Question about Hayward Pool & Spa
Hayward 1hp super pump-self priming -rebuilt won't run
I just replaced the shaft seals in my pump. reinstalled impeller and all covers. Primed pump and started it up--ran for 30 sec then popped GFI. reset-turned on and each time now as soon as pump starts GFI pops. Test ran pump on bench and had no issues then. Could I have tighten impeller to much, or installed something incorrectly. Thought I had put together as it was taken apart. Thanks for any help!!
    Top Expert:
  • Hayward Master
  • 5,775 Answers
Something is binding take apart and try again
Posted on Mar 05, 2016
SOURCE: Lossing Prime
It's pulling in air very slowly from somewhere:
priming pot lid,
valve body tops,
valve handles,
pipe unions, --
check gaskets/o-rings-- replace defective ones, lubricate
tighten everything possible
Posted on Apr 22, 2009
john224
  • 1378 Answers
SOURCE: HAYWARD SUPER PUMP 1HP. ABOUT
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
Start with the capacitor if one is present. Use a digital multi-meter (DMM), preferably with a capacitor setting, or an analog meter set for Ohms. With an analog, you should see the needle deflect as if testing a closed circuit then it will slowly drop to 0 if the capacitor is good. If it doesn't move or moves and stays to the side showing a closed circuit the capacitor is bad. If you notice a burn hole near the terminals on the end of the capacitor do not bother to test it. If you do not have access to a meter you can try grounding the posts together with a screwdriver to see if they arc although it is not a very reliable test method. Be sure you are holding on to an insulated handle for the tool you use to short the terminals together or you can get a good poke.
Next check the internal stationary start switch for continuity thru the contacts. Bent or burned up points and arms can cause a startup failure...you may need a new part if yours is more than bent out of position.
Finally check the winding for grounds and shorts...if you find any it is most likely time for a new motor.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage. If you wish to continue to try to repair it yourself please comment with any questions you have as you work thru the pump and motor.
If this answer does not fix your problem, please comment with additional details or contact me thru our site at www.arrowpools.net prior to rating the answer; I'll do what I can to help. Positive feedback is appreciated once your problem is solved!
John
Posted on May 21, 2011
MOTORWIZJ
  • 1343 Answers
SOURCE: taking the impeller off to
OH BOY, THESE ARE FUN. I TAKE THE MOTOR COMPLETELY APART AND PLACE THE ROTOR IN THE VICE, AND WITH A PAIR OF SLIP JOINT PLIERS TRY TO REMOVE THE IMPELLER . I GET ABOUT 3 OUT OF 5 OF THEM OFF.. AND I'M GOOD BABY.. THE IMPELLERS FOR THESE ARE CHEAP, ITS THE MOTOR YOU WANT TO TRY AND SAVE !
Posted on Jun 04, 2011
ftw1952
  • 10319 Answers
SOURCE: I just replaced a seal
a swollen armature will start if spun by hand but not by it's own power when faulty
replace the armature
Posted on Jun 17, 2011
SOURCE: Just installed new Hayward 1
my super pump was under water for several hours from the hurricane i turned it on its working yet it sounds different will it be o.k or is thier something i should do to avoid a problem.
Posted on Aug 29, 2011
My Hayward 1 hp super pump will run for a second and then trip the gfci. What has happened? Thanks.
Normally the GFCI is doing its job.
Water is getting into the internal of the motor.
Try replacing your Shaft Seal
Jul 31, 2012 | Hayward 1HP Super Pump II Inground Pool...
Have a hayward 1.5hp motor. plastic impeller broke off and is not spinning, how do i replace.
YOU WILL NEED A NEW IMPELLER SPX3010C SUPER HAS 4 BOLTS OR A SPX261OC SUPER 2 HAS 6 BOLTS. JUST TAKE THESE BOLTS OUT AND THE IMPELLER SCREWS OFF TO THE LEFT, CLEAN UP THE TREADS. USE A NEW 201 SHAFT SEAL. AND ON THE MOTOR PICTURED THE SHAFT CAN BE HELD AT THE BACK OF THE MOTOR TO SCREW ON THE NEW IMPELLER.. PUT IT ALL BACK TOGETHER ,PRIME THE PUMP WITH ABOUT 4 GALLONS OF WATER. RUN IT AND WATCH FOR LEAKS .. NO LEAKS ? YOU GOOD TO GO ! ..
JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL .. GIVE ME A VOTE IF'N I WAS OF HELP 2 YA
Jul 06, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
Hello I'm trying to dismantle my hayward pump, but can't seem to able to remove the turbine... without forcing it too much....any tricks?
IT TURNS OFF TO THE LEFT, YOU NEED A 7/16 OR A 11 mm WRENCH TO HOLD THE ROTOR AT THE BACK OF THE MOTOR.. LOOK FOR THE NOTCH IN THE SHAFT UNDER THE SYNTRIFICAL SWITCH ASSEMBLY , BE CAREFUL NOT TO BREAK ANYTHING ON THE BACK OF THE MOTOR. REPLACE THE SEAL ! THERE IS A GUY SELLING SHAFT SEAL HAYWARD SUPER PUMP MOTOR REPAIR KIT & how to
ON EBAY .. HEY YOU .. PRIME THAT PUMP AFTYER ANY PUMP REPAIR !! THERE NOT SELF PRIMING UNTIL THERE INITIALLY PRIMED IN FIRST PLACE !!! AKA PUT WATER IN THE PUMP !.. IF I WAS OF HELP CLICK ON THAT (YES) BUTTON ON THE BOTTOM LEFT OF THE PAGE.. REMEMBER A CLEAN POOL IS A SAFER POOL .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA ..
Jun 11, 2011 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Pump difficult to prime-surges-will not pick-up??
let the air out of the filter as you try to start, this makes it hard for the pump to pick up the water. i would check the impeller and shaft seal,and basket for cracks, if the basket is cracked 99% of the time the impeller is plugged ..shaft seal there is is one one ebay with how 2 for around 10 bucks SMART ! PRIME the pump after a repair !!
Jun 06, 2011 | Hayward SP3015X20AZ 2 HP SUPER PUMP II ...
I have a 1 hp hayward super pump. the model # of the motor is C48K2n143B1. I need to replace the motor only. is it a big deal?
If you've never done it before, it can be a bid deal. You will need to get the exact replacement motor (1hp square flange), a shaft seal, impeller wrench, and be prepared to replace o-rings and rewire the new motor. If you're not comfortable dealing with electrical/mechanical, you're better off getting a service tech to help you out.
Sep 15, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Pump motor will not turn over without manual priming?
All pumps need to be primed. The Self-Priming pumps still require water in the basket.
If water is not staying in the plumbing system when it is turned off, then you have a leak in one of the o-rings or the shaft seal.
Sep 04, 2010 | Hayward 1 12 Hp Super Swimming Pool Pump...
Water coming out down by motor , pump is pumping but leaking. how do you get impeller off
sounds like a shaft seal leak..... cut power to pump ... unbolt the motor at the seal plate and pull motor from pump... take electrical cover off back of pump and hold the shaft at the middle (may have to do some digging to find it) of the back of the pump... now youll be able to remove the impeller by spinning it counter clockwise...
make sure you dont go cheap on the seals... and make certain to replace all seals on pump
(diffuser oring, housing gasket, shaft seals, and lid gasket
May 23, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
Leak between seal plate and pump/strainer housing
The pump seal is leaking and needs replacing and requires removing four 3/8 bolts (9/16) wrench and removing the motor then the diffuser to get to the impeller and seal . A 7/16 wrench holds the rear motor shaft behind the springs and impeller spins off to reveal the seal which has two parts one on the impeller with a spring and one in the seal plate is white ceramic/ porcelan whatever they use. Part number is an SPX1600KA on super pumps and 1500KA wassome above grounds. When replacing do not touch the mating white and black surfaces with your fingers.
May 25, 2009 | Hayward 1HP Super Pump II Inground Pool...
How do you change a pump seal on a hayward 1hp pool pump
The seal is located behind the impeller. Once you remove the impeller it is fairly obvious how to replace it. Basically, unscrew everything, replace it and put it back together again. There is a decent diagram on page 11 of the Hayward owners manual found here if you need it. http://www.haywardnet.com/products/Manuals/pdfs/Manual113.pdf
May 13, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Lossing Prime
priming pot lid,
valve body tops,
valve handles,
pipe unions, --
Apr 10, 2009 | Hayward 1HP Super Pump II Inground Pool...
Pool & Spa Logo
22 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
