Dell Motherboard
Problem for Dell (F2273) Motherboard
Battery will not charge on a dell d610 when plugged into outlet
By fcheath2k on Apr 01, 2009
Light near keyboard does not come on indicating ac power is connected. Tried AC power cord on another dell laptop and it checks out good. Battery will not charge and will indicate several hundred hours remaining on charge while plugged into ac. System will stay on with battery pulled. Battery is known good and will charge in another dell laptop. pulled motherboard out and solder connections on power plug show no discrepancies and input power is measured at solder connector. Could this be a bios issue? Tried to flash to an older version, but unable due to system does not recognize external power is plugged. Any help with this issue would be greatly appreciated.
Same Problem
Apr 17, 2009
-   only starts with my battery in, will not charge it.... Says theres 1,000's of hours left but it ran out.... now it wont start and i think its a short.... n e ideas?
yhf971@gmail.com
-   Guest
Solution #1
posted on Jun 25, 2009
Somewhat Helpful)
isamb
Rank: Master
Rating: 86%, 10 votes
I have seen this with faulty batteries.
Try changing the battery.
Also, check in the BIOS that the adapter you are using is recognised and shows a state of charging with the battery in.
Was this helpful?
Yes
No
Popular Solutions for Dell Motherboard
Questions and Unsolved Problems for Dell Motherboard
Do you recommend Dell (F2273) Motherboard?
Answer
Answer
my computer is a dell inspiron 531. 2 1/2 years old. it developed shut down problems 2 months ago.... (More)
Answer
can you you tell me how i can fine a wedsite with a clear motherboad diagram with a step by step... (More)
Answer
La laptop funciona correctamente conectada a la red, pero no carga la bateria. Baterias (2) y... (More)
Answer
Mi dell latitude c640 no carga la bateria. Funciona conectada a la red, sin la bateria. Ambas... (More)
Answer
i need replaced mother boerd dell with gigabt in box of dell diemenion 8300 and i have problem with... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
