Question about LG WM2301HW Front Load Washer
Grease like stains on clothing after washing
Doesn't happen every time
    New Friend:
You have to clean the filter once a month. Which located lower left. Do a tub cleanse. Rinse extra. That will clear your problem. I have had the same issue and many repairmen and that was the answer. As long as I clean it than grease marks
Posted on Jan 01, 2015
    Top Expert:
  • LG Master
  • 43,980 Answers
Sometimes fabric softeners leave greasy stains
Posted on Jul 30, 2013
SOURCE: stains
This problem is caused from fabric softner, building up in the system and pipes. IT takes alot of flushing to get rid of this to remove it.  It will also be in the outley pipe.  Also there should be a draining plug undo this and then flush out the washing machine with a hose you will notice black gunk coming out.  Also remove the draining pipe and clean it out under a bath tape it will take many goes to clean it or just buy a new pipe.   Nonetheless a bit of elbow grease will fix it.  Good Luck  Kylie
Posted on Jan 09, 2009
  • 958 Answers
SOURCE: Clear greasy stains appearing on clothes from brand new LG front loading washer
the grease i'm sure would be coming from the machine. look at the water solenoids, detergent dispenser, dispenser solenoids, everything with rubber hoses.
they do put a clear grease just to insert the hose easier in the plant. and if it was not removed during QC, then it would come out now as you uses it.
tnx 4 using fixya,
drcool
Posted on Sep 28, 2008
SOURCE: Black marks on clothes
My wife complained that we were having similar problems recently. After investigation I located the remains of a pen entering the filter and removed this and did a few empty boil washes to remove any remains of ink and this worked for us. Check the filter and hose between the drum and filter.
Posted on Mar 03, 2007
Lady Spark
  • 51 Answers
SOURCE: oily spots on clothes after washing, no oil or
sounds like the seal at the base of the tub is allowing oil to leak from the bearing (that is allowing the tub to spin on the motor shaft.
Not much to do unless you are good with tools and can remove the tub and replace the seal. (This is sorta like the seal between the transmission and engine on a car, or around the main motor bearing)
Posted on Feb 03, 2010
SOURCE: grease stains on clothes from LG washer (tromm 2688)
I have the exact same problem and I have NEVER used fabric softner. My washer is less than a year old. It is wiped down after each use, the door is left open, and we clean the trap out at least monthly.
Posted on Jun 23, 2010
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
How to remove grease stain from laundered shirt
How to Remove Grease Stains ' Stain Removal
www.howtocleanstuff.net > ... > Clothing & Fabrics > Stain Removal
Begin by blotting with a clean cloth to remove as much of the grease as possible. ... If your clothing is durable, spray oven cleaner on the stain and let it set for ...
Oct 07, 2015 | Washing Machines
A407 maytag washer getting grease on clothes occassionaly what would the replacement part
Maytag washing machine gets grease on clothes ... - Fixya
www.fixya.com/.../t14582529-maytag_washing_machine_gets_grease
Oct 8, 2012 - Maytag washing machine gets grease on clothes occasionally. ... some of their clothes ruined by grease stains from their front loader Kenmore. .... remove the agitator from a Maytag washing machine Model A407 series 02?
Aug 24, 2015 | Maytag Washing Machines
OIL STAIN ON A CLOTHES out of washing machine E12477
Are they getting the oil stain from the washing machine? If so, you need to get a tech out to inspect your washing machine. If you are putting oily clothes into the washing machine hoping it will come out, it's too late, you need to pre-wash with Shout or Tide to remove oils and grease. The more you wash and dry it the deeper the stain will set. Sounds like you need to throw those clothes away.
Jan 20, 2015 | Washing Machines
Oil/grease stains on clothing
Dryer is much more likely
Nov 28, 2011 | Washing Machines
2nd time I have oil stains on my clothes from Whirlpool LSR9434PQ1 and nothing gets them out. Need to know how to get the stains out and what kind of washing machine is better so that I can replace. Spent...
You can try Lestoil to get the grease out, it has surfactants that will help break up the grease, if they aren't set too deeply. This seems to me to have a leaking transmission if you are constantly getting grease on the clothes. A better machine is anything newer that you can afford, quite honestly, there is only your preference to what you want/need for your usage.
Hope this helps, please rate service and comment, Thank You,
Joe
Sep 01, 2011 | Whirlpool LSR9434PQ Top Load Washer
My Sears Kenmore washer model #41743142200 is leaving extensive black grease stains on my clothing. It's been doing this in an increasingly serious way for a couple of months. Any idea why this is...
there should be a filter on the washing machine some where usually on the bottom left side on the front. u have to clean it every so many washes, years or somthing along those lines it should tell u on it. that should be it
Aug 23, 2011 | Kenmore Washing Machines
When i wash it goes through all cycles but it lets out these pieces of carton rubbery pieces it doesnt happen all the time
YOU MAY HAVE WASHED SOME ONES CLOTHING WHICH HAD THIS ITEM IN THE CLOTHING IF THIS IS JUST AN INTERMITENT PROBLEM. IT COULD BE CAUGHT UNDRE THE AGITATOR AND ONLY APPEARS SOME TIMES. THERE IS ONLY ONE PUBBER PIECE UNDER THE AGTATOR AND THAT IS A GREASE SEAL IF YOU START TO SEE GREASE STAINS ON YOUR CLOTHING THE SEAL HAS WENT BAD AND THATS NOT GOOD
Aug 10, 2009 | Washing Machines
A few clothing items have come out of the dryer with black stains on them - looks like grease. It happens a lot with sheets. I'm guessing it happens in the wash, but I'm not sure - it couldbe the dryer...
how old is the machine... 9 times out of 10 when there is grease deposits, the tranny is starting to go, and throwing grease in the machine. Happens with all washers near the end of their life.
Jul 30, 2009 | Kenmore Washing Machines
Grease spots and stains
Yes you can. Remember a front loader has no gearbox so no oil is coming from there? fabric conditioner, washing powder,and oils from our bodys can build up on the tub walls. All it needs is a good flush out. You can use dishwashing powder. Run it through with no clothes in you washing machine on a hot wash or a wash and hold a couple of times to flush it out. NZL
Jan 13, 2007 | Kenmore 20172 Top Load Washer
LG WM2301HW Front Load Washer Logo
530 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
