Question about Epson Stylus Pro 7600 InkJet Printer
Clear counter i have a message from my printer it is 00010005 what i need do
  • 3 Answers
How can i remove printer count?
Posted on Jul 30, 2013
How to fix brother printer drum error troubleshooting and routine maintenance
I still receive the error message "Replace Drum", "Drum End Soon", "Drum Near End", or "Drum Stop" after I replace the drum unit with a new one. The following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter as instructed below.
If you want to clear an error message related to the toner replacement, click here to see how to clear an error message after you replaced the toner cartridge.
"What is the difference between the toner cartridge and the drum unit?"
Please reset the drum counter only when you replace the drum unit. If you reset the drum counter during the life of the drum unit currently being used, the remaining drum life will not be displayed accurately.
  1. Make sure that the machine is turned on.
  2. Open the front cover.
  3. Press Clear or Clear/Back on the control panel.?
    NOTE: The layout of a control panel differs depending on the model, but the Clear or Clear/Back button is located on the right side of the LCD screen as shown in illustration.
  4. Do one of the following.
    • If your Brother machine has a numeric keypad:
      Press 1 to reset the drum counter.
    • If your Brother machine doesn't have a numeric keypad:
      Press the Up Arrow Key to reset the drum counter.
  5. When the LCD shows Accepted, close the front cover.
Sep 11, 2017 | Brother Office Equipment & Supplies
Maintenancecall 2
First it indicates that the drum needs to be replace along with developer. has that been done? Then who did it for got to clear the counter. Go to service mode Utility then stop 00 stop 01 . Then to # 9 Clear counter then to supplies life counter clear yes exit out
Apr 05, 2014 | Minolta bizhub 180 Black and White Copier
Xerox 6280 gets error message replace fuser kit, it was replaced and still has the same message
This is an easy one.
The original fuser supplied with the printer DOES NOT have a counter chip. Instead, the PRINTER assumes that when the number of pages printed reaches the level at which the fuser needs to be replaced, the printer issued the REPLACE FUSER message.
If you replace the fuser with another that has come OUT OF a new printer (i.e. a 'PULL' from a new unused printer), since it has no counter chip of it's own, the printer assumes the fuser pagecount is the same as the printer pagecount (because there is no information to read from a fuser chip), and still wants the fuser to be replaced.
A new REPLACEMENT fuser from XEROX, or a CORRECTLY refurbished fuser WILL have a counter chip, and therefore clear the REPLACE FUSER message.
Nov 28, 2012 | Office Equipment & Supplies
When we are trying to scan documents we get a message that says, "Please replace your PC drum"
Simply replace the pc drum.If you do not want to then do this,Press utility/counter buttonpress detailsnow press stop,0,0 stop,0,1 its the code to get into service modewhen you are in service mode press counter,in counter menu press parts life counter, select it and press "c" to clear its counter.clear all the counters like maintenance counter, life counter etc.after clearing restart the machine and this message will be gone.If you cannot do this then don't worry this message will not affect the print quality or even the machine.
Mar 29, 2011 | Konica Minolta Bizhub 222 Black and White...
I was getting a message that the transfer belt needed to be replaced and I replaced it. But the message won't go away.
try this:
1. Press # sign; then 1934
2. Press MENU
3. Arrow to Tech Mode (not User Mode); press OK
4. DataSetup; move arrow to Clear All Memory
5. Clear All Memory; press OK
6. Choose coonutry; press OK; will erase and print out configuration report; clearing the transfer belt error.
This wipes out the counter on the Transfer Belt. Clear All Memory means all your settings are wiped out. This also reset all the counters EXCEPT the imaging unit counter.
Trust this helps. Please vote.
Dec 14, 2010 | Samsung CLP 300 Laser Printer
The machine says "replace ozone filter" i did that but the message won't reset itself. is there something i can do to reset it?
On most models of Color Bizhub machines, to reset the ozone filter message you must go into service mode. Press the Utility/Counter button on your operation panel, select meter count, then detail, press stop,0,0,stop,0,1. This will put you in service mode. Find and press counter button, Locate life counters, and clear ozone filter. You will not be able to clear some of the counters in this menu. They are automatically cleared when the items are replaced.
Apr 23, 2010 | Konica Minolta bizhub C351 All-In-One...
Printer unable to clean
Your "excess toner cartridge/pad" is probably full. The reason it didn't clear when you turned it off is because your printer has a "counter" that didn't get reset during the power cycle. You can manually reset this "counter", which will clear the error and allow you to print. You have to bring the printer into Service Mode and find a counter and reset it, when you reset the correct one, it will clear the error.(sorry I cannot give you definitive instructions on how to do this)
But eventually your "excess toner cartridge/pad" will NEED replacing becasue toner will spill out of it and into the printer. Pretty simple, it's like a big sponge.
Reset the counter and you will print. But replace the excess toner pad soon.
Sep 21, 2009 | Brother MFC 210C All-In-One InkJet Printer
Canon mp730 Error message
Dear sir,
physically you can't replace that part ,its a EPROM counter, which shows you the error message .you can only reset the counter through that procedure.otherwise if you want to replace that part then you have to contact authorised Service centre , to replace that part.
Regards
Dec 17, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Epson Pro 7600 Service required error
You need to be able to clear the counters in the printer that tell the printer to stop working.
In order to do that you must
1. Turn printer off
2. you must hold down the "Paper Source, Paper Feed, Select Feed, Cut/Eject" buttons all at the sime time while you turn the printer back on.
3. From there navigate through the menues to clear the counter that pertains to you or all.
(Error 00000101 is pertains to the print head motor)
Word of warning -
Those counters can be a pain as they cause the printer to stop working however you do need to get your printer serviced by a tech as soon as you can because the error is a warning, reset the counters lets you finsih a job, but if it goes unserviced too long it will actually break down all togther.
So even after you rest the counters you absolutly must get your printer serviced soon.
Apr 17, 2008 | Epson Stylus Pro 7600 InkJet Printer
Epson Stylus Pro 7600 InkJet Printer Logo
172 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
