by 3-4 degrees and see if that changes anything. Beyond that, I'm going to change the temp sensor first before doing any of the control boards. #29 is the temp. sensor. Good Luck
Wine cooler cools but has a very loud, too loud to ignore, whirring sound when it is in cooling mode. Any ideas?
And when the wine is cooled ... the noise stops?
It's like a refrigerator ... it only operates when it it is reducing temperatures. Once things have cooled, the system cuts out.
If your wine cooler stops making a noise when the wine is cooled ..ok.
Jan 19, 2016 | Refrigerators
Can anyone direct me to an operating manual for the Brandt Wine Chiller?
Search Results
    Download brandt wine chiller manual - Google Docs
    https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesLooking for brandt wine chiller manual? Download brandt wine chiller manual.brandt wine chiller manual. User Manuals, Instructions and Guides.We have that ...
    brandt manual Refrigerators Questions & Answers - Fixya
    www.fixya.com > Forum > Tags > brandt manual
    On my Brandt wine cooler at the top is an adjustment control for temperature. ... is amanual for this refrigerator LG top mount ice box service manual Maytag ...
    Free Refrigerator User Manuals ' ManualsOnline.com
Dec 14, 2015 | Refrigerators
I have an older model Avanti Wine Chiller that began making a very loud almost-grinding noise last night. It continues to cool but I have turned it off due to the deafening sound. Any ideas?
first off determine where the noise is coming from what area? I suspect u may have a fan or condenser fan problem restricted , impeded or going out?
Feb 25, 2015 | Avanti Refrigerators
My 2009 auris has a loud noise from the front end and flashing check battery and check engine
You need a scan tool hooked up and the fault codes read that are recorded when these warning lights came on. That is the starting point to understand what has failed here.
May 19, 2017 | 2010 Toyota Auris 1.33
When do I need an aquarium chiller?
You'll need a chiller when the ambient room temperature is higher than the desired temperature of your aquarium. This can happen due to many reasons such as:
1) If you live in a warm part of the world and decreasing the room temperature is not good enough.
2) If you wish to keep cold water species in your aquarium.
3) If you have installed heat emitting equipment that increases the water temperature such as light, pumps etc.
Aug 13, 2012 | Fish
Loud fan noise every 3-4 minutes
It's probably the automatic control of the CPU fan.When the temperature goes up the fan speed increases witch generates more noise.When the CPU cooler accumulates dust the temperature rises faster so try and see if that's the problem. If that's not it you can download a software to manually control your fans.I recommend SpeedFan and you can get it here: http://www.almico.com/sfdownload.php
Dec 17, 2011 | Compaq Presario CQ5110F (NP185AA ABA) PC...
Why does the Fan make louder noises when you run certain programs, and is there a way to prevent it from making these loud sounds?
If this has Smart fan technology on the mobo, it will do this as the fan speed is increasing to compensate for the increase in the temperature of the CPU.
You could , if the noise irritates you, purchase a better cooler, one with copper heatpipes and a larger fan..
Jan 03, 2011 | HP (219115001) CPU Heatsink & Fan
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
