My grandson has a dell dimension xps gen2 computer with a raid 0 hard drive configuration. He required replacement of his cmos battery, which has been done. Now the computer will not boot into windows
My granson's computer required a change of cmos battery, which has been done. Now it will not boot into windows xp. It simply defaults to "press F2 to enter setup". As near as I can tell the setup values are appropriate for the system. After failure to boot I cleared cmos and re-entered new but correct values (I think). The system still fails to boot. Any suggestions.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 17 Answers
Go into bios (F12 key on startup) and prioritize boot order to HDD on the very top
Posted on Jul 30, 2013
frcs68
  • 1605 Answers
SOURCE: Dell Precision 470 Dual Processor
enable "auto" in BIOS for drive #0 and drive #1. you can select IDE or SATA drive. restart the machine.
Posted on Dec 10, 2008
  • 258 Answers
SOURCE: can't reload XP
Depending on the age of your PC it may have Dell automatic recovery
During startup at the Dell Screen hold down the CTRL key and tap F11 twice
It may display the Dell Recovery from which you can set your computer back to factory settings
Please note all your files will be deleted
Posted on Jan 25, 2009
  • 1043 Answers
SOURCE: OverClocking Problem when startup my system
Most motherboards have settings that allow the board to try and overclock itself upon bootup. Take a look in your manual and it should lead you to the correct setting in the bios that will allow you to have the computer boot up in normal mode. Failing that, you may have to force the motherboard back to the default setup. There is a jumper you would have to move, then you would remove the battery from the motherboard. Check your manual for how to clear the CMOS settings if you need to do that step.
Posted on Jul 10, 2009
FixinFax
  • 3085 Answers
SOURCE: boot up screen says "diskette drive 0 seek failure"
Press F2 look through the menus and remove / disable 3.5 floppy drives.
Posted on Jan 06, 2010
Subhagya
  • 59 Answers
SOURCE: I installed a new WD hard drive and now upon boot
I would recommend you to change the CPU fan as it may nt be working fine and that should resolve the problem.
Posted on Mar 23, 2010
Drive replacement and rebuilding Raid 1 on a Dimension XPS Gen 2
Did you format the new drive? Formatted size must be the same or bigger than remaining drive.
Mar 07, 2014 | Dell Dimension Computers & Internet
Drive replacement and rebuil ding Raid 1 on a Dimension XPS Gen 2
Hmm,tricky, I think your best bet would be to save old drive and do a complete new programme install hopefully you have the discs, then once setup and running, connect old drive as a backup and transfer data you require, there may be a better way, this is what I would seriously consider.
Raid failure on Dell Dimension XPS 410 PC
A flag will pop up that says you RAID volume is degraded. Down in the task bar area.
Jun 22, 2012 | Dell Dimension 8400 PC Desktop
I have two WD1600s, in RAID 0 configuration, on my Dell XPS, XP. One has failed. Can I just buy another one and reload the OS? Will any WD1600 do?
If you have a Raid 0, then both drives are tied into one. You could remove the bad drive, and just use the leftover one. But you would need to disable RAID in the BIOS.
Unless you know how you benefit from a Raid 0, I do not recommend keeping a Raid 0 if you have important files you need to keep.
you could also buy another drive, disable Raid, and install the operating system on the first drive, and keep leftover files like pictures etc on the second drive.
May 03, 2011 | Western Digital Caviar WD1600 (1600YD) 160...
WHAT CAN USE TO REPLACE A MAXTOR 7Y250MO HARD DRIVE? IT IS IN A 6 1/2 YEAR OLD DELL DEMENSION XPS GEN 2 TOWER RUNNING WIN XP. THE OS CAN NO LONGER FIND THE DRIVE AND WILL NOT BOOT UP. I WOULD LIKE TO...
The Dell Dimension XPS GEN2 has support for both, IDE and SATA standards. Your Maxtor is SATA drive, you can use any SATA drive as replacement. You mentioned that the OS no longer find the drive, make sure that you load SATA drivers at your Windows XP reinstallation, maybe your old drive is not defective only not recognized in the installation process. You can download the floppy image with required drivers here, see SATA drivers section. When you start Windows installation, at the Windows Setup Screen you should see, at the bottom of the screen, a message saying "Press F6 if you need to install a third party SCSI or RAID driver." At that point press the F6 button and when the next screen appears press S key to specify an additional device. Select the drivers from the provided list(to load all drivers from the disk, beacuse I don't know which is yours as I don't know the content of the disk, repeat steps to specify additional device), after drivers load your hard drive should be recognized and you can continue installing the Windows XP operating system. Ignore these steps if your hard was already tested and confirmed that is defective. Good luck!
If this is the solution for your problem, please rate my post, otherwise give us more details.
Regards,
Andras
Sep 26, 2010 | Dell Computers & Internet
Can't set up RAID on my Dell J3492 Motherboard & replaced harddri
It's unclear about which version of windows you are trying to install.
However please checkout http://www.legitreviews.com/article/454/1/. The page has step by step instructions for installing Windows Vista on a Raid Machine.
If you are looking for a different solution please let me know with a clear description of your requirements.
Hope this helps. Best Regards NextDoorNerd
Jul 30, 2010 | Dell Dimension 8400 PC Desktop
Turned off raid, unable to access 2nd 160 gig hard
Right click on Computer in the Start menu. You should see manage.
click on manage and you will see some selections the left one called disk management. click that and you should see all your drives. If you disable the Raid you may have to initialize the disk for windows to use it again. right click on the drive and initialize or if it shows up you may have to create a partition and then format.
Mar 08, 2010 | Dell Dimension 3100 PC Desktop
I would like to create a RAID array on my Dell Dimesion 2350
Hi there
Download the raid drivers from Dell if you need them.
You have to go into the bios settings to enable raid, look to see what raid options you have and choose them accordingly to how you want your raid configuration.
Thanks for using Fixya!!!
Feb 02, 2009 | Dell Dimension 2350 PC Desktop
Raid failure
The only thing RAID 1 does is make a real time backup of everything you do in real time. Its like having a mirrored hard drive. You dont really need it per say.
Dec 27, 2008 | Dell XPS 410 PC Desktop
Raid failure
Not a lot of details, but here is some basic information, assuming you have a Dell with Integrated RAID
Dimension 9150/9200 and XPS systems have RAID, depending on the model the exact troubleshooting differs. At boot, after the Dell screen, you should get the RAID status listing. RAID 0 will either be normal or failed. Raid 1 can be normal, degraded for failed.
If the RAID array was RAID 0 and one of the drives failed, then all data is lost and you'll have to create a new array then reinstall Windows and drivers
If the RAID array was RAID 1, then you may need to add the new drive to the Array, CNTL+I or CNTL+N at boot (Depending on the system model) add the new drive to the array and reboot. If the system still will not boot to Windows, then you may have a software error too with the OS.
If during troubleshooting, the array was broken in the RAID BIOS, then the array will need to be recreated and Windows/Drivers reinstalled.
Jun 11, 2008 | Dell Dimension 2350 PC Desktop
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
