Question about Dryers
Troubleshoot error code kenmore dryer model #41784082500
Dryer heating element was replaced, because it wasn't heating up and drying. Now panel shows an error code of A6 or Ab what does that indicate?
catriver
  • 878 Answers
SOURCE: replacing the heating element Kenmore dryer 110 64892
nestor, on the posted model, you want to drop the lower front panel. Take a puddy knife and push in on the clips on each side and it will pull off. Kill the power to the dryer. On the right you will see the heater housing. The housing will have a front deflector. You can remove that deflector by removing the screw on the bottom or simply just bend it down out of the way. Remove the 2 wires on the left that attach to the element itself. On the left side of the housing there will be a quarter inch screw that holds the element in place. Use a small socket set to get it off. Now the element will pull right out of the housing. Sometimes they are difficult to pull out but it will come out. Did you ohm out that element to make sure that was the culprit? Catriver.
Posted on Dec 09, 2007
SOURCE: Heating element
It was very easy to do on my dryer. Kenmore 80. Removed 8-10 screws. Ordered a new element on Thursday afternoon from
http://www.pcappliancerepair.com/index.html, had new one Thursday morning at 9:00 am. Paid for shipping on 3-7 days got it less than 24 hours. Plus paid $10 less than Kenmore site.
Posted on Mar 06, 2008
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
  • 1028 Answers
SOURCE: how to replace heating element, kenmore model 110.60912990
lint screen in door ? remove bottom apnel ..top lint screen remove rear panel both cases ckd thermal fuse on top end also
Posted on Jul 05, 2008
hunter19_46m
  • 7482 Answers
SOURCE: LG Dryer won't dry, no heat.
The heating coil is not too big of a problem to replace if you are mechanically inclined and have tools to do the job.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Posted on Oct 17, 2009
Dryer won't heat. How can I keep troubleshooting?
You may have to get a new heating element when they go out the jet dryer where the heat comes out will not work normally this is caused buy a bad heat element. If not take back panel off and check the little white fuse and replace it, Almost all dryers are the same in that area.. Hope that helps....
May 15, 2017 | Kenmore Dryers
Why won't my Kenmore dishwasher display work properly?
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
My Frigidaire Galaxy Series dryer (model GLEQ2152E) runs but does not heat. I get a E5B error code (which may point to the DL2 heater relay). However, Im pretty sure I caused the problem - It was drying...
I am not familiar with electronic codes, but I am with dryers that do not heat.
Here are the most likely problems, from the most likely first to the least likely last.
1)You have a set of overheat thermostats and a replaceable fuse in the back and/or bottom of the machine. These are to prevent a fire should the dryer overheat. Perhaps one of these has tripped, and needs to be replaced. There are between 3 and 7 of them. All require taking the machine apart
2) Less likely is the heating element may have burned out.
3) Least likely is that a wire may have burned in two somewhere in the back or bottom of the machine, also needs to be repaired. Be blessed.
Jun 23, 2013 | Dryers
My Kenmore 6.7 cu ft he2 Super capacity electric dryer is taking twice as long to dry. no error codes
It sounds like a connection problem with one of the heating elements, or perhaps only a clogged input or output hose from the dryer. Either of these could cause the problem...also, a burned out electric element.
Jan 15, 2013 | Kenmore Dryers
Kenmore gas dryer heats poorly
You either have a heating element going bad or thermostat.
May 24, 2012 | Kenmore Dryers
My dryer doesnt heat. I checked the voltage, and ran through all the diagnostic tests to try to get an error code. Everything works fine when in the test mode. Figuring that all was well i went back to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'
Jul 17, 2011 | Kenmore 84072 Electric Dryer
Kenmore dryer has will not heat up to dry
IT SOUNDS LIKE YOUR HEATING ELEMENTS HAVE BURNT OUT FIRST TURN OFF POWER THEN LOCATE THE SCREWS HOLDING THE BACK PANEL ON REMOVE THEM AND PANEL YOU SHOULD SEE THE ELEMENT REMOVE IT FROM THE PLUG I WOULD ALSO SUGGEST YOU REPLACE THE TERMOSTATS AS THE TEND GO THE SAME TIME OF ELEMENTS TAKE THEM TO A ELECTRICAL AND PLUMMERS SUPPLY STORE FOR REPLACEMENT REFIT TO YOUR MACHINE AND IT SHOULD WORK FINE , GOOD LUCK .
Nov 30, 2009 | Dryers
No heat in kenmore series 80, model 85040
hello there:
here is some troubleshooting ideas for you to help
A dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty
Oct 26, 2009 | Kenmore Dryers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Kenmore Dryer, Model # 11063102100, does not dry.
Does the drum still turn. If so probably just needs a new heating element. VERY easy to replace. Usually instructions to replace on or in new element box or just google instructions.
New heating element would be my first move to repair dryer.
Also, if you use softeners or dryer sheets, Wash lint screen with dawn and soft scrub brush to remove oils and residue (even if it dont look like there is none there there is) to extend your heating element use.
Sep 26, 2009 | Dryers
Dryers Logo
63 people viewed this question
Top Dryers Experts
