Question about Kitchen Ranges
Whirlpool akg958gy cooker hood
How to remove the hood completely
2 Suggested Answers
  • 72 Answers
SOURCE: how to change carbon filter on whirlpool cooker
The paper filte pulls out from under the lugs of the metal panel that is attached to the door, turn the plastic clips on the left and right, half way and it will drop out.
Posted on Dec 28, 2009
Cooker hood installation
A cooker hood needs to done by a competent qualified Electrician but basically depending on your surface of the cooker hood.Depending on the type of cooker hood you have(extract or outside) If it is a extraction (meaning you are using filters and not connected to a vent) The Electrician needs to connect the electric to a point or spur via a power switch on the wall which when you fit up the main part of the hub covers the spur. after that you need to measure and fit the cooker hood to your requirements but make sure your walls can support it and mark off the holes before drilling or check the walls for electric wires in terms of safety.
May 21, 2012 | Washing Machines
Hi, we have a Whirlpool Generation 2000+ Cooker Hood that blows instead of sucks, any idea why please?
Is it possible that the motor wiring was jumbled in case it was taken out. If so the rotation would have changed resulting in the reverse movement which make it blow into the area.
Check the capacitor connection to the motor and reverse.
Jan 04, 2012 | Whirlpool Kitchen Ranges
Light and fan stopped working
Power problem or fuse .....gotta trace wires....maretts gotta be taped....
Oct 27, 2009 | Kitchen Ranges
How to change carbon filter on whirlpool cooker hood AKG958GY
Sep 14, 2009 | Kitchen Ranges
Bulb blew on Whirlpool cooker hood and new ones fail.
well is there a switch you might want to check that out.
Jun 29, 2009 | Whirlpool GZ5730XR Kitchen Hood
CDA CPX9 COOKER HOOD - how to remove chimney/disconnect power
remove filters, inside there will be mounting screws, support the unit prior to removing screws. there might be ducting inside clamped on, and a power plug(hopefully) to disconnect.
Jan 26, 2009 | CDA Kitchen Ranges
Removal of cooker hood to locate electric plug
Thank you for your letter, we had to dismantle the whole cooker hood to get to the electric plug.
Thank you.
Jan 18, 2009 | Kitchen Ranges
Belling cooker hood chim101 BL - light/ lamp
I just had this very same problem and believe I have solved it!
You can remove the entire light unit from the hood. On first inspection it appears to be a sealed unit that does not allow you to remove either the wires or what looks to be a regular halogen bulb. If you turn the unit so the bulb is facing you, you can gently prise the glass from it's housing leaving the naked halogen bulb exposed beneath it. You can gently pull this from the housing and buy a new one to replace it. I would advise that when installing the new one you make sure it is completely free from any contaminant as any grease etc can greatly reduce the life of the bulb. Hope this helps!
Nov 04, 2008 | Kitchen Ranges
Indesit cooker hood
indesit hi 591 cooker hood bulb blew replaced it hood not working at all now
Oct 17, 2007 | Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
