RCA 42" 42LA45RQ
I have a RCA 42" 42LA45RQ that won't power on and the standby light does not come on.
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
Check and replace its main power regulator board as card basis.
Posted on Jul 30, 2013
  • Shane Jul 30, 2013
    How would I test the power supply board? I've checked the capacitors and none are blown or burnt. I've also checked the fuse. the board has around 24 to 4 something volts at most plugin. I can't find a service manual or any info to how much power the connectors should have or which one suppose to have power.
  • Shane Aug 01, 2013
    I've found that on the main power cable to the main board from the power supply board there is no 12 volt
4 Suggested Answers
jdvillanueva
  • 2098 Answers
SOURCE: I have a RCA 32" Flat Screen TV that shut off and
The sound was came from the clicking of the relay. This kind of symptoms is an indication of out-of-regulation condition on the power supply section. This is caused by faulty electrolytic capacitor. It will dropped the supply voltage and will trigger that kind of symptoms.
Faulty electrolytic capacitor mostly has a physical indication of fault like bulged/dome at the top and can be easily identified. See sample picture of faulty electrolytic capacitor below.
capacitor with bulged/dome at the top.
Check these parts on the power supply section. Once found, replaced it with same capacitance and working voltage which is printed on its body itself. Click this LINK for more info regarding electrolytic capacitor.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified TV Technician to isolate the faulty parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Aug 05, 2011
SOURCE: RCA LCD TV red light flasiing tv won't come on
I acquired a 42" RCA LCD TV (model L42WD22) that would not come on. When you pressed the power button, the power indicator light on the front of the TV would blink red 5 times. It would then pause for a few seconds and blink red 5 times again, etc. I work as a technician so I took the TV apart. It had capacitors in the power supply section that had overheated and were obvious by looking at them. I replaced all the caps that looked like that, and the TV has been working for days and days after that. The manufacturer uses cheap components when they built, but capacitors don't last forever anyways, even good quality caps.
Hope that may help.
Posted on Oct 27, 2012
  • 879 Answers
SOURCE: Standby Light 12 Blinks and Won't turn on
What is the brand name to your TV?
Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
Posted on Dec 02, 2012
Rca 20f512 tv won't stay on
Here is a troubleshooting guide for you:
Flyback Transformer
must have supervision of a qualified service technician
Sep 23, 2012 | RCA 20F512T 20" TV
Thomson TG585 v8 connection problem
this is way too vague, try power cycling your modem and router. also make sure you have not accidentally hit the standby button (teal oval on front). let me know what lights are on and or flashing and what lights are not. that modem's GUI can be accessed by entering 192.168.100.1 in the browser bar and you may be able to diagnose your problem from there.
Nov 01, 2011 | RCA Thomson Digital Cable Modem (DCM305R)
I have a RCA DVD Home theater system and I plug it in and the blue standby light comes on, but when I push it or other buttons on the unit, it just powers off and then won't turn turn back on at all....
I am having the same problem...i plug it in the standby light xomes on but i press the power button and nothing happens...mine is a rca rtd315wr model
Sep 03, 2011 | RCA RT2360 System
My "50" RCA Scenium won't
That's usually caused by a bad lamp. However that chassis is famous for having bad caps on the power board. The repair kit is available at the following link and has repair instructions included. http://servicemanuals.vstore.ca/product_info.php/pName/rca-atc336-dlp-power-board-repair-kit/cName/repair-kits
Aug 16, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
Hope I helped you.
Have a nice day!
Aug 05, 2011 | RCA L32HD31 32 in. LCD HDTV
Hey, I got a rf power 750s. I have a jvc kd-hdr20 h.u., and a kicker 07cvr154 sub. Install went smooth, but when I turned my car on I got power in @ the amp and a lil red light at rf badge, but nothing...
Check the RCA plugs where they mount to the board and make sure the shield ground pins are not broken. If in tact a regulator might have failed not allowing power to the op-amps.
Apr 20, 2017 | Rockford Fosgate Power 750S Car Audio...
Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
Jun 12, 2011 | Pioneer Televison & Video
EVERY TIME I POWER UP ITS SAYING F61
The below doesn't work with all Panasonic equipment but if this fails then the only fix is a replacement Laser which isn't cost effective.
U61 Fault
Corrupted or Faulty DVD in Machine.
  1. Put Machine into Standby
  2. If won't go into Standby hold 'Power' for 5-10 seconds
  3. In Standby hold 'Stop' & 'CH UP' together for 5-10 seconds until tray opens
If this fails then re-initialise the Machine as follows
  1. Put Machine into Standby as above
  2. In Standby hold 'Stop', 'CH UP' & 'Open/Close' together for 5-10 seconds.
  3. Hello displayed followed by TM AV1
  4. Put Machine into Standby
  5. 11-11 then 12-12 and finally 22-22 displayed
Switch Machine on and Retune
Apr 23, 2011 | Panasonic Audio Players & Recorders
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
