Question about Garden
Husqvarna trimmer fuel line routing diagram model 123l
I need to know where the fuel hoses hook up on the carb, bulb, and tank
slohry
  • 87 Answers
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Posted on Apr 10, 2009
mitchjl_1692
  • 3 Answers
SOURCE: Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
Posted on May 27, 2009
  • 3600 Answers
SOURCE: Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Posted on Jun 21, 2009
  • 52 Answers
SOURCE: String trimmer, fuel lines disintegrated, I need routing.
The Walbro has two connections on it for the fuel line. My Walbro has one connection on the side of the idle screw and main fuel adjusting screw. This connection hooks up to the suction side of the primer bulb. Usually the shorter stem. (You actually **** fuel through the carb instead of pushing it through.) On the other side of the carb is the other hook up. It draws fuel from the tank. This line will connect to the side of the tank that has the filter. The other side of the tank is your return and it hooks to the other connection on the primer bulb. Usually the longer stem.
Posted on Apr 19, 2010
  • 4 Answers
SOURCE: How do I replace the air purge pump primer bulb
if it is a clip bulb, romove it , and take it down to your local lawn care shop, and see if they can get you a new one, but if theres just a plate holding the bulb on, then take out those screws on the plate, and pull the bulb off, then try and find a replacement, once you do that, just put the bulb bacl on, and then put the plate on, and tighten it up
Posted on Aug 24, 2011
I need the fuel line routing diagram for a Craftsman Model No. 358.791510 Weedwacker 32cc/1.9 cu.in. 2-cycle
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Jan 18, 2012 | Garden
Fuel line routing for craftsman chainsaw 358.350370
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Jan 11, 2012 | Garden
My wife somehow jerked the fuel lines off my 123L husk'. what goes where and such
fuel line shoud come from the tank to the primer, then to the carb.
Aug 31, 2011 | Husqvarna 28cc Gas Line Trimmer
Replaced primer bulb and all fuel lines still getting air in lines. ran pretty good for about 10 minutes now will start with choke but dies in a few seconds. Cannot rev. up. cleaned under both plates but...
The primer bulb pulls fuel from bottom of fuel tank,when bulb is full it will return fuel back into tank,the hose entering bulb runs in the tank to bottom with filter on the end,the return hose stops just as it enters the tank maybe 3/4",make sure the hoses entering tank are tight fit or they will pull air in and leak.the carb may also need rebuild/clean,there is a screen inside of carb that may be stopped up which will need to be replaced.(carb kit).
Feb 18, 2011 | Troy Bilt Tb70ss Gas Trimmer
Gas edger Model 358.773100 the fuel lines were cut. looking for diagram to repair
They don't really have fuel line routing diagrams available. This is even true on the Sears website. What they do have is the machine breakdown diagrams with all the parts listed and pricing for all available parts. I can give you fuel line instructions for a 32cc trimmer. I see that your model is a 24cc 2-stroke engine. This may point you in the right direction.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Nov 28, 2010 | Craftsman Garden
No gas getting from the gas tank to the carb. replaced hoses and filter already. can not even draw gas with primer button.
You either need a new primer bulb (leaking air) or you have the fuel lines routed wrong. Here is the correct fuel line routing just in case:
Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb.If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank
Oct 04, 2010 | Craftsman Convertible 25cc. Gas Line...
My trimmer came with no fuel lines connected to the primmer bulb. Does the longer nipple on the bulb get the line from the tank? What about the other nipple?
If your trimmer is brand new, you could take it back and receive another one that has the lines hooked up or go back where you bought it and LOOK at the same model and note the fuel lines routing.
Or you can try the fuel lines one way and if no success starting, switch them around and try to start the machine.
On these machines the "primer bulb" is actually a "puge" bulb that moves (pushes) air and old fuel out of the carb back into the fuel tank while drawing (pulls) fresh fuel from the tank into the carb.
Some lawn mowers have actual "primer" bulbs on their carbs.
Jun 09, 2010 | Garden
Need to know the fuel line routing including the primer bulb.
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Look carefully at the 2 nipples on the carb. You can tell one is slightly larger than the other. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. completing the purge circuit. This info pertains to the Craftsman 32cc with Zama carb and may work on the 25cc model as well.
Jun 01, 2010 | Craftsman 25cc Gas Line Trimmer
Apr 17, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
596 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
