Question about Vehicle Parts & Accessories
The car has been garaged seince 2008 I put a new battery in it fresh gas cranked it over and didn't start sprayed it with eather it fired I push the valve on the fuel rail and its dry I pulled the bac
  • 2,530 Answers
I don't see what kind and year of car you have, but understand they can dry out and may need to be "primed". You might also need to replace the fuel pump and filters, as they may also have dried out.
In the old days, a person could gently pressurize the gas tank to see if the gasoline would flow through the system, but today, that would probably not work due to the extra emissions and vapor lines.
If the fuel rail stays dry, it probably means the fuel is not reaching that point.
If you have a removable rubber fuel hose between the tank and the engine, you might try either a suction on the line to bring gas to you, or some air pressure on the line to blow it up to the front. You will need to be very gentle here.
Blessings
Posted on Jul 30, 2013
3 Suggested Answers
  • 111 Answers
SOURCE: what should the fuel pressure be at the rail on a 99 durango 5.2
You can get help from here > http://answers.yahoo.com/question/index?qid=20110925145726AAaZx70
Posted on Jan 24, 2012
SOURCE: I have an 03 S10 and i'm putting a pig tail on it and I know the yellow and green wires on the truck are the turn signals,but what are the other 3 for two are brown and I don't remember what color the
There are 2 brown wires light brown is for the fuel gauge darker brown is tail lights the other wire if it's black is ground if its red it could be power for electric brakes
Posted on Mar 14, 2013
GMC 2000 sierra pick up 1500 sounds like it wants to start but won't turn over. Battery sounds good so I guess battery and alternator are ok. For several years fuel gauge doesn't work and...
It sure could be. But, first...by "won't turn over" you do mean it cranks at normal speed but won't start?
A simple test of the fuel pump is to stand by tank and listen as someone turns key to on. When first turned to on, your pump will activate for 2 or 3 seconds, pressurizing the fuel system, and then shut off if the engine computer doesn't get a cranking signal. Do you hear it come on? If not, then something's not turning your pump on. If you can hear it buzz on briefly, then maybe it's your filter. Another test: Spray a little starting fluid into your intake manifold (remove the big hose going into intake manifold) while someone tries starting it.If it doesn't fire and try to stay running, then it's probably an ignition problem. But if it does fire off, then you know it's a fuel problem-likely your pump or filter. good luck.
Nov 07, 2011 | 2000 GMC Sierra
190cc 675 sears push LM. Irene put it under water. Drained carb and crank. removed and cleaned filter. New gas. Won't start. Got a little pop with starter spray. No pop at all?
Did you drain fuel tank before refilling with fresh fuel? Drained carburator bowl good, drained crankcase and refilled with fresh oil good,removed air cleaner and dried out good. One question for you , did you remove spark plug and drain any water that may have gotten into your cylinder through an open valve? There could be water sloshing around in the cylinder, gas and water will not fire, and water on spark plug wont allow plug to spark. If you need any more help please get back to me , I believe this is the first under water problem I've encountered. GOOD LUCK.
Sep 07, 2011 | Briggs & Stratton 190cc 875 Series OHV...
95 ford thunderbird has been sitting for about 2 yrs. engine will turnover but will not crank. suggestions
i would be inclined to empty fuel tank and put fresh petrol in and then try it again ,try starting it with a ether spray in the air intake and see if it will fire up because once engine warms up a bit it will run on the old fuel so you drive to a garage and fill it up with some fresh fuel
Jan 27, 2011 | 1995 Ford Thunderbird
My pickup was cold yesterday. Coldest day of the year. It started, and I left way too ea rly (didn`t realize how cold it was). less than a km later, the truck started burping, and then stalled. Tried...
Definetely sounds like frozen gas line, should put it in a garage or somewhere with heat and put in a gas line antifreeze to remove the moisture in the gas. Plugging it in will only warm the oil/intifreeze.
Jan 18, 2011 | 1999 Chevrolet S-10 Pickup
Someone put diesal in my gas truck
Man what a mess that is, hopefully you didn't start your truck up.
You need to have the tabk grained and flushed.
This is a dangerous repair to do yourself, best to have it towed to a garage and pay to have it done.
If you have to do it your self, be sure to have the battery on your truck disconnected to make sure nothing haopens to make a spark, and have a buddy on standby with a fire extingiher.
Please be careful if you try it your self
Nov 23, 2010 | Dodge Pickup Cars & Trucks
Lawn mower will not start
check gas tank with light is there dirt in tank? did you change fuel filter? is there spark at the spark plug? try a 2 second spurt of starting fluid in carburetor and crank does it fire?if it does then you most likely need to clean carburetor with carburetor cleaning spray, flush fuel lines with spray and swap fuel filter.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have an 04 CRF250R, with a new plug, fresh gas, and a fresh top end( good compression), but it won't start, any ideas?
ok check to make shure it is gettine the gas you can manualy spray a little gas in the carb and see if it starts that will let you know 2 things eather air to fuel flow mix isnt right or it isnt getting gas if it dosnt start then its the timeing
Jun 03, 2009 | 2004 Honda CRF 250 R
My 81 Honda gl 1100 was not winterized. Installed new battery. Cranking fine. Wants to start. Smell gas, probably flooded.
You should drain your gas, gas line, and carbs.
Try putting in some fresh gas and see if it wil fire up.
If not a carb rebuild is more than likely going to be needed.
Apr 21, 2009 | 2002 Honda VT 125 Shadow
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
