Question about Vehicle Parts & Accessories
False reading 1993 Honda accord instrument panel temperature gauge false reading.
sodeep
  • 3267 Answers
SOURCE: fuel gauge on 1993 Dodge Dakota V8
Definitely the gauge can be changed, provided the float in the fuel tank is OK, i.e. no leaks. This float connects to a potentiometer which records the current flowing thru it and displays it in the gauge. So before replacing the gauge measure the current and match that against the quantity of fuel in the tank...............sodeep
Posted on Jun 25, 2009
rteemon
  • 578 Answers
SOURCE: INSTRUMENT PANEL GAUGES DON'T WORK
check your vehicle instrument module
Posted on Jul 02, 2009
pippall
  • 1486 Answers
SOURCE: My 2003 Saturn Vue instrument panel stopped
The plug at the back of the panel has come lose.Remove the dash panel and push plug on firmly.Hope that was helpfull.
Posted on Aug 08, 2009
SOURCE: instrument panel lights are out
Call your local Honda dealership, they have extended the warranty to 7yrs and 100,000 miles on the radio circuit broad which is the problem.
Posted on Aug 24, 2009
Wolfman304
  • 720 Answers
SOURCE: 1990 honda accord temp gauge above hot limit.
Firstly - DO NOT run engine, when guage reads hot, as this will cause costly damage to head gasket & alloy engine head.
The fact that guage takes 1min to read HOT, would confirm the guage IS working properly.
So, other components which are likely to cause hot readings (in this order) are:
- lack of coolant (or leakage somewhere): is there sufficient green coolant at the correct level? Top up mixture to correct level. Repair any leaks.
- collapsed radiator hose: when engine is cold, start engine, then quickly watch both upper & lower radiator hoses to see if either begins to flex inwards (collapse). Replace if either hose is collapsed.
- bad/incorrect thermostat rating : when replacing thermostats, you must ensure it is of the SAME temp rating (they all differ).
- Incorrect Temp sensor rating: the ratings of this sensor must be within manufacturer's spec's.
- bad waterpump: the engine relies on the waterpump to distribute the coolant throughout the entire system. If waterpump is faulty, coolant will not flow quick enough, causing overheating.
If you still believe all of the above components are OK, then have your cooling system "pressure tested". This test should be done, before looking further at other electrical components.
Cheers,
"if this has helped you in any way, please rate this solution"
Posted on Jan 27, 2010
1993 Honda Accord EX instrument cluster
i expect it is a faulty component , contact a honda dealer , they will know exactly what the cause is
Jul 05, 2014 | Cars & Trucks
My temperature gauge doesn't work on my 1990 Honda accord
Using an ohms tester, remove your temperature sensor and apply hot and cold water to it. If you find a difference in resistance, then refit it and replace your instrument temperature gauge
Sep 22, 2013 | Cars & Trucks
Why does the fuel gague in my 1988 Honda accord always read full?
check to see if your fuel gauge is working by disconnecting the fuse from the panel, if gauge reads e then ground the fuel gauge if it reads full then the fuel gauge reads fine the its the float sensor in the fuel tank. good luck have fun
Oct 21, 2011 | 1988 Honda Accord 4 Door
1993 honda accord check engine light come on the computer code read 10, what is the problem?
Intake air temperature sensor or circuit fault is what code 10 means
Dec 01, 2009 | 1993 Honda Accord
I am looking for a fuse box diagram for a 1995 Honda Prelude.
The manual indicates Fuse 11 (10A) interior fuse box, INSTRUMENT PANEL LIGHTS.
Also, the is a dimmer for them:
The dial on the dashboard to the left of the instrument panel controls the brightness of the instrument panel lights. Turn the dial to adjust the brightness.
To reduce glare at night, the fuel and temperature gauges dim when you turn on the parking lights or headlights. You then adjust their brightness when you adjust the instrument panel brightness. Turn the dial up as far as it will go to return the fuel and temperature gauges to their daytime brightness.
You can try the following URL for a copy of your manual (which includes fuse box diagrams). You won't be able to save the whole thing (except by sections), but you can print copies of whatever sections are important to you. You'll need Adobe reader (free from Adobe) to read the manual.
https://techinfo.honda.com/rjanisis/pubs/om/PR9595/PR9595MAINIDX.pdf
Hope this helps you.
Nov 29, 2009 | 1997 Honda Civic
Just bought a used 1995 Honda Prelude and the Tach and speedometer work along with the clock but I can't see any other gauges. (Gas, oil, temp and whatever else might be there. What is the problem?
Since you just bought the car, I thought that you might not be aware of the instrument lighting control. I apologize if you know this:
Hope it's that simple.
Nov 25, 2009 | 1995 Honda Prelude
95 Accord, Intermittant Gauges
This sounds like a bad ground but first check the fuse for the instruments located in the fuse box. If that is OK, somone will have to find the ground wire for the instruments and see if it has any voltage with the key on. If it does, the gound connection is bad
God Luck
Feb 07, 2009 | 1995 Honda Accord
98 honda accord panel lights will not turn on
Did you check the dimmer to switch? This is for a 2000 Honda Accord but this may help you: If your instrument lights have burnt out on your 2000 Honda Accord.... You may have another problem!!! While the dealer fixes this recall, they should replace your burnt out bulbs. 2000 Honda Accord Recall ID from NHTSA: 04V256000 Auto Recall Date: 06/07/2004 Vehicle Component: INTERIOR LIGHTING Estimated Vehicles Affected: 19572 2000 Honda Accord Defect Summary: ON CERTAIN PASSENGER VEHICLES, THE DIMMER CONTROL FOR THE INSTRUMENT PANEL LIGHTS COULD FAIL DUE TO HEAT BUILDUP. Defect Consequence: IF THIS OCCURS, THE INSTRUMENT LIGHTS MAY FAIL AND, AT NIGHT, THE DRIVER MAY NOT BE ABLE TO SEE THE INSTRUMENT PANEL GAUGES, SUCH AS THE SPEEDOMETER. Remedy: DEALERS WILL REPLACE A MULTIPLEX CONTROL UNIT FOR THE INSTRUMENT PANEL LIGHTS. OWNER NOTIFICATION BEGAN JUNE 16, 2004. OWNERS SHOULD CONTACT HONDA AT 1-800-999-1009. Notes: AMERICAN HONDA MOTOR CO., P36
Nov 25, 2008 | 1997 Honda Odyssey
Do you I need to replace the thermostat on my 1999 Honda Accord as a preventative measure only?
No only if you have noticed a change in engine running temperature on gauge, colder or hotter than normal.
Aug 05, 2008 | 1993 Honda Accord
Vehicle Parts & Accessories Logo
18 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
