Question about Garmin StreetPilot 2610 GPS Receiver
GARMIN NUVI 1300 can not reset!!!!
I tried to update my Garmin Nuvi 1300 and now it only turns on, but I can not reset it. I tried all reset tips. Now, when I turn it on, it shows the Garmin logo, flashes once and then goes on to the Garmin logo and hangs on loaer loading... FOREVER. Can I do something to fix this?
  • Garmin Master
  • 2,130 Answers
No, it will need to be serviced. Please see this link:
http://www.sharc.net/gps_bootup_repair.htm
Posted on Aug 01, 2013
SOURCE: NUVI 250w Show Black Screen with ICON of Computer and NUVI
I had this problem. I discovered that I was using the wrong lead in the car. The problem resolved itself when I used the lead that came with it.
Posted on Jun 10, 2008
pabloloco
  • 2335 Answers
SOURCE: hi my garmin nuvi 205w has gone into some kind of
Try the Hard Reset procedure outlined in this tip.
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them.
A hard reset (or Clear All User Data)has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will beread from 'temp.gpx' into the non-user accessible memory area on theNuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
Ifpossible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
Posted on Jan 15, 2010
pabloloco
  • 2335 Answers
SOURCE: garmin nuvi 1300 brand new. when i turn on it
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Posted on May 27, 2010
SOURCE: My Garmin nuvi 780 will
I had the same problem. When you have your nuvi plugged into your cigarette lighter it doesn't charge. Your battery is probaly near dead. I called Garmin and they told me to plug it into my computer via the usb cable. Turn the Garmin off and let it charge for several hours. That did the trick
emissionwiz
  • 78289 Answers
SOURCE: My garmin nuvi 1300 stopped working when i stopped
have u tried as reset?
Posted on Jun 17, 2010
When turning on the unit, it starts up with the Ga...
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
May 20, 2010 | Garmin nuvi 1300 Car GPS Receiver
Tip
Garmin Nuvi 1300 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1300 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
on May 13, 2010 | GPS
Tip
Garmin Nuvi 1300 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 13, 2010 | Garmin nuvi 1300 Car GPS Receiver
THE UNIT WILL NOT TURN ON
I hope that helps.
May 15, 2010 | Garmin nuvi 1300 Car GPS Receiver
My gps is not turning on. I tried to charge but there is no signal. Can you please help me?
I hope that helps.
May 12, 2010 | Garmin nuvi 1300 Car GPS Receiver
Will not turn on. Is there a reset button?
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
Apr 19, 2010 | Garmin nuvi 1300 Car GPS Receiver
HI not to good on compt. my 1300 series turns on says lpading maps then powers off tried 2 methods of re booting joe kane thanks
I hope that helps.
Apr 01, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin freezes up on the first screen (which says garmin).
I hope that helps.
Jan 23, 2010 | Garmin nuvi 1300 Car GPS Receiver
When I turn on my Nuvi 1300 the Garmin logo appears. But after that, nothing happens. It appears that the unit freezes up Thanks, Curtis
A Garmin Nuvi 1300 that won't start, freezes, or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
Jan 06, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin nuvi 1300 brand new. when i turn on it stays black with only the "garmin" logo showing. How do I fix?
I hope that helps.
Dec 28, 2009 | Garmin nuvi 1300 Car GPS Receiver
Garmin StreetPilot 2610 GPS Receiver Logo
156 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
