Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Distortion in lower part screen (blurry) after powered on
I own a Sony KDL-52XBR4 HDTV, anyways when I power the TV on on the lower part of screen I would say 2 to 3 inches high is blurred and distorted,all the way across and stays like that for a duration of time which varies. What are my options?
    Top Expert:
  • Sony Master
  • 75,462 Answers
It sounds that the CCFL lamp at the lower part is faulty. The fault is with its back-light itself. Check it. If you wish to get more details about these type of faults to LCD TVs, check the site linked here. It has stap-shot illustrations to these type of fault to LCD TVs; which I cannot include here by this window. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option.
Posted on Jul 30, 2013
SOURCE: clicking noise sony bravia kdl-40v3000
http://forum.ecoustics.com/bbs/messages/2/176039.html <-- Check that out.
Also I have a Sony Bravia and it clicks while it is on as well. I read that forum and some people said to disconnect the cable box for 10 sec. and then some said it was the heat from the summer.. i don't know.. I just turned my tv off and then back on and it stoped. I read this is happening with all kinds of TVs....
Posted on May 23, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Posted on Mar 14, 2009
SOURCE: 3 horizontal lines through screen and distortion
Yes this thing start happening to my tv too about 4weeks ago and this goes away in about 15 minutes. TV is only 18 month old and I donot have extende warranty. Please post the solution if someone has got it repaired. Thanks
Posted on Jan 21, 2010
SOURCE: Sony BRAVIA KDL-46XBR 46 in. HDTV LCD
I hope this helps
It seems Sony is extending the warranty on your TV
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
Posted on Feb 04, 2010
SOURCE: The TV has horizontal lines across about 5 inches
Horizontal lines are relatively rare problem in LCD TVs.
The likely problematic areas are:
1) The LCD itself (the micro ICs embedded into the LCD panel structure); that doesn't sound likely based on what you say, but it's not completely impossible. The bad news is it's mostly uncurable.
2) The power board A-1511-322-D G5
Power boards may sometimes cause problems with display, although rarely causing horizontal lines.
I wouldn't start looking here either, but it is certainly a problem to consider.
3) Main board 1-876-561-13 R1506072C
Slightly more possible and yet not quite likely. A high operating temperature and bad SMD soldering process may cause some soldering contacts on the main board to behave differently when the board is cold versus when it heats up. It is very common and may have all kinds of different effects on the TV and the screen.
One way to check for that is with a regular dryer..the process is explained in many other solutions at fixya and around the net, so I wouldn't repeat it here...but it takes time and patience.
4) The most likely place to start with is the T-Con / LCD controller
404652ASNC6LV4.1 M139.
I'd first replace that and see if the problem goes away.
5) There's a very minor chance that the LVDS cable that connects the main board with the T-Con does not make good contact initially and changes that as a result of getting hot. It's easy to just touch and move it lightly when the TV is still cold to see if it has an effect on the picture.
Sorry I couldn't just nail it for you, but that's the nature of the repair businss :-)
Bobby, www.coppelltvrepair.com
Posted on Mar 15, 2010
Red line vertical
This is usually an indication that the power board has had an issue at one time or another. Does it fade a bit after the tv has been on for more than 10 minutes or so? This happened to my daughters LCD tv after I repaired the power board. The expense to replace a video driver board or an lcd panel is usually more expensive than the tv is worth unfortunately.
Feb 23, 2015 | Sony Bravia Xbr Kdl-52xbr4 52-inch 1080p...
Tigerdirect.com
Have your TV check at Sony store.
Oct 22, 2017 | Sony BRAVIA KDL-52XBR4 LCD TV
Bottom half of Sony Bravia TV screen has color distortion
Check for loose contacts in power outlet, RC cable, jack and socket.
In order to ensure, it is not caused by the input device, connect a DVD player and see.
Aug 22, 2012 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I have a Sony Bravia KDL-52XBR4 LCD TV.
Sure, but not at minimal cost - it's a sony! Probably the t con board.
Sep 17, 2017 | Sony BRAVIA KDL-52XBR4 LCD TV
Hello my screen was hit with a object and is broken inside, i want to know wher can i buy a new screen for my kdl-52xbr? thank you
There are replacement screens available but I don't know if you'd be able to get an exact replacement for the broken one, but anyway they're expensive and you might as well just buy a new monitor.
Jan 23, 2011 | Sony KDL-52XBR4 LCD Monitor
I have a Sony Bravia 52" tv and the screen was hit
Not likely take to a qualified repair center. It will need a new screen
Nov 28, 2010 | Sony KDL-52XBR4 LCD Monitor
My TV will play fine for 10-20 min. after that the screen will go blank.I have no problems with the sound.When I unplug the power cord for a few min. and plug it back in the TV works
Hi
Please remove the power cord of the TV, if it is connected to any power surge box and connect it directly to wall jack or wall outlet. Do not place any magnetic items nearby the TV. Do not completely cover the LCD with plastic cover or cloth.
This should resolve the issue.
Jan 28, 2010 | Sony BRAVIA KDL-52XBR4 LCD TV
Sony KDL-52XBR4 has a tranparent vertical blueish line just to the left of center.
the panel is failing and will need to be replaced big buck hope it is under warranty
Dec 03, 2009 | Sony KDL-52XBR5 52 in. LCD HDTV
My sony bravia kdl-52xbr4 has a chip in it . looks like a little pellet hit the screen. how much will it cost to replace that screen?
Sadly, a replacement screen itself would cost more than the TV is worth.
Here are a couple of web sites selling the replacement screen:
http://www.partstore.com/GetModel.aspx?MfgName=Sony&BrandName=Sony&ModelNumber=KDL52XBR4&SearchTerm=True&Page=1&SortBy=price&SortDirection=desc#PartsearchSKUList
http://www.encompassparts.com/products/?1-802-490-31
http://www.encompassparts.com/products/?1-802-490-32
I know it seems like a crazy price. But, TV manufactures buy a mass quantity at a lower price. Where buying just one screen panel cost an arm and a leg. Buying a new TV is the best choice money wise.
Nov 09, 2009 | Sony BRAVIA KDL-52XBR4 LCD TV
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
143 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
