Question about Kenmore Dryers
Dryer won't heat. How can I keep troubleshooting?
A single Mom I'm trying to help has an old Kenmore gas dryer (Model #: 87873100). The dryer starts just fine, but cools down after a few minutes and doesn't ever heat back up. -The starter was just recently replaced and is working -The is continuity between the thermostat pins, safety thermostat, fuse, and heat bias Where do I go from here to trouble shoot some more? Parts diagrams: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-*87873100/0582/0151200
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 131 Answers
You may have to get a new heating element when they go out the jet dryer where the heat comes out will not work normally this is caused buy a bad heat element. If not take back panel off and check the little white fuse and replace it, Almost all dryers are the same in that area.. Hope that helps....
Posted on May 16, 2017
jumptrout51
  • 3361 Answers
SOURCE: Gas dryer does not completely dry
Replace the glowbar ignitor and also the gas valve coils.
Posted on Aug 18, 2009
hiltonjug
  • 612 Answers
SOURCE: Dryer heats for a bit then stops.
Looking in the wrong place. i see this 3 to 4 times a week. you have a bad motor. Motor will continue to run if the gas does not light. Just like it runs on air only. The motor stops due to internal switch that keeps it from catching on fire. Sorry someone put you on the wrong track but you will need to replace the motor.
Please rate this solution if helpful.
Posted on Aug 25, 2009
canwoodjc
  • 3301 Answers
SOURCE: My Kenmore 110.66962501 dryer doesn't start.
if your sure the thermal fuse is good,, check the start switch,, making sure the dryer select setting is set to something other than off, also, the door switch . you can Jumper both these switches, I'd try the door switch first as they go out more often . if you have a meter and want to test the switch Some door switches have only two metal prongs extending from the body, while others have three. Those with three terminals will have a common (COM) terminal, a normally closed (N.C.) terminal, and a normally open (N.O.) terminal. Those switches with only two terminals will have either a common terminal and a normally open terminal, or a common terminal and a normally closed terminal. We are providing directions for testing a door switch with three terminals. If you are dealing with a door switch that has only two terminals, ignore the part of this test that does not apply to you.Use your ohmmeter to test your switch for continuity. Begin by setting your ohmmeter to measure resistance at a scale of R x 1. If yours is a two-wire switch, touch each tester probe to each of the switch's terminals. You should receive a reading of infinity. While the probes are still touching the switch's terminals, press in on and hold the switch. The reading should change to zero.
Posted on Jul 20, 2011
SOURCE: Kenmore 70 series dryer won't heat
Post the model number for clarity. These tests should only be attempted by competent service personnel. Do you actually have 220 power? Are both legs of circuit hot...at 120v? While dryer is unplugged from power, check the heating coil for continuity. Also check continuity to ground from each end of heater (should not have continuity to ground at both ends). Also there should be power to the heating element when activated.
Posted on Mar 15, 2012
TheMobilian
  • 8220 Answers
SOURCE: Timer ticking and heating element activating when dryer is off
One thing to check is if the heater is shorted to frame.Remove the wires and do the checking. If that is fine then the only way the heat can come on at all is IF the motor is running. So check between terminals one and 2 for continuity with the motor NOT running. If you get a reading then your motors cent switch is stuck. You can sometimes oil the springloaded sliding switch but most times the springs have broke on it.
Posted on Jun 21, 2012
Testimonial: "Thanks this helped me diagnose the issue."
I have A kenmore elite gas dryer model # 110.75062501 it won't heat please help
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'
Jul 18, 2011 | Kenmore Dryers
Kenmore Gas Dryer 11072212101 won't heat. we
heatman101.,/
Jun 30, 2011 | Kenmore 73102 Gas Dryer
Ovendoor will not lock on self clean mode
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 07, 2010 | Kenmore 73952 Gas Dryer
Hello-I have the Kenmore Electric Dryer model 110-66842501 series 80. Started the dryer and noticed a burning smell & the dryer was unusually warm to the touch. Now there is no heat. Drum turns...
heatman101
Jun 12, 2010 | Dryers
I have change the element & fuse & still no heat
heatman101
Jun 06, 2010 | Kenmore 62882 Electric Dryer
No heat/ gas dryer
heatman101
Jun 04, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer thats not drying
heatman101
Jun 01, 2010 | Dryers
Wet and cold clothes after cycle
heatman101
May 31, 2010 | Kenmore 72062 Gas Dryer
My dryer (kenmore elite model 110.64992300) wont heat
heatman101
May 26, 2010 | Kenmore 64992 Electric Dryer
Dryers Logo
56 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
