Question about Health & Beauty
I have had my e100 electric scooter for a about 2 years i havent actually used the scooter in 12 months so today i plugging in into the wall with the charger and there is a green nonflashing lite on the charger is this a good sign? do you think i need a battery or something since i havent used it in forever
  • 53 Answers
The charger light should normally be red if the battery is accepting a charge and green when the charger goes into trickle charge or off. SLA batteries do not last well if they are not regularly given a top up charge. I suspect the battery needs replacing.
If you have access to a voltmeter then you can test the battery voltage at the charger input port on the scooter.
There are lots of places that sell Razor E100 scooter parts and provide resources/information on replacing the battery.
Here are a few: http://www.razorama.com/
http://www.scooterguru.com.au/
http://electricscooterparts.com/
http://www.monsterscooterparts.com/
Posted on Oct 28, 2013
How to fix my razor scooter e100?
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
The control module is simple and can be replaced with only a 24 volt relay without the kick start feature or Brake. If you want the brake then you can use two 24 volt relays still no Kick Start.
For those of you who know electrical, below is circuits I developed to replace the controller. This diagram will also give you a better understanding on the Razor circuit.
NOTE : This is not a schematic diagram of the Razor E100 Control Module. I designed this circuit. for my Great Nephew's Scooter.
1. The Brake is a normally closed switch that opens when you squeeze the Brake handle.
2. The throttle is two normally open switches that close when you turn the throttle.
3. The Kick Start circuit is described in the Diagram below.
4. The resistors values may need to be tweaked for best performance.
Google Link to what could be the Electrical Diagrams for E-100
Aug 13, 2014 | Sport & Outdoor - Others
Have an e100 razor electric scooter. it has not been used since I bought for a couple of years. I got a new e100 charger and tried to charge but I noticed that the charger's does not activate either red...
Most equipment running on rechargeable batteries have one thing in common: if you let the battery sit there for long periods of time without recharging, the charger is not made to bring the battery back up to spec. The battery pack, if it is still good, needs a "kick" or "boost" from some other strong supply to get it started.
The other solution would be to replace the battery pack all together. If you have a friend with a similar scooter, you can try your new charger on his scooter to see if it works. Hope this helps!
Oct 21, 2013 | Razor E100 Electric Scooter
I have two electric razor 175 and put new batteries in both of them. After fully charging them all i hear is a click everytime turn the throttle but nothing,, anyone that can help please help
Thank you for choosing FixYa, I will be helping you today :)
When using an electric scooter, it's always important to know that you must advance on the scooter manually, and during this action, only then can you turn the throttle. The engine on an electric scooter is not powerful enough to move a person by itself.
Hope this helps, thank you :)
Jul 03, 2011 | Razor E100 Electric Scooter
Hi i have a razor e100 today at a yard sale and brought it home and plugged it in and the green light turned on and i plgged it in to the scooter and the light tuned green so i pulled the plug out of the...
There are a few components to check when diagnosing electric scooter issues.
1. Batteries
2. Wiring
3. Controller
4. Throttle Assembly
5. Fuses
Once you inspect all of these for damage, you can test your motor and batteries, by bypassing the controller, and directly hooking the batteries to the motor. If the motor spins very fast, then you have good batteries, and a good motor. The controller will need to be replaced. If your motor spins slowly, you could require new batteries or Controller, or battery, depending on the results.
You can find replacement parts and service locator here.
urbanscooters.com/partsforscooters
Oct 02, 2010 | Razor E100 Electric Scooters Red
Have an e100 razor electric scooter. it has not been used for a couple of years. I got a new e100 charger and tried to charge but i noticed that the green light stays on and the red light charging does not...
The batteries are dead. The battery in these scooter need to be kept charged or if not in use for a long time charged every 3months. Otherwise, like what to you, they will go dead. The chemicals in the battery have deteriorated to the point where it won't hold a charge. Replacement batteies are available at:
razor.com
Jul 20, 2010 | Razor E100 Electric Scooter
How do I charge my scooter I have lost my instructions
Look in your manual if you lost it then, go to razor.com and request one. But the simple answer is to:
1. Turn off the scooter
2. Plug charger into wall outlet.
3. Find the hole on the side that matches the charger plug(not the wall outlet plug) .
4. Plug the charger into the scooter.
5. Wait until the charger turn off ( if the charger is a smart charger), typical charging time is 4-6hours.
*If not a smart charger you can calculate the charge time by using an online battery charging time calculator.
Jul 02, 2010 | Razor E100 Electric Scooter
Razor E100 reset button and no charge
Hi... My son hasnt used his Razor E100 for nearly a year as couldnt find the charger.. I finally found it and as soon as I plugged it in the plug was showing green light as that it was fully charged... When we turn the unit on it lights up but its dead... Where can I get the cheapest battery (and does it have 1 or 2)? Or you mention a reset button? Many Thanks...
Jan 24, 2010 | Razor E100 Electric Scooter
Health & Beauty Logo
101 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
