Question about GE Refrigerators
General electric repair manual for tbx22rmr
Freezer will not freeze
3 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: the freezer build ice in the inside rear, it
If you are still having the problem we need to look at control board on back of refrigerator. Below is a picture of the back of refrigerator and the opening where the circuit board is mounted. Let me know if you need me to help get this resolved. You will need to examine back and front of board for burn marks. Always unplug refrigerator before you begin work on it. Thanks, Sea Breeze
seabreezehvac@yahoo.com
Posted on Apr 21, 2009
  • 266 Answers
SOURCE: i have a side by
More than likely either your defrost timer is bad or the heating element in the fzr is bad. The timer is normally located with the controls in the fridge side behind the plastic back or top if there is a light in the top center. It will have an access where you can turn it manually with a flatblade screwdriver. Turn it slowly and you will hear clicks it may take a few min. but try to make it click one at a time and listen for the fan and compressor to kick off. (slowly the defrost mode is just one click) If it kicks off wait 3 min and open the fzr and see if you hear hissing or ice cracking. (the hissing will be water dripping onto the heating element) If this happens replace the defrost timer. If you do not hear the element hissing ect... The element is bad or the defrost limit attached to one end of it it will be a round disc apx the size of a nickel replace it. good luck and remember to unplug the refridgerator before delving into the elect parts. I hope this helps you can defrost the fzr manually with a hair dryer or if the manual turning of the timer works until you get the offending part. good luck
Posted on Aug 16, 2010
Fridge is not cooling, fridge is working fine
Hello Dan, Is Your Fan in your freezer compartment on ? sometimes the evaporator coils will freeze up not letting the air cool the refrigerator
Dec 25, 2013 | General Electric GFSS6KKXSS Stainless...
Have General Electric standup freezer; model # FUF2DMARWH. Left door open a tad, over night. Unplugged it in morning for 10 min., then plugged it in and it seemed to be working as the temp. dropped...
turn off freezer and remove freezer panel at bottom in back. if evap.coil full of ice then defrost all ice. if no ice build-up then compressor may need new relay.
Aug 29, 2013 | General Electric Refrigerators
I cleaned my freezer and now it won't freeze
When you say "cleaned", did you defrost it? And. if so, could you have damaged the internal lining? Often the coil inside the wall of a chest freezer can fracture if hit or stabbed at during defrosting.
Other than that, is the compressor running (you would hear it)? it may have overheated. If not running, see if it feels hot (siezed) or cold (no power from thermostat). If cold, put it on fast freeze and see if it kicks into life (thermostat faulty) or not (compressor fault, time for a new freezer!)
Let me know how you get on!
Jul 05, 2012 | GE 14.8 cu. ft. General Electric Chest...
THE COMPRESSOR IS HOT. CHEST FREEZER NOT FREEZING.
Sounds like you have a bad compressor. If you can check the amp draw.
Jan 18, 2011 | GE 14.8 cu. ft. General Electric Chest...
Hi! I have a GE Freezer Model FUF14DTARWH that runs but the coils are not getting cold enough to freeze???
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 15, 2010 | GE 13.7 cu. ft. General Electric Upright...
My freezer dosen't freeze enough. The temperature is situated in -2 c.
Please top up the refrigerant and set the thermostat a bit lower temperature.
Oct 26, 2010 | General 14.8 cu. ft. Electric Chest...
Freezer starting to defrost
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Feb 22, 2010 | GE 13.7 cu. ft. General Electric Upright...
Fridge works freezer isnt getting cold enough to freeze
check to see if you have frost on the back panel of the freezer if so then defrost the unit and if your able to find the failure of the defrst heater or defrst thermostat,or the defrost thmer more than likely its the mother board since its a general electric frig but if you manually defrost until a repair tect can come then it will run normal until it frost up again but before you call the tech out make sure you have the frost on the back panel otherwise he'll make several trip trying to solve the problem with the frig unless its the defrst heater
Sep 08, 2009 | Amana Refrigerators
Its freezing roun the top and not the bottom?
is this a chest freezer? Thick frost around top? try defrosting unit. DO NOT scrape the ice. Very important to remove drain plug to remove water or frost will very rapidly redeposit
Jul 13, 2009 | General Electric Chest Freezer FCM5SU
Refrigerators Logo
116 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
