This is a new Gaggia New Espresso006 Dose machine. I cannot figure out how to remove the Shower Holding Plate to clean it, the gasket and surrounding portifilter holder. Previous Gaggia Carezza had two allen screws. This Holding Plate has two notches on opposite sides with what appears to be a screw hole in the middle. The machine did not come with instructions for this.
I'd say unscrew the screw and pry the thinger off with a palate knife.
Same Problem
Apr 22, 2009
-   I have the exact same proble. The machine did not even come with the gasket and there is no seal with the filterholder and therefore the machine cannot even pressure up.
If I find out how to do it I will let you know.
-   vgbrown
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
I tried grinding my beans less fine, putting less espresso in there, I don't know what to do. I did...
(More)
I tried grinding my beans less fine, putting less espresso in there, I don't know what to do. I did some dummy shots with nothing in there at all and it was doing the same thing. It's my mom's old machine and it used to work fine, but I'm scared she broke it. Bah.
how do I remove the base of a KitchenAid JAVASTUDIO? KCM534 14-Cup Coffee Maker? It has a small leak...
(More)
how do I remove the base of a KitchenAid JAVASTUDIO? KCM534 14-Cup Coffee Maker? It has a small leak from the resevoir
new coffee maker made 2 pots then overheated and only brewed 2 cups coffee and used all the water. ...
(More)
new coffee maker made 2 pots then overheated and only brewed 2 cups coffee and used all the water. coffee machine was blazing hot
