Question about Gateway 420GR PC Desktop
Can not go on network
System check says network adapter is ok. connector and cable are ok. does not light up router indicator.
  • 32 Answers
Is the windows network icon giving you a popup or is the web browser just saying it cannot connect?
Posted on Jul 30, 2013
Need help with a wusb54g ver4 network adapter
You are say link light means network light not on. Then you check network cable because network cable not proper response not link light on. or check you not break any cable. If possible reset Linksys adapter and wait some time then open and configure i hope solved your problem. If not solved then contact Good network engineer.
Thanks.
Computer Support
Mar 06, 2014 | Linksys Wireless-G Broadband Router
INET light is on not able to connect to internet
Checked the instruction manual online. There's no INET light indicated. There's Power, Status, WAN, WLAN, and LAN LEDs. The WAN LED only indicates that the WAN port is connected to another device, e.g., cable or DSL modem. Check on your cable or DSL modem to see if the Internet light is on. If so, then you'll need to log into your router and go through the configuration/setup per the manual for your type of connection.
Oct 18, 2013 | D-Link 802.11g Wireless Router WBR-1310...
Network adapter not working
Flying blind here, with not much info, but let's see. Have you tried a new cable? Have you tried a different outlet in the back of your router? Are you saying the light on the cable which plugs into the back of your computer. Have you checked to see if there are any errors showing in Device Manager?
Jul 30, 2013 | Gateway 420GR PC Desktop
Recently my computer indicated "network
Yes, the router is probably faulty.
It pays to connect all your computer equipment to a surge protector board.
Jun 15, 2011 | Computers & Internet
I m getting error on my dir-300 :network cable unplugged" and only power light is indicated. No other lights blinking. What to do? I tried to reset several time but not worth..
1. Make sure the LAN/ Ethernet cable and RJ-45 connectors at both ends of the cable are fine and the cable is not damaged.
2. To identify the problem, try a short cable and another PC/ Laptop
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Apr 04, 2011 | D-Link DIR-300 Wireless Router
How Can I Get My Ps2 To Go Online What Parts Are Needed
You need the Network Adapter and you have to sign up and pay money/ month
http://au.ps2.ign.com/articles/366/366021p1.html
f you are hooking it up to a DSL cable/modem,
1. Remove the sticker covering the network connector on the Network Adaptor and
plug your Ethernet cable in the connector labeled NETWORK.
2. Plug the AC power cord for the PlayStation2 system into an electrical outlet.
3. Turn on the PlayStation2 system and start the Network Adaptor Start-up Disc.
If you are hooking it up to a router:
1. Remove the sticker covering the network connector of the Network Adaptor.
2. Connect an Ethernet network cable from the NETWORK connector of the Network Adaptor to an available LAN port of the router.
3. Connect the WAN port of the router to the DSL or cable modem.
4. Connect a personal computer (not pictured) to an available LAN port of the
router. Use a web browser on the PC to set up the router to reach the
Internet.
5. Follow the specific instructions that come with the router. There is no additional installation for switches.
If you are hooking it up to a LAN:
2. Connect an Ethernet network cable from the NETWORK connector of the Network Adaptor to a wireless Ethernet bridge.
3. Connect the WAN port of the wireless router to the DSL or cable modem.
4. Connect a personal computer to the router. Use a web browser on
the PC to set up the router to reach the Internet.
For pictures, see the thread here:
http://www.funadvice.com/r/3js7klmkua
May 20, 2010 | Sony PlayStation 2 Slimline Console
Second computer connected to this model gives message "Network cable unplugged" when it is not! network connection intermittent. What can we do please?
Hi Jackie!
It sounds like a communication problem between the router and the computer. Try the following solutions to solve this:
1.Connect the LAN cable to other free LAN port in the router.
2. Try using a different LAN cable.
3. a. Open Device Manager
b. Go to Network adapters. Click on the "+" sign next to it.
c. Double-click on your network adapter.
d. On Advanced tab, look for Speed/duplex settings (or Media Type)
and change it's value to Full autonegotiation (or AutoSelect).
e. Click OK on all windows.
f. Close the Device Manager and restart your computer.
4. Reinstall or update your network adapter device drivers.
A "workaround" solution - use a wireless network adapter to connect wirelessly to the router.
Hope I helped,
Pelu.
Mar 16, 2010 | Belkin F5D7630uk4A Wireless Router
Trying to connect two computers to the internet through a router (not wireless) having problems after connecting both computers to the router, only one computer has internet connection. My internet...
Initially check whether the ip address is assigned in the computer in which internet is not browsing using the command ipconfig/all for windows and ifconfig for linux.If ip is present try to ping the default gateway ip address,if ping is success there is no issue in the cable you used and also with ip address.If ip is not assigned assign ip by manually or by using dhcp of router.Enable and disable the lan card in the router so that sometimes the problem get resolved.After ip is assigned and ping with router is ok .Ensure dns servers are correct else give google public dns server 8.8.8.8.Then try to ping www.google.com in command prompt if ping is success then you can browse.
Mar 01, 2010 | HP Pavilion a1610n PC Desktop
When I connect the wrt160n in the pc it says network cable unplug
Check the Ethernet adapter status under network adapters in devicemanager.
right click my computer-properties-hardware tab-device manager-network adapter.etherrnet should be green
Jul 12, 2009 | Linksys WRT160N Wireless Router
Problem with my lan port
did you check the cable that is it working fine???
and the other thing does your network connection shows that the local area is unplugged if it shows then it is definatly problem with the wire or Connector.
Nov 08, 2008 | Dell Ethernet Card Network Adapter
Gateway 420GR PC Desktop Logo
19 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
