Question about Magnavox 50" LCD HDTV 50MF412B
Tv problem orange stripe on screen
    New Friend:
    Problem Solver:
  • 5 Answers
It is sometimes possible to message a dead pixel back to life by rubbing the surface of the screen where the dead pixel is with a soft cloth. I have heard reports of it working, but would not recommend it. Also the length of time it lasts is indefinite.
Posted on Jul 30, 2013
What are the coler s of the speeker wire for a 1996 ford explore
Right rear speaker Orange with red stripe is negative brown with a black stripe is positive Right front speaker Dark green with orange stripe negative white with light green stripe positive Left rear speaker Gray with light blue stripe negative Tan with yellow stripe positive Left front speaker Light blue with white stripe negative orange with light blue stripe positive
Aug 15, 2011 | 1996 Ford Explorer
I have a 2005 f150 lariat super crew, I want to change the factory speakers and put some after market speakers, but my question is does anybody know how to tell wich is positive and negative in the...
For the std single or 6 disc changer, non DVD
Front
L + : Orange w/ Light Green stripe
L - : Light Blue w/ White stripe
R + : White w/ Light Green Stripe
R - : Dark Green w/ Orange Stripe
Rear
L + : Gray w/ Light Blue stripe
L - : Tan w/ Yellow Stripe
R + : Orange w/ Red Stripe
R - : Brown w/ Pink stripe
Dec 30, 2010 | 2001 Ford F150 Styleside SuperCrew
Tell me the color coding of wall jack to connect cat6 cable to the switch
You can use either T 568 A or B providing that both ends of the cable are wired in the same format. If one side is allready ended thenI would try T568 B standard first.
Pin T568A Pair T568B Pair Wire T568A Color T568B Color Pins on plug face (socket is reversed) 1 3 2 tip 60px-wire_white_green_stripe.svg.png
white/green stripe 60px-wire_white_orange_stripe.svg.png
white/orange stripe rj45plug-8p8c.png 2 3 2 ring 60px-wire_green.svg.png
white/orange stripe 60px-wire_white_green_stripe.svg.png
white/green stripe 4 1 1 ring 60px-wire_blue.svg.png
white/blue stripe 60px-wire_white_blue_stripe.svg.png
white/blue stripe 6 2 3 ring 60px-wire_orange.svg.png
white/brown stripe 60px-wire_white_brown_stripe.svg.png
white/brown stripe 8 4 4 ring 60px-wire_brown.svg.png
Sep 09, 2010 | Leviton (102-5G108-RW5)
Wire order in new clip to replace broken end end 10 base T
From left to right:
1. White/Orange stripe
2. Orange/White stripe
3. White/Green stripe
4. Blue/White stripe
5. White/Blue stripe
6. Green/White stripe
7. White/Brown stripe
8. Brown/White stripe
Hope this helps!
Aug 07, 2010 | Unicom UTP Network coupler (ILC-S504C-SH)
Cat 5 cabling
Straight Cabling :
Side 1 Side 2
White Orange White Orange
Orange Orange
White green White Green
Blue Blue
White Blue White Blue
Green Green
White Brown White Brown
Brown Brown
Cross Cabling :
Side 1 Side 2
White Orange White Green
Orange Green
White Green White Orange
Blue Blue
Green Orange
Brown Brown
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 11, 2010 | Computers & Internet
Sony KDF 3LCD Screen has a horizontal orange tint stripe at top
This problem is caused by a defect in the optical block. It causes about 1 - 1.5" tint usually green, orange, or yellow at the top of the screen. The part is very expensive, retails around $600-800 usually. You cannot fix it without replacing the optical block. They did have an extended warranties for this particular issue because of a class action lawsuit on certain models. Call Sony to see if your model is one of the ones they extended the warranties.
Oct 05, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
I have a 2000 accent.I'm trying to self install my old eclipse deck but need a diagram for the accent wire set up.
Black - Neg. (-) earth, Orange/Black stripe - Constant 12V, Blue/Black stripe - ACC 12V, Green/Orange stripe - Pos.(+) Dimmer, Green/Black stripe - Neg. (-) Dimmer.
There are two Orange and two Blue wires, you will need to work out which is which, it's not hard.
Front Right - (+) Brown,(-) White;
Front Left - (+) Red, (-) Blue;
Rear Right - (+) Blue, (-) Orange;
Rear Left - (+) Green, (-) Orange.
Sep 01, 2009 | 2000 Hyundai Accent
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Magnavox 50" LCD HDTV 50MF412B Logo
55 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
