Question about Microwave Ovens
Sharp carousel microwave reset
I have a Sharp carousel microwave oven that will not reset after being unplug briefly. The numbers flash and thats it. Tried unplugging it for a while but this did not change anythting. Thx
  • Teola Brown Aug 01, 2013
    I unplugged the microwave for a few minutes and plugged it back in to use it but the panel flashes and I am unable to reset it. The panel flashes and non of the number buttons will operate for use.
MicrowaveSvc
  • 9047 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: My Sharp Carousel R-510HW 1200
On these models, the LCD is connected to the main control board via a rubber connector known as a "zebra strip".
Sometimes the connections can get contaminated.
One can take the control board off and clean the contact surfaces of the board, the edges of the zebra strip and the connection side of the LCD glass with high-grade isopropyl alcohol.
See drawing below.
If you don't want to tackle this, we do it for $39.95 for customers nationwide.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 08, 2008
SOURCE: Control Panel for Sharp Carousel Microwave Oven
would you help me to find..
driver Acer Nplify 802.11b/g/Draft-N WLAN
Posted on May 07, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Carousel Model R-1440 won't stop running
It may be a sticking door switch (upper or lower, not the middle one) or the mount of one of those switches may be loose, broken or out of alignment.
See these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you can get to the switches.
Or it may be a sticking relay on the control board. We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
If during this unwanted operation the oven lamp, internal cooling fan, and stirrer are all stuck on, but the turntable is not on moving and the oven is not actually cooking, then I would suspect relay RY1 on the control board is stuck.
That's what I suspect in your case.
Posted on Dec 13, 2009
SOURCE: Wattage Sharp Microwave Ovens Carousel Model R-3A35
i just checked my R-3A36 manual to find out the wattage. it's 800 watts. i make pralines in my microwave. i am always asked for the recipe. so i needed to be able to tell people the wattage of my oven so they can adjust the recipe to their oven.
garry, metairie,la.
Posted on Dec 14, 2009
Magnetron part for a sharp carousel Microwave oven Model R-930ak
Maybe a faulty magnetron but check for abnormal noise caused by faulty diode pack. If you are in UK google the part number
RV-MZA114WRE0
R930AK Sharp Sharp Microwave
Apr 07, 2017 | Sharp Microwave Ovens
User manual for 1200 w carousel ser# 57088
Free Sharp Microwave Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Sharp > Kitchen Appliance Sharp
Products 1 - 50 of 359 - Sharp Microwave Oven 11452 User Guide. Pages: 0 Saves: 0 ... Sharp Operation Manual Microwave Oven R-308H, R-305H. Pages: 0 ...
Free Sharp Convection Oven User Manuals - Kitchen .
Nov 15, 2015 | Sharp Microwave Ovens
I cannot reset clock
Touch Timer/Clock pad and number 2 pad.
Enter the correct time of day by touching the numbers in sequence.
Touch Timer/Clock pad again.
Aug 15, 2015 | Sharp Carousel R530EST Microwave Oven
Sharp Carousel Model R-209KK-W is flashing all 8's and keypad not working
The first thing to try is to do a hard reset.
Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still doesn't work, it may need repair, which can be done for $39.95 in most cases.
Jun 10, 2012 | Microwave Ovens
I have a sharp carousel microwave model r-120D. It is flashing all 8's like so 88:88 and i cant get it to reset or work at all. Can you help?
usually does this after power outage. reset the clock. go to sharpusa.com and select PRODUCT DOWNLOADS under the CUSTOMER SUPPORT menu...select product not listed in drop down list, then enter R120PK in box....this should be the manual for your microwave
Dec 10, 2010 | Sharp R-120D Microwave Oven
User Manual Needed for Sharp Carousel Microwave Model R-303CW
mcdevito75 here, Best Bet, contact Sharp online, try sharp microwave oven.com Or in any store that sells Sharp microwave ovens get contact info off that package.
Jul 07, 2010 | Sharp R-303CW Convection / Microwave Oven
Does model, R 4A94 sharp carousel microwave oven have reset butto
I don't know of a reset button but there is a fuse that you have to remove the outer cover to get to that has a habit of blowing
Oct 14, 2009 | Sharp Microwave Ovens
Sharp carousel II microwave/convection oven
The question is... Do you want to put money on a 18year MW, or put it towards a new one? I must admit I love the SHARP Combo MW Convection ovens. I own two. One is almost 25years old. The mechanical Timer Type, but they work great and I can maintain them with 30years ef exrerience. I am now retired.
It does sound like the Magnetronhas broken down, however it could be other things in the Secondary (High Voltage Side). The High Voltage Side is made up of the Secondary HV side of the High Voltage Transformer, A High Voltage Diode, a High Voltage Capacitor, and the Magnetron. The High Voltage Side is DANGEROUS, and CAUTION should be taken to protect yourself against EXTREME HIGH VOLTAGE. unplug from power and DISCHARGE High Voltage Capaciton to frame GROUND before touching anything!!!!
Jan 29, 2008 | Microwave Ovens
Microwave Ovens Logo
215 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
