Question about Ariens Zoom 42 In 165 HP Briggs Stratton Zero Turn Riding Mower ()
Turn zero the mower was running fine and the blade stoped but mower would run as long as i wouls stay sitting i would shut down even with e break and pto button in off, i repaced the pto button and the blade started to work for about 5 min and stoped thought i had a bad pto button got another one same thing blade worked about 5 min and then stoped the button was hot the mower has a 12 hp kholer ohc 32 inch cut
    Filmmaker:
    Uploaded 5 video answers.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 108 Answers
Sorry but i would talk to the shop about that.
Posted on Dec 29, 2013
  • 2468 Answers
SOURCE: Ariens Sierra 1440H Lawn Mower
the solenoid is sticking inside the housing
Posted on Apr 30, 2010
SOURCE: mower only runs two min and quits
Sounds like a blocked or dirty fuel inlet.
Remove the carb bowl and work the float up and down until gas flow improves. Be gentle! Just a little light pressure from beneath and the float should swing up about a quarter inch.
The short run is due to the carb bowl not refilling fast enough to keep up with full throttle demand.
Make sure when you put the carb bowl back on there arent any fuel leaks before trying to run the mower.
Good luck and be careful!
Posted on Jul 25, 2010
  • 59 Answers
SOURCE: mowed an area of about 12 X 12 and it just cut
the kill switch cable may have stretched, you can check this by disconnectiing the kill switch wire. With this unhooked and it still has no spark, replace the coil
Posted on Sep 25, 2010
#1 Taper
  • 1040 Answers
SOURCE: When I start my Ariens
You either need a carburetor rebuild or you need a valve adjustment. Either of these things would cause this to happen.
Good Luck!
Jim
Posted on Aug 20, 2011
  • 6468 Answers
SOURCE: Hard to start after it sets up for 4 to 5 weeks
gas is only good for small engines for 30days use fresh gas
Posted on Aug 07, 2012
Mower shuts off as soon as you release parking brake and in park will shut off if you turn blade on
You most likely have a safety switch issue, try un-plugging the switch in question and holding the wire connectors together with a small vise grip and do a test to see if it will run. If it stays running, then replace the switch in question before using your machine.
Oct 08, 2016 | Vanguard 48" Great Dane Zero Turn Lawn...
Is there any way to bypass the switch that engages the blades on my Husqvarna RZ4219 zero turn mower so that it will start?
get a test light, this will make troubleshooting alot easier. check seat switch,stick,neutral,guard and the power in and out of the key. 6 12V Circuit Tester with 5 ft Lead
Sep 04, 2015 | Husqvarna RZ4219 42" 19.5HP Zero Turn Lawn...
Wheels won't turn, runs and blades work
if by turn you mean they wont rotate, then check if parking break is on, if you mean you cant turn the steering wheel, or cant make make it go around corners, then check the linkage
Apr 20, 2013 | Cub Cadet Riding Lawn Garden Zero Turn...
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Jul 20, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
I have trouble starting the tractor
First, make sure you are using fresh gas. Gas breaks down quickly with the ethanol they put in it now.
Next, you must apply the brake before you start the tractor, and be sitting in the seat.
Make sure it is neutral and make sure the blade is not engaged.
Apply the choke, then start the tractor, once the tractor starts running turn off the choke. let the engine run for a bit, then put it to full throttle.
If you get off the seat without the blades off, and the break on, the engine will shut off.
May 03, 2009 | Craftsman Garden
Ariens Zoom 42 In 165 HP Briggs  Stratton Zero Turn Riding Mower () Logo
110 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
