Question about Dataproducts 8524 Matrix Printer
Can not on line to print ,stay in p out,what can I do??pls help me
Just happen yersterday , when I what to switch the printer on line,but for the ribbon problem occur,the printer turn to the light p out,now the ribbon ready ,I switch the on line but still stay in the p out light , what can I do?
I replaced the cartridge of my hp psc 1401, copied the test page that was automatically printed, but now I can't print anything. Copying works OK. I don't get an error message or blinking lights on...
what is the status of print job in the queue? whether it is showing printing or no status in the windows.
if the status is printing you delete all the print jobs and switch off and on .then try print something. if no status is there in the windows then you check whether the printer is off line .try make it online by right click on the printer icon then click on the use printer online.
Aug 10, 2011 | HP PSC 1401 All-In-One Printer
When I print tables, the lines come out crooked. Any idea what the problem could be?
do the print head alignment... to do this..first switch OFF the printer and then load paper, press the Pause button while switching ON the printer.. the printer will then print the instruction for you to align the print head. Just follow the instruction and select the best printed line.
If when you print text or line, and you notice there is some part missing, this show that you print head have broken pins. If this happen, you will have to replace the print head.
Jun 14, 2010 | Epson LQ 680 Matrix Printer
My hp deskjet 3745 wont print because it is off line. how do i get it back on line and for it to stay that way. this happens often.
hello lblb45. Under control panel - printers and faxes - doble click on your HP printer and you will see the status of the printer (either printer offline, out of ink, or out of paper, etc. Click on printer option on the top and unselect the "Use Printer Offline" option. That usually happens because the print spooler service looses connection to the printer at some point. Did you try with another USB cable or reinstall the drivers? I hope this helps.
Jun 03, 2010 | HP Computers & Internet
Printer does not go
After few head cleaning, ink counter running low, so ink ligh (red) flashing. Then ink counter runing out, so the light stayed on. After replacing both of ink, red light stayed on, because the compatible ink (chip) not recognized by printer. Check epson status monitor. Use original ink or refill and reset ink level counter.
May 26, 2010 | Epson Stylus C60 InkJet Printer
Printed output has white lines....
white lines mean ur cartridge working not good change cartridge or clean incotter (printers part )
Apr 07, 2010 | HP DeskJet D1460 InkJet Printer
White lines across my printing.have cleaned print cartridges and aligned cartridges. Still white lines are through all solid areas.
havwe you tried manually cleaning the cartridges with clean cloth and a dab of alcohol? if not pls do and tell me what happens
Jan 08, 2010 | HP Photosmart 2575 All-In-One InkJet...
Drum light stays on after replacing
C- Auto- C -Auto . 24 Print, 07 Print , then press CCC three times.
Pls? try so that)
Dood luck!
Sep 15, 2009 | Sharp AL-1642CS Copier
Canon ip1000 printing problem,pls help?
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 26, 2009 | Office Equipment & Supplies
Epson Lx300+ printing problem
hi
pls check printer test print
  1. switch off the printer .
  2. insert paper in printer
  3. hold the button ll/ff pressing .
  4. switch on the printer
if you get test print OK then. you need to be Reinstall Printer Drivers on your Pc
May 22, 2008 | Epson LX-300 Matrix Printer
Samsung ML-1710 Laser Printer
Hi, On another posting of a similar problem, I proposed this solution: In some instances, the PC switches off a USB port. You may have to un-check "Allow the computer to turn off this device to save power." This is in your Device Manager/Universal Serial Bus Controllers/USB Root Hub. Hope this be of some help/idea. Pls post back how things turn up or should you need further information. Good luck and kind regards.
Apr 24, 2007 | Samsung ML 1710 Laser Printer
Dataproducts 8524 Matrix Printer Logo
27 people viewed this question
Top Dataproducts Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Dataproducts Office Equipment and Supply Expert? Answer questions, earn points and help others
