Question about Garden
Replaced the string and the spring came out - Garden
  • 1,807 Answers
There is a couple of video's on youtube, i'll send you the links.
Posted on Jul 30, 2013
Why won't mypull string recoil
when it broke it may have unwound. the spring has to be wound up before it will recoil. you tube has many videos to show you how to rewind the spring. be careful as when wound up it has pressure on it. also be sure to back it off one turn past the string hole so if you pull all the way out it will not break the spring.
Jan 30, 2016 | Garden
How do you get the starter string to rewind after it has been replaced
Did you preload the Spring before tying the string back on>
May 25, 2015 | Troy Garden
I have a smith corona electra 220 and the space bar does not advance the paper tot the next spot. everything else works. took the back cover off,a nd found a loose string coming from a black spool. can you...
That is what we call the draw string, there is a spring loaded pull that this string is. Wound around. The pulley has to be wound up and. Then the string fits in a. Little slot. Somme times the spring breaks in the pulley, the string fits in a slot by .a knot which sometimes breaks, sorry about the bad news, the string is fishing line and wears out as it gets old.
Jan 28, 2014 | Office Equipment & Supplies
Blower string wont retract
you might have installed the wrong spring type, check also the stopper or the lock inside that holds the spring secure.
Jun 04, 2013 | Garden
My pull string came off my lawn mor.i replaced but dont know how to rewined it back up help is there a trick to it.
You have to wind the spring and the housing that holds the spring. Then insert string in and tie the end in a knot. Probably like you have it now. But you have to wind the spring first.
Oct 02, 2010 | Craftsman Garden
Have a S-M portable (5T231908X). -String Off Rewind Spool
Wind the spool clockwise at least 5 rotations. hook the string on the top and carefully let the spring take up the slack. You will need a hook of some type to pull the string through and under the carriage to hook to the other side. You may need more tension on the spring if it will not move the carriage all the way to the left. It is possible that the spring has broken inside the housing. In which case you will have to take it to the shop.
Dec 22, 2009 | Office Equipment & Supplies
Typewriter string is losehow can i reconnect it
Did the string break? Possible that the spring broke inside the housing, If so, then you will have to take it to a shop. I am in Largo Florida and can fix it. If you have a new string. Connect it to the right side of carriage then pull it through with a hook. Then wind up the spring clockwise several rotations then hook up the string and carefully and slowly let the spring take up the slack.
Pull string came off as I was trying to start it.
there should be three or four screws to the top of the mower where the string goes, after purchasing new pull string make sure you wind the spring when you re string, so that when you put the cover back on it will be spring loaded and in proper working condition
Oct 17, 2009 | Ariens Garden
Need help putting my guitar together
The "handle type thing" is a Tremolo or, more often referred to as a "whammy" bar. The thing at the base of the strings is called a bridge. Looking at the strings, there should be a hole to the right of the smallest string. If your "handle" is threaded, stick the threaded end into the hole and rotate in a clockwise motion. Once is hits the bottom of the threads, back it off one turn and gravity will let it hang out of the way while you play. If there are no threads, it will slip in and you will feel a "click" when it's in the proper position.
On the back of the guitar, there is a cover plate that covers the cavity where the springs are located that make the "whammy bar" work. The springs hold tension on the bridge so you can tune it and play normally, but let the "whammy bar" stretch or release tension on the strings when you push or pull it. If you already have springs inside the cavity, the extra spring you have will let you add more tension to the bridge, but you probably won't need it. If there are no springs already installed, you can install your "extra" spring in there to give you the flex and spring for the "bar-handle" to work properly.
To install a spring, loosen or remove your guitar strings, open the cover on the back, and install the spring over the hooks on the bridge and the hook on a metal bar on the other end of the cavity. Replace the cover, insert your "handle", and wiggle-away.
The allen wrenches are most likely for adjustment of the moveable pieces that support the strings on the bridge. The bridge has adjustments for up and down, and forward and back to adjust the height and distance where the string is supported. Don't adjust the bridge supports unless you loosen the strings. It is highly recommended that you don't make any adjustments yourself unless you are familiar with the mechanism. You can adjust your guitar where it's impossible to keep in tune if the adjustments are not perfect. There are usually guitar repair shops close by and offer "set-up" services to get your instrument adjusted properly. It's well worth the money to have it done right, and the service people with often teach you many things that will help keep your instrument playing well.
Hope this helps.
Jim
jimmydsmith@cox.net
Phoenix, Az
Jan 10, 2009 | Fender Squier Std Strat Mn Car
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
